My domoticz installation received quit a large number of divices from my RFlink hardware (>3000) that are not mine and I think this makes my domotics slow. For instance when accessing the list of divices.
is there a problem executing "delete from DeviceStatus where used =0" on the database to get rit of these devices?
Peter
Cleanup unused devices Topic is solved
- Domoticz version: 2020.2
Re: Cleanup unused devices
In the list of devices, click on "not used devices" at the left top. After this, select "all" for "show entries.peter8wun wrote: ↑Monday 09 March 2020 15:04 Hi,
Peter
This will give you a complete list. Now select the little selectbox right next to the garbage bin, then click the garbage bin itself.
This gets rid of all unused devices.
Hans
- waaren
Not really butpeter8wun wrote: ↑Monday 09 March 2020 15:04 My domoticz installation received quit a large number of divices from my RFlink hardware (>3000) that are not mine and I think this makes my domotics slow. For instance when accessing the list of devices.
Is there a problem executing "delete from DeviceStatus where used =0" on the database to get rit of these devices?
- to be safe make sure you have a backup and only do this when domoticz is not active.
- If you have the allow new hardware set to yes they will come back.
- These devices will also have data in other tables.
select name as Tables_containing_deviceRowid from sqlite_master where type='table' and sql like '%devicerowid%';
delete from LightingLog where devicerowid in (select id from devicestatus where used = 0);
delete from Rain where devicerowid in (select id from devicestatus where used = 0);
delete from Rain_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Temperature where devicerowid in (select id from devicestatus where used = 0);
delete from Temperature_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Timers where devicerowid in (select id from devicestatus where used = 0);
delete from SetpointTimers where devicerowid in (select id from devicestatus where used = 0);
delete from UV where devicerowid in (select id from devicestatus where used = 0);
delete from UV_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Wind where devicerowid in (select id from devicestatus where used = 0);
delete from Wind_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Meter where devicerowid in (select id from devicestatus where used = 0);
delete from Meter_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from MultiMeter where devicerowid in (select id from devicestatus where used = 0);
delete from MultiMeter_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Notifications where devicerowid in (select id from devicestatus where used = 0);
delete from LightSubDevices where devicerowid in (select id from devicestatus where used = 0);
delete from DeviceToPlansMap where devicerowid in (select id from devicestatus where used = 0);
delete from SceneDevices where devicerowid in (select id from devicestatus where used = 0);
delete from SharedDevices where devicerowid in (select id from devicestatus where used = 0);
delete from Percentage where devicerowid in (select id from devicestatus where used = 0);
delete from Percentage_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Fan where devicerowid in (select id from devicestatus where used = 0);
delete from Fan_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Pushlink where devicerowid in (select id from devicestatus where used = 0);
delete from devicestatus where used = 0;
Thanks for the quick and complete answer. this helps tremendously.
- waaren
Not sure when the fix was applied but on older versions this approach (which should be the preferred one) caused domoticz to 'hang' when > 5 devices where selected for deletion.manjh wrote: ↑Monday 09 March 2020 15:56 In the list of devices, click on "not used devices" at the left top. After this, select "all" for "show entries.
