Dashticz Graphs - Features, Fixes & Updates
Janco
Re: Dashticz Graphs - New Features, Fixes & Updates
Then it's correct, but it's not a real solution of course. One to have the freedom to choose the order.
And what about the beginAtZero?
Is it supposed to work for each Y axis separately (so three different settings), or is just a single value that controls all the Y axes in the same way?
- clinkadink
- Domoticz version: 2020.2
Correct, it's not a solution, it was a test.
I will try a have a look at this over the next few days.
Sent from my HD1913 using Tapatalk
- EdwinK
- Domoticz version: BETA
Can this script be modified to get the high/low tariff from my P1 meter, with some bars
- Spoiler: show
- clinkadink
Graphs in the beta branch has been updated to include the following changes:Janco wrote: Saturday 07 March 2020 13:10 Then it's correct, but it's not a real solution of course. One to have the freedom to choose the order.
- Fix for custom data Y label order. The y labels for custom data were being generated using the order your devices provides the data. If this differed to the order of you custom data, you would experience the issue that you raised. This has now been fixed to allow for this scenario.
- The beginAtZero setting has been updated to accomodate multiple Y axes. For example, for a graph with 3 Y axes, you can use:
For a graph with a single Y axis, you can still use:
beginAtZero: [true, false, true]Code: Select all
beginAtZero: true
Janco
Great. I tried it and it works now.s Thanks a lot!
Jimster
When I click on the line or bar on a popup graph, I see the the date and value at that moment, the time is missing. Whith a graph on the dash, the time is visible. Any idea why the time is missing in a popup graph?
- clinkadink
Any chance you could provide a screenshot of this? Thanks.Jimster wrote: Saturday 14 March 2020 5:04 When I click on the line or bar on a popup graph, I see the the date and value at that moment, the time is missing. Whith a graph on the dash, the time is visible. Any idea why the time is missing in a popup graph?
Jimster
On the left a graph on the dashboard, time is visible behind the date.clinkadink wrote: Saturday 14 March 2020 21:38Any chance you could provide a screenshot of this? Thanks.Jimster wrote: Saturday 14 March 2020 5:04 When I click on the line or bar on a popup graph, I see the the date and value at that moment, the time is missing. Whith a graph on the dash, the time is visible. Any idea why the time is missing in a popup graph?
On the right the same graph behind a block, no time visible. I see the date format is also different.
- clinkadink
Thanks.
Popups now default to using the recently implemented HTML tooltips (from last month). Whereas the default for graphs is the standard 'rendered' tooltip. You can enable the HTML tooltip on your graph by adding ...
The date format for HTML tooltips is set to show the date only when the range is set to 'month'. But I can see from your graph your range is set to 'day'. I will look in to why this is and report back.
toolTipStyle: true,"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
Jimster
I've updated to the latest beta, it works now. Oops, should have tried that first.clinkadink wrote: Saturday 14 March 2020 22:33 Thanks.
Popups now default to using the recently implemented HTML tooltips (from last month). Whereas the default for graphs is the standard 'rendered' tooltip. You can enable the HTML tooltip on your graph by adding ...The date format for HTML tooltips is set to show the date only when the range is set to 'month'. But I can see from your graph your range is set to 'day'. I will look in to why this is and report back.Code: Select all
toolTipStyle: true,
- clinkadink
OK, thanks for letting me knowJimster wrote: Saturday 14 March 2020 23:24 I've updated to the latest beta, it works now. Oops, should have tried that first.![]()
webrazor
Is this only in beta version or also in the latest stable 2020.1?
- clinkadink
Beta (above) refers to the Dashticz beta, not Domoticz.webrazor wrote: Friday 27 March 2020 21:09 Is this only in beta version or also in the latest stable 2020.1?
https://github.com/Dashticz/dashticz/tree/beta
webrazor
offcourse dashticz, only in beta yet.
- clinkadink
Jimster
Works great! Looks a lot better.
- clinkadink
Good news, always a relief to hear
Boattailman
The stacked is true is not working on my graph:
- Spoiler: show
- clinkadink
Your block config code is incomplete, I have corrected this below.Boattailman wrote: Monday 30 March 2020 9:15 The stacked is true is not working on my graph:Probably some stupid mistake from my side
- Spoiler: show
- Spoiler: show
