Unresponsive Topic is solved
EdwinK
Unresponsive
Post by EdwinK »
Dashticz became laggy and threw errors.. 'dashticz became unresponsive'.. and then ask to wait or cancel the operation. Thinking this was due to the fact that my DiskStation was using too many processes, I decided to move the webserver part to a RPi. After working with the default settings, I then put back the config and it worked... for a moment, then the same error about unresponsive returned.
I tried to get more info fro the developers tool on Chrome.
Screen Shot 2020-02-13 at 18.30.46.png (106.28 KiB) Viewed 1848 times
Lokonli
Re: Unresponsive
Post by Lokonli »
That is the websocket connection. The websocket connection will stay open, and should be no problem.
Can you test with adding to CONFIG.js the following:
config['enable_websocket'] = 0
This will disable the websocket connection.
EdwinK
Re: Unresponsive
Post by EdwinK »
Unfortunately, same problem ;(
btw. With Firefox I get the following.
Source map error: Error: request failed with status 404
Resource URL: http://192.168.0.8:8082/dist/bundle.js
Source Map URL: ical.min.js.map
This page uses the non standard property “zoom”. Consider using calc() in the relevant property values, or using “transform” along with “transform-origin: 0 0”. bundle.js:1:67920
ReferenceError: alldevices is not defined
line 42 > scriptElement:83:7
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help http://xhr.spec.whatwg.org/ bundle.js:53:83247
The script from “http://192.168.0.11:8080/json.htm?usern ... 1627889264” was loaded even though its MIME type (“application/json”) is not a valid JavaScript MIME type.
192.168.0.8:8082
The script from “http://192.168.0.11:8080/json.htm?usern ... 1627889266” was loaded even though its MIME type (“application/json”) is not a valid JavaScript MIME type.
192.168.0.8:8082
Lokonli
Re: Unresponsive
Post by Lokonli »
The following message means something is wrong:
Do you maybe use alldevices in your custom.js?
That may not work anymore ...
EdwinK
Re: Unresponsive
Post by EdwinK »
O. I see...
/ Buienradar
    if (alldevices[500].Data == 'Voorlopig droog') {
            $('.block_500 .col-icon').addClass('off-ico');
            $('.block_500 .col-data').addClass('off-stat');
    else {
            $('.block_500 .col-icon').removeClass('off-ico');
            $('.block_500 .col-data').removeClass('off-stat');
// Toon Setpoint [377] & Toon Selector [380]
  if (alldevices[377].Data == '6.0') {
    $('.block_377_2 .col-icon').addClass('icon-off');
    $('.block_377_2 .col-data').addClass('data-off');
    $('.block_380 .col-icon').addClass('icon-off');
  else {
    $('.block_377_2 .col-icon').removeClass('icon-off');
    $('.block_377_2 .col-data').removeClass('data-off');
    $('.block_380 .col-icon').removeClass('icon-off');
  // Thuis
  if (alldevices[49].Data == 'Off') {
    $('.block_49 .col-data').addClass('data-off');
  else {
    $('.block_49 .col-data').removeClass('data-off');
  // TV
  if (alldevices[393].Data == 'Off') {
    $('.block_393 .col-data').addClass('data-off');
  else {
    $('.block_393 .col-data').removeClass('data-off');
Going to comment out those parts
EdwinK
Re: Unresponsive
Post by EdwinK »
unfortunately, after deleting those lines, Dashticz still becomes unresponsive.
EdwinK
Re: Unresponsive
Post by EdwinK »
It looks like I've found it. When I removed all multigraph's the dashboard seems to work.
Lokonli
Re: Unresponsive
Post by Lokonli »
Interesting. Maybe it's the amount of data. How many graphs do you have? Can you check in DevTools how much graph data is received from Domoticz?
EdwinK
Re: Unresponsive
Post by EdwinK »
I only had one. Need to create it again. I'll try later tonight
EdwinK
Re: Unresponsive
Post by EdwinK »
This is what I have (from the readthedocs instrcutions)
//multigraph temperature
blocks['multigraph_175'] = {
        title: 'Outside vs Inside Temp',
        devices: [ 175, 376],
        graph: 'line',
        buttonsBorder: '#ccc',
        buttonsColor: '#ccc',
        buttonsFill: 'transparent',
        buttonsIcon: 'Blue',
        buttonsPadX: 10,
        buttonsPadY: 5,
        buttonsMarginX: 5,
        buttonsMarginY: 2,
        buttonsRadius: 0,
        buttonsShadow: 'rgba(2, 117, 216, 0.2)',
        buttonsSize: 12,
                custom : {
                        "Last hours": {
                                range: 'day',
                                filter: '6 hours',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
                                        delta: 'd.te2-d.te1'
                        "Last 2 weeks": {
                                range: 'month',
                                filter: '14 days',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
                        "Last 6 months": {
                                range: 'year',
                                filter: '6 months',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
        legend: {
                'te1': 'Outside',
                'te2': 'Inside',
                'delta': 'Difference'
When I check with DevTools , in console there is one error listed:
js/domoticz-api.js:83 Uncaught TypeError: newPromise.reject is not a function
at js/domoticz-api.js:83
(anonymous) @ js/domoticz-api.js:83
setTimeout (async)
newRequest @ js/domoticz-api.js:80
mightThrow @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
(anonymous) @ bundle.js:53
fire @ bundle.js:53
add @ bundle.js:53
Deferred @ bundle.js:53
then @ bundle.js:53
domoticzRequest @ js/domoticz-api.js:45
_requestAllDevices @ js/domoticz-api.js:247
setInterval (async)
(anonymous) @ js/domoticz-api.js:112
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fireWith @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
jQuery.each.jQuery.<computed> @ bundle.js:53
newRequest @ js/domoticz-api.js:66
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
add @ bundle.js:53
then @ bundle.js:53
checkWSSupport @ js/domoticz-api.js:105
_init @ js/domoticz-api.js:126
(anonymous) @ js/dashticz.js:63
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
initDomoticz @ js/dashticz.js:50
_init @ js/dashticz.js:32
(anonymous) @ VM142:143
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ VM142:138
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ VM142:97
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ VM145:60
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
initVersion @ VM145:19
(anonymous) @ VM142:93
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ VM142:87
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ VM142:78
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
loadFiles @ VM142:55
(anonymous) @ index2.html:62
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
(anonymous) @ index2.html:57
When I remove the multigraph then everything works again.
clinkadink
Re: Unresponsive
Post by clinkadink »
EdwinK wrote: Saturday 15 February 2020 11:39 This is what I have (from the readthedocs instrcutions)
        graph: 'line',
        buttonsPadX: 10,
        buttonsPadY: 5,
        buttonsMarginX: 5,
        buttonsMarginY: 2,
        buttonsRadius: 0,
        buttonsSize: 12,
                custom : {
                        "Last hours": {
                                range: 'day',
                                filter: '6 hours',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
                        "Last 2 weeks": {
                                range: 'month',
                                filter: '14 days',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
                        "Last 6 months": {
                                range: 'year',
                                filter: '6 months',
                                data: {
                                        te1: 'd.te1',
                                        te2: 'd.te2',
        legend: {
                'te1': 'Outside',
                'te2': 'Inside',
setTimeout (async)
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
add @ bundle.js:53
then @ bundle.js:53
setInterval (async)
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
add @ bundle.js:53
then @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
l @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
l @ bundle.js:53
setTimeout (async)
fire @ bundle.js:53
fire @ bundle.js:53
fire @ bundle.js:53
done @ bundle.js:53
load (async)
send @ bundle.js:53
ajax @ bundle.js:53
Hi, I have just noticed that the readthedocs graph section for the latest beta needs updating.
https://dashticz.readthedocs.io/en/beta ... tom-graphs
The example multigraph should be updated as follows:
blocks['outside_inside_temp'] = {
        graph: 'line',
        buttonsPadX: 10,
        buttonsPadY: 5,
        buttonsMarginX: 5,
        buttonsMarginY: 2,
        buttonsRadius: 0,
        buttonsSize: 12,
                custom : {
                        "Last hours": {
                                range: 'day',
                                filter: '6 hours',
                                data: {
                                        te1: 'd.te_175',
                                        te2: 'd.te_376',
                                        delta: 'd.te_376-d.te_175'
                        "Last 2 weeks": {
                                range: 'month',
                                filter: '14 days',
                                data: {
                                        te1: 'd.te_175',
                                        te2: 'd.te_376',
                                        delta: 'd.te_376-d.te_175''
                        "Last 6 months": {
                                range: 'year',
                                filter: '6 months',
                                data: {
                                        te1: 'd.te_175',
                                        te2: 'd.te_376',
        legend: {
                'te_175': 'Outside',
                'te_376': 'Inside',
The was a significant change in the last beta that saw the graph block and the multigraph block merge. But also, the idx of each device within the graph are added to each of the keys displayed. e.g. te for device idx 100 would become te_100. In the example above (and below) you can see that the keys in the custom data now reference "key_idx". All existing graphs using custom data, drawOrder and legends, will need to be updated to this new format.
I posted an example block config (and graph) of these changes. Link below. Hope it makes sense ;)
https://www.domoticz.com/forum/viewtopi ... 20#p236733
EdwinK
Re: Unresponsive
Post by EdwinK »
going to take a look at it. :)
EdwinK
Re: Unresponsive
Post by EdwinK »
Now this gives a error in config.js. Time to do some troubleshooting.
EdwinK
Re: Unresponsive
Post by EdwinK »
This one works
blocks['multigraph_17'] = {
        title: 'CPU, Memory & HDD',
        devices: [ 491, 493, 495 ],
        datasetColors: ['Red', 'Orange', 'Blue', 'Green', 'LightBlue', 'Aqua', 'Yellow', 'Purple', 'Pink'],
        legend: true,
        cartesian : 'linear',
        graph: 'line',
        lineFill: true,
        drawOrderDay:   ['v_491', 'v_495', 'v_493'],
        drawOrderMonth: ['v_min_17', 'v_avg_17', 'v_min_18', 'v_max_17', 'v_avg_189', 'v_max_189', 'v_min_189', 'v_avg_18', 'v_max_18'],
        legend: {
                'v_491'          : 'CPU',
                'v_avg_491'       : 'CPU avg',
                'v_max_491'      : 'CPU max',
                'v_min_491'      : 'CPU min',
                'v_493'          : 'MEM',
                'v_avg_493'      : 'MEM avg',
                'v_max_493'      : 'MEM max',
                'v_min_493'      : 'MEM min',
                'v_495'         : 'HDD',
                'v_avg_495'     : 'HDD avg',
                'v_max_495'     : 'HDD max',
                'v_min_495'     : 'HDD min'
This one as well:
blocks['graph_1'] = {
    title: 'My Power',
    graph: ['line','bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v+d.v2-d.r1-d.r2',
                usage: 'd.v+d.v2',
                generation: '-d.r1-d.r2'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                usage: 'd.v+d.v2',
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
                usage: 'd.v+d.v2',
    legend: true,
    datasetColors:['blue','red','yellow']
Working, sort of..
Working, sort of..
Screen Shot 2020-02-16 at 22.46.51.png (334.19 KiB) Viewed 1645 times
clinkadink
Re: Unresponsive
I am glad you have got it working ;)
EdwinK
Re: Unresponsive
Post by EdwinK »
Those two in my previous post are working, but the outside_inside_temp one is still throwing errors.
For now I'm going to forget about it, and see if I can think about it some more tomorrow.
HansieNL
Re: Unresponsive
Post by HansieNL »
EdwinK wrote: Sunday 16 February 2020 22:46 Those two in my previous post are working, but the outside_inside_temp one is still throwing errors.
For latest betas there are some changes:
I suppose your device idx for your graph is 1.
You have to define your device and use the _idx fot the graph types in the custom section.
    title: 'My Power',
    devices: [1],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v_1+d.v2_1-d.r1_1-d.r2_1',
                usage: 'd.v_1+d.v2_1',
                generation: '-d.r1_1-d.r2_1'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
    legend: true,
Blah blah blah
clinkadink
Re: Unresponsive
See updates this weekend for the graph:
https://www.domoticz.com/forum/viewtopi ... 05#p237105
