Help Uninstalling Domoticz From Raspberry Pi Topic is solved
petecal
Post by petecal »
I just installed Domoticz on my Pi using:
"curl -L https....."
It has totally hung up my system.
I really need to uninstall it but I don't know how.
I am new to Pi, Linux, etc.
I have been using OpenHAB for home automation.
I was trying to get some z-wave devices to work on OpenHAB using an Aeotec USB stick.
I was having some difficulties so I went to the Aeotec site and that directed me to Domoticz.
I didn't know Domoticz was a HA system.
I am totally hung.
I can't deal with this now.
I have spent too much time trying to unravel this hole I have dug for myself.
Please tell me how to uninstall Domoticz.
Please.
Thank you so much.
Pete
sancla
Re: Help Uninstalling Domoticz From Raspberry Pi
Post by sancla »
Sounds like you need a beer...
How about a format and a clean setup, would that be an option?
Check these howto's: https://sancla.com
petecal
Post by petecal »
No way a clean install.
I have too much in this configuration.
Are you saying there is no way to uninstall Domoticz????
EddyG
Post by EddyG »
Do you still have ssh access to the Raspberry?
If so.
sudo systemctl stop domoticz.service
sudo systemctl disable domoticz.service
After that with positive result. Delete the complete domoticz dir in /home/pi/domoticz or otherwise where you installed it.
sudo rm /etc/init.d/domoticz.sh
sudo systemctl daemon-reload
After this system should work as before and domoticz removed.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
EddyG wrote: Sunday 09 February 2020 21:58 Do you still have ssh access to the Raspberry?
If so.
EddyG,
Does this include the /home/pi/domoticz/ folders also?
Greetings McMelloW
freijn
Domoticz version: Stable
Post by freijn »
McMelloW wrote: Monday 10 February 2020 16:33 Does this include the /home/pi/domoticz/ folders also?
first stop the service as mentioned already then
sudo rm -r /home/pi/domoticz
does the "trick"
McMelloW
Post by McMelloW »
freijn wrote: Monday 10 February 2020 16:42 first stop the service as mentioned already then
does the "trick"
Thanks, freijn. I thought I already missed the domoticz folders
Greetings McMelloW
petecal
Post by petecal »
EddyG,
Yep, that worked.
My Pi is blazing along like a Tesla.
Thank you so much!!!
Pete
