trigger GPIO for max 250mSec (remote press)
imdos
Domoticz version: 2023.2
Post by imdos »
I have 2 remotes which I want to control from my Pi3 with Domoticz.
The problem is that I need to simulate a press once instead of continous, to overcome strange behaviour.
Therefore I need a maximum trigger of 200 milliseconds approximately.
Is this possible with a Pi and what do I need to do?
I have tried it with python
pi@raspberrypi:~ $ cat GPIO-test.py
import RPi.GPIO as GPIO            # import RPi.GPIO module
from time import sleep             # lets us have a delay
GPIO.setmode(GPIO.BCM)             # choose BCM or BOARD
GPIO.setup(17, GPIO.OUT)           # set GPIO17 as an output
GPIO.output(17, 1)         # set GPIO17 to 1/GPIO.HIGH/True
sleep(0.2)                 # wait half a second
GPIO.output(17, 0)         # set GPIO17 to 0/GPIO.LOW/False
pi@raspberrypi:~ $ cat GPIO-testv3.py
#!/usr/bin/python3
import time
led = 17
GPIO.setup(led, GPIO.OUT)
endtime=time.time()+0.2 #200 milliseconds
GPIO.output(led, 0)
while (time.time()<endtime):
    GPIO.output(led, 1)
GPIO.output(led, 0)
But couldn't get it to work. The closest I got was to use dzVents.
I can do a switchoff after the amount of milliseconds (like this example: GPIOx.switchOff().afterSec(0.250) ), but am not able to turn it on for the right amount of time.
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
imdos
Re: trigger GPIO for max 250mSec (remote press)
Post by imdos »
Got the dzVents code solved. Now I have a new hurdle. Before Domoticz starts I have to set the GPIO pins to the correct mode.
When I change the behavior of the GPIO ports; the port is active / high and can't be changed instantly (after 200 milliseconds I can make a change). Even when I set it to low / off the LED (on the remote) continues to flash/blink for a while (like 5 seconds at least). Therefore while setting the GPIO outputs it is sending commands; which is not recommended.
Now I have to find out how to stop the LED from flashing/blinking when I enable the port. The code I use:
sudo echo 17 > /sys/class/gpio/export ;
sleep 0.2;
sudo echo out > /sys/class/gpio/gpio17/direction;
sleep 0.2;
sudo echo 0 > /sys/class/gpio/gpio17/value ;
gpio exports
Is there another sequence or setup I could use?
I tried both methods from the Wiki
I even tried to connect the 3.3V PIN after I have configured the GPIO ports; but as soon as the remote receives power from the Pi it starts to blink as well.
