Hi!
i have enabled OTA in the zigate menu, i can now see in domoticz log that there are several update for my trådfri devices, but how do i perform this update?
is it possible to update these devices from domoticz or from the zigate webbpage?
Zigate and ota update?
Re: Zigate and ota update?
If you have enabled OTA, then the plugin will present those Firmware to each applicable device and the update will be trigger if needed.
So you don't have to do any think, just leave the plugin doing its work.
Then after a day , you can disable OTA
tjabas
ok, that sound good, and i have also enabled the : "allow battery powered devices OTA", is this a must?
i also noticed this : "allowAutoPairing" , i sometimes looses the connection of som devices, i then need to repair the devices, should this allowAutoPairing fix this issue so i dont need to repair the lost devices?
If you have allowAutoPairing it means that you have not the latest version of the beta branch and then this is an experimental parameter, and I do not recommand its usage.
