HEOS by DENON
Spacewalker
Re: HEOS by DENON
I had the problem the Heos players were not showing up.
It is solved now. Domoticz has to be the latest beta and than everything works. The latest stable was from november.
steef84
- Domoticz version: DS213+
Re: HEOS by DENON
Nice plugin!!
Really like the favorites stuff to be fully implemented
When I get home start radio playing. Or spotify. When leaving stop playing.
Are you still working on this plugin Steven? Dont have nc running on my Synology
- Stefan
Steven84
Re: HEOS by DENON
steef84 wrote:Nice plugin!!
Really like the favorites stuff to be fully implemented....
Hi steef84,
Nice to hear. No iam not working. Sneezydevil is the creator of this plugin.
- McMelloW
- Domoticz version: V2024.1
Re: HEOS by DENON
Hi to all,
I have added my HEOS speakers to Domoticz and devices are created. However I can not do anything with these devices. What can I do to control these speakers. I would like to set on/off; Volume up/down etc. Also the button Setup in de HEOS hardware entry does not doe anything. Can somebody point me in the right direction
Greetings McMelloW
- McMelloW
Re: HEOS by DENON
When I click on the remote control icon of my HEOS-switch this popup comes up. The switch-type is set to Media Player.
Please can somebody point me where I can find how to program or use this buttons. So far I was not able to find it anywhere. See also my previous post.
Thanks in advance
Greetings McMelloW
Sneezydevil
Re: HEOS by DENON
From what I can tell this is a problem with the remote.
Kodi / LMS users report the same problem:
https://github.com/domoticz/domoticz/issues/1928
Due to a very busy schedule I have not really been able to work on this hardware.
- McMelloW
Re: HEOS by DENON
Thanks for your updateSneezydevil wrote: Tuesday 12 December 2017 13:31 From what I can tell this is a problem with the remote.
Greetings McMelloW
rvanderven
Re: HEOS by DENON
Hi, any update on the issue that the buttons are not shown on Chrome? On FF indeed hovering it is shown, however this doesn't work for a phone or tablet.
- Brutus
Re: HEOS by DENON
This plugin works only for 40% at the moment.
I have bought two HEOS by Denon speakers last week. You can add the hardware and get one new "Media Player" item in the switch section.
When using the remote, the following buttons do not work:
- Favorites
- Browse
- Shuffle
- NowPlaying
- Repeat
You get the following error for every coresponding button:
Buttons that do work on the remote:
- Volume Up
- Volume Down
- Mute
- Stop
- Pause
- Play
- Play Next
- Play Previous
The status from the player is not getting updated to the "devices status" from domoticz untill a reset takes place for example when you edit the name of a switch and save it. Here you can see what I meen:
The Player with the actual "Playing" status: At the same time in the "Device Current States" in the Event section: After saving a switch the status gets updated: Also sending Commands to the player like "Stop" or "Mute" in LUA aren't working.
So we can't do anything with this to automate some things.
It also would be nice to have a seperate Slider to adjust the volume Like the Kodi plugin has.
- Favorites
- Browse
- Shuffle
- NowPlaying
- Repeat
2019-10-07 19:22:11.086 Error: HEOS by DENON: Command: 'NowPlaying'. Unknown command.
- Volume Up
- Volume Down
- Mute
- Stop
- Pause
- Play
- Play Next
- Play Previous
commandArray['Denon Woonkamer'] = 'Stop'It also would be nice to have a seperate Slider to adjust the volume Like the Kodi plugin has.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
BarryT
- Domoticz version: 2024.3
Re: HEOS by DENON
Any update on this?
still see no buttons and i cannot control anything of the heos.
i have 5 speakers, and they are found by domoticz.
domoticz v4.11777
domoticz v4.11777
- flemm
- Domoticz version: 4.11780
Re: HEOS by DENON
Last weekend I bought myself an AVR-X1600H. I was kinda thrilled when i found out it was possible to control the device with domoticz, until i realised it didn't work as easy as I thought it would
Unfortunatly I haven't made a lot of progress either. With the default 'HEOS by Denon'-hardware i'm able to get the Denon switch to appear, and the log tells me there is a connection. When something is playing on the unit, the switch shows the track name and artist. But that's pretty much it, unfortunately. I know this topic was started quite some time ago, but there must still be people using Denon devices, right?
Mario ipsum RGB mushroom 1-up.
- Brutus
Re: HEOS by DENON
I have made my own switches and sensors using the HEOS Control Protocol:
http://rn.dmglobal.com/euheos/HEOS_CLI_ ... cation.pdf
I combined it with this python script:
https://github.com/ping13/heospy
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- McMelloW
Re: HEOS by DENON
Hi Brutus,Brutus wrote: Thursday 12 March 2020 9:01 I have made my own switches and sensors using the HEOS Control Protocol:
Are you willing to share some more info about your Heos configuration in Domoticz.
Greetings McMelloW
- Brutus
Re: HEOS by DENON
What would you like to know?
I have made a lot.
- Volume slider
- Source Selector switch (Favorites, Inputs, Outputs)
- Mediaplayer sensor with information whats playing now.
So i have made two basic scripts.. one script that pulls data from the Denon and another that respond to actions in the house like:
When I come home and turn off the alarm my denon autmatically starts my Favorite Radio Station that I have saved on spot nr1 in de Denon Favorites list.
Go to sleep and turn on my alarm, the Denon wiches me a Good Night (audio file saved on my nas) and turns everything off.
My phone rings.. When I take the call Tasker (a Android Automation App) swithes a virtual switch called "On the Phone" and the Denon Volume is set to 18. The volume before calling is saved as a number and when I stop calling the volume is set to that previous value.
When I want to see a movie or series with Kodi (installed on the same machine as Domoticz) I open the Kodi Remote app on my phone and again with the help of tasker the input changes from HDMI Out (TV) to HDMI1 were my Windows Machine is hanging on.
But I have this all working under Windows. That's a sometimes a bit different with the coding in LUA.
Greetings Brutus.
I have made a lot.
- Volume slider
Greetings Brutus.
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- McMelloW
Re: HEOS by DENON
Sounds very interesting. Can you share the basic scripts. I just have a Heos soundbar and 2 Heos HS2 1 speakers. Listen to Spotify, Radio and TV-sound.Brutus wrote: Saturday 14 March 2020 18:40 What would you like to know?
I have made a lot.
- Volume slider
Greetings Brutus.
First thing first, see or I can get the system controlled by Domoticz. Then further for more sophisticated options.
Greetings McMelloW
- Brutus
Re: HEOS by DENON
I could share the scripts but they are not basic and based on Windows and my personal environment.
So i should explain the basics. Hope these will help you..
First you need to fix your soundbar with a fixed IP. You can do this within the advanced options for your Soundbar in the HEOS app.
I give the fixed IP trough my router.
Then install the plugin as mentioned here: https://github.com/ping13/heospy
You then need to make a "config.json" file and fill in the needed information you can get by giving the command: heos_player
Example of my config.json:
Now it should be possible to communicate with your Denon through the python plugin. You can test this with some commands like:
The first code is for setting your volume and the second plays the first item in your favorites list.
I have made the following LUA code for changing the volume with a "Dummy Dimmer Selector Switch"
Note that when I change the volume further then 50 it won't respond because that's to loud
Here some more examples:
Change to HDMI1 (my Kodi setup):
The "Denon Source Set" is a Dummy Hardware Selector Switch, type Selector. Here I have presets like HDMI1, TV, Radio and so on.
For al the possible commands take a look at this PDF from Denon self: http://rn.dmglobal.com/euheos/HEOS_CLI_ ... cation.pdf
Hope this will help a bit.
Greetings Brutus.
"host": "192.168.1.57",
"player_name": "Woonkamer",
"players": {
"Woonkamer": -107*******
"pid": -107*******,
"user": "[email protected]",
"pw": "password"
}Code: Select all
heos_player player/set_volume -p level=19Code: Select all
heos_player player/play_preset -p preset=1I have made the following LUA code for changing the volume with a "Dummy Dimmer Selector Switch"
DenonVolume = devicechanged['Denon Volume']
sDenonVolume = tonumber(otherdevices_svalues['Denon Volume'])
if DenonVolume and (sDenonVolume >= 1 and sDenonVolume <= 50) then
os.execute('"heos_player player/set_volume -p level='..sDenonVolume..' "')
if DenonVolume == 'Off' then
os.execute('"heos_player player/toggle_mute"')
endNote that when I change the volume further then 50 it won't respond because that's to loud
DenonSourceSetCHD = devicechanged['Denon Source Set']
if DenonSourceSetCHD == 'Kodi TV' then
print ('Denon Source Set: Kodi TV')
os.execute('"heos_player browse/play_input -p input=inputs/hdmi_in_1 -p pid=-10******* "')
endFor al the possible commands take a look at this PDF from Denon self: http://rn.dmglobal.com/euheos/HEOS_CLI_ ... cation.pdf
Greetings Brutus.
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- McMelloW
Re: HEOS by DENON
@Brutus, thanks for sharing this. I will dig into it and see how I can implement this in my situation
Greetings McMelloW
- McMelloW
Re: HEOS by DENON
Got problems at the first step. Errors on pip install and the readme.mdBrutus wrote: Sunday 15 March 2020 10:50 Then install the plugin as mentioned here: https://github.com/ping13/heospy
pi@mcmellow-pi:/tmp $ pip3 install heospy
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see pypa/pip#5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting heospy
Using cached heospy-0.1.4.tar.gz (13 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7g_l19lu/heospy /setup.py'"'"'; file='"'"'/tmp/pip-install-7g_l19lu/heospy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(_ file_);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' eg g_info --egg-base /tmp/pip-install-7g_l19lu/heospy/pip-egg-info
cwd: /tmp/pip-install-7g_l19lu/heospy/
Complete output (5 lines):
File "", line 1, in
File "/tmp/pip-install-7g_l19lu/heospy/setup.py", line 19, in
long_description=open('Readme.md').read(),
FileNotFoundError: [Errno 2] No such file or directory: 'Readme.md'
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Greetings McMelloW
- Brutus
Re: HEOS by DENON
As mentioned I installed everything on Windows. But I can remember I needed to install pip.
Pip is an installer for python plugins. So install it or upgrade it maybe it will work then.
https://pip.pypa.io/en/stable/installing/
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
