On the remote host (the machine hosting the rtl_sdr) I have the device connected to rtl_tcp running on the default port of 1234. I have enabled the UFW rules for both IPv4 and IPv6.
In Domoticz, I've added the additional parameter to the RTL433 config of "-d rtl_tcp://host:1234" and Domoticz cannot connect to the host.
If I fire up rtl_433 from the commandline on the same host as Domotic, and pass the same parameter, it connects successfully to the host.
I noticed in the logs that the following is output, and I'm not sure if it's a quirk of how the log is output or if this is what is being passed to rtl_433:
2020-01-30 17:17:20.122 Status: Rtl433: Worker started... (Extra Arguments: -d rtl_tcphostname1234)When I was setting up the rtl_sdr yesterday, I managed to get Domoticz to connect via rtl_tcp when the device was running locally, but for some reason, it doesn't like connecting to a remote host (despite rtl_433 itself being happy).
I also installed rtl_mus (which is a Python script which allows multiple clients to connect to rtl_tcp). This runs on the same host as Domoticz and again it can connect to my remote rtl_tcp connection fine. If I then point Domoticz at this "proxy" it still won't connect, despite the "proxy" running on localhost.
Any help would be greatly appreciated.
