Plugwise Adam
Dr8072
Domoticz version: 4.10xxx
Re: Plugwise Adam
Post by Dr8072 »
Perfect.... Thanks....
That actually makes more sense
Right now I had a version that tried to update each separate device but It makes more sense if we are using zones ....
Based on this the plan now is:
I add a setpoint per zone so when I update a zone..... we can assume that the Adam will sort out which device needs to be updated
Then how about I change the setpoint for the lisa and Tom into a Desired temp and leave the actual temp and battery in place so you can see if the difference
That would match the app pretty well I Think.
would that work for you ?
ahattink
Domoticz version: Stable
Re: Plugwise Adam
Post by ahattink »
I think that would work perfectly!
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
This will require a bit of rewrite as it changes to plugin from thermostat focused to zone focused.
it may take me a bit longer, as I need to keep the functionality for the Anna intact but I'm working on it
akatar
Re: Plugwise Adam
Post by akatar »
Dr8072 wrote: Tuesday 19 February 2019 14:50 This will require a bit of rewrite as it changes to plugin from thermostat focused to zone focused.
Perhaps a stupid question, but, why is there need to keep the anna intact? why not 2 plugins (1 for adam, 1 for anna)
people use the anna OR the adam, it makes no sense to use the anna if you have a adam (i guess)
akatar
Re: Plugwise Adam
Post by akatar »
Dr8072 wrote: Friday 15 February 2019 9:20
Keep in mind... I cannot physical test the Adam part as I do not have physical access to one
If you need access, i can give you acces to mine, but i have only 1 adam and 1 lisa
you can Always contact plugwise for a test set, they are mostly willing to help creating a plugin.
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
@Akatar,
The reason for keeping the Anna system in place is because from Domoticz point of view its a Plugwise system, it doesn't matter that if you have an Anna, Adam, Smile, Tom, Lisa or floor
They are handled all in the same way so its a bit overkill to have two plugins that almost do the same thing
Even the current Anna basically works like a zone system. It just has a single zone... i.e the living room
akatar
Re: Plugwise Adam
Post by akatar »
Dr8072 wrote: Monday 25 February 2019 16:34 @Akatar,
Even the current basically Anna works like a zone system. It just has a single zone... i.e the living room
ok, can i ask you to add the water pressure to the plugin? it's nice to see if i have to refill it or not?
<point_log id="0f2f09edf21646f2813790ddbe67f085">
<updated_date>2019-02-25T16:26:06.109+01:00</updated_date>
<type>central_heater_water_pressure</type>
<unit>bar</unit>
<last_consecutive_log_date>2019-02-25T16:26:06.108+01:00</last_consecutive_log_date>
<period end_date="2019-02-25T16:26:06.109+01:00" start_date="2019-02-25T16:26:06.109+01:00">
<measurement log_date="2019-02-25T16:26:06.109+01:00">1.20</measurement>
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
Yeah I saw that one too in the XML from the Adam I'm using . Its in my test version already, you will get a pressure sensor but only if your CV reports it back to the Plugwise system.
I still have an older CV, and it not reporting it back, So I have to do the manual walk to check it. But if the gateway has it it will report it and you put your automation around it.
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
Doing last bit of testing... first release will go out soon
tcviper
Re: Plugwise Adam
Post by tcviper »
Will the plugwise domoticz plugin also work for Smile P1? :) Would love to see that added.
akatar
Re: Plugwise Adam
Post by akatar »
Dr8072 wrote: Tuesday 26 February 2019 23:25 Doing last bit of testing... first release will go out soon
Any idea when? :)
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
Apologies. Real life got in the way... Changed jobs etc.. so. Coding for fun took a back seat, hoping to find some time soon
akatar
Re: Plugwise Adam
Post by akatar »
no problem, take you're time :)
ahattink
Re: Plugwise Adam
Post by ahattink »
hi Dr8072,
Did you find some time to code?
Arthur
djreesing
Domoticz version: stable
Re: Plugwise Adam
Post by djreesing »
Hi there, what is the status of the Adam integration? Looking into buying one so I would like to know if it already works with Domoticz.
schj
Re: Plugwise Adam
Post by schj »
Dr8072 wrote: Wednesday 27 March 2019 12:00 Apologies. Real life got in the way... Changed jobs etc.. so. Coding for fun took a back seat, hoping to find some time soon
Very interested in this also. Let me know if I can give a hand. Cheers -- Jaap
ahattink
Re: Plugwise Adam
Post by ahattink »
schj wrote: Wednesday 27 November 2019 11:37
Dr8072 has not been seen on this forum for months now, so i don't think there is any progress. Someone else who can further develop this?
eddieb
Re: Plugwise Adam
Post by eddieb »
Is there any development on the Plugwise Smile / Anna / Adam plugin ?
I got 3.1.11 firmware and there seems to be a couple of options availiable that would be nice to have
Eddie
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
gerben
Domoticz version: 2021.1
Re: Plugwise Adam
Post by gerben »
Any progress in this item. It would be nice to be able to integrate the Adam device with all its linked valves and temperature sensors.
Gerben
Dr8072
Re: Plugwise Adam
Post by Dr8072 »
Apologies to all who have been following this topic. I started to extend the Anna plugin for the ADAM, however as stated before, life got in the way and haven't had the change to do private coding until now.
I fear i have to start again if i would pick this up again completely from scratch as the repository i used for this has been corrupted - read hard disk crash.
I'm focusing on bug fixing the base Anna plugin for now.
