Luxaflex PowerView and Domoticz?
Awst6000
Post by Awst6000 »
I saw on the Luxaflex-website that there is something new: Luxaflex PowerView.
Can this be used with Domoticz/RFXcom?
Op de site staat vermeld:
Het PowerView™ Motorisation systeem is compatibel met de tablets en mobiele apparaten van Apple® iOS en Android™ om de mogelijkheden van een draadloos huis uit te breiden. Het is eveneens compatibel met de meeste domoticatechnologieën die vandaag de dag op de markt zijn.
Txs
Awst6000
Re: Luxaflex PowerView and Domoticz?
Post by Awst6000 »
I found the following info:
http://www.hunterdouglas.com/operating- ... ional-info
It seems that PowerView has it's own hub and can be combined with the Harmony Hub.
Awst6000
Post by Awst6000 »
Still nobody bought this?
Txs
TheSpanishInq
Post by TheSpanishInq »
They have a serial api. It's not exactly cheap, about €340,- extra for a motorized top/down screen and then you'll still need a remote and a hub. (serial works with hub). They use a proprietary protocol over 2.4Ghz for the old remotes. Could well be they use this for the new product too. Not sure if it interferes with your WiFi connection...
Bid to steep for our budget. :|
Domoticz on Debian AMD64 with Aeon Z-Stick. V2020.2 (build 12900)
ZME_RC2
Marcel
Post by Marcel »
The PowerView hub can be talked to through ip example: https://github.com/bradfitz/powerview/b ... werview.go
this is also described in their pages
With the addition of the PowerView Hub, window coverings with PowerView Motorization can be integrated into a home automation system via RS-232 serial input or IP (internet protocol) from many common systems.
Now the wait is for someone to implement! I will buy this set this year anyhow because I really like it!
rasper
Domoticz version: 2022.2
Post by rasper »
Anyone any luck with building/integrating powerview with Domoticz?
nitpicker
Post by nitpicker »
FireWizard
Post by FireWizard »
With this description https://github.com/drbrain/indigo-power ... w%20API.md
and some programming (script or node-red) it should be possible to connect to Domoticz.
Timothy
Domoticz version: 3.8153
Post by Timothy »
is anyone interested in developing a plugin for Luxaflex?
Cropper17
Post by Cropper17 »
I just stumbled upon your blog and wanted to say that I have really enjoyed reading your blog posts.
