Sorry, I can't help with this, it is over my knowledge
Enviado desde mi Mi A2 mediante Tapatalk
script to send mqtt message with percentage
salvacalatayud
megamarco83
Re: script to send mqtt message with percentage
ok, thanks for you time on this.
but, just a question related to your script to import uservar on note red.
it seams that is not working, it give errors when import userva string.
is it working on your domoticz?
salvacalatayud
It is not my node, check the github page for issuesmegamarco83 wrote: Monday 02 March 2020 1:02 ok, thanks for you time on this.
hoeby
- Domoticz version: V2022.1
Did you found the answer for this?
I have the shelly 2.5 with tasmota flashed.
Yesterday i installed node-red with the flow in this post.
Changed the things that where needed and made the variable.
But i don't onderstand, how the variable is updatet when i move the dummy slider. Dan someone explane this?
I need to look over. It is the first time using node-red, but untill now i think it is a difficult application. Hope to find the solutions o get my shelly working
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
