Zigate Plugin version 4.7 Topic is solved
pipiche
Post by pipiche »
Version 4.7 of plugin is now out on the stable branch
A bunch of new stuff in from internals but also new devices as well as improvement of the Web Admin part
* Legrand Netatmo devices
* Schneider Wiser ( Partialy )
* Livolo Switch
* Konke
* Pluzzy Temp/Humi (with the specific firmware)
If you have installed plugin via git here is the procedure to upgrade
In case you are on 'betat', you need first to switch to 'stable' before starting the update
git checkout stable
Then you can do the update
git pull
Finally if you want to switch to 'beta
git checkout beta
Thanks a lot for those of you whom contribute via Paypal, so I have been and I'll continue to buy some devices and make it works on the plugin
Geitje
Re: Zigate Plugin version 4.7
Post by Geitje »
Thanks for updating the plugin. I'm slightly confused about updating. Right now i'm still on beta 4.6.062. I was about to update to the next release beta, and FW (FW now is still 31a).
About your post, if I want to update to 4.7, and then in future to the next beta's if they are released, do I first need to go back to stable? And then again switch to beta? Or can I just remain on beta and use git pull?
Also a brief question just as confirmation: after updating the FW of zigate, I do not need to re-pair devices I suppose?
Zwave, Zigate, RFlink etc.
pipiche
Post by pipiche »
As plugin is concerned
I suggest to do the following
git checkout stable
git pull
git checkout
git pull
In case you get git pull errors, then you need to follow a re-install ( https://github.com/pipiche38/Domoticz-Z ... install.md )
As the firmware is concerned
You can upgrade from 3.1a to 3.1c without loosing your devices. You MUST NOT erase EEPROM nor erase PDM.
Geitje
Post by Geitje »
I successfully followed those steps. No errors. Upgraded plugin from beta 4.6.062 to stable 4.7. For now I remain on stable.
I also succesfully flashed firmware to 3.1c, no issues, devices remained.
