compiling
alienkidmj12
compiling
Post by alienkidmj12 »
can someone assist, just been compiling latest domoticz for debian
i actually compiled 4.10717 from git hub, and turned out to be 4.9700 when you check the console
thanks
dave
Re: compiling
alienkidmj12 wrote: Thursday 23 January 2020 20:45 i actually compiled 4.10717 from git hub, and turned out to be 4.9700 when you check the console
Can you share in a bit more detail which steps you took to get the sources from github and to checkout the version you want to compile ?
alienkidmj12
Re: compiling
i downloaded from here
https://github.com/domoticz/domoticz/re ... ag/4.10717
when i compiled and ran the binary it reported different version
alienkidmj12
Re: compiling
also tried domoticz_v4.10658, that also appears to be v4.9700
im at a loss, no idea whats going on
alienkidmj12
Re: compiling
ah when i click on versions at the top it reports
Versioon 4.10717 (May 9th 2019)
even more confused now :(
new to this git business.
Re: compiling
alienkidmj12 wrote: Friday 24 January 2020 1:02 new to this git business.
To get the domoticz sources start with
target=<targetDirectory>  # enter relative or absolute path where you want to store your local copy
git clone https://github.com/domoticz/domoticz.git $target
Once you have that you can compile the version you want. Without other git commands it will compile latest beta. If you want another version do a git checkout of the version you need first. You can find versions / commits here here.
luan
Re: compiling
Post by luan »
waaren wrote: Friday 24 January 2020 6:46
I appreciate you.
keep it up
Burger king survey
alienkidmj12
Re: compiling
i only have cmake 3.13.4 in my debian 10 x64. apparently i need 3.14.0 to compile latest.
anyone know which is the latest which supports cmake 3.13.4, also what do i type to grab it,
thanks
dave
Re: compiling
alienkidmj12 wrote: Friday 24 January 2020 23:56 i only have cmake 3.13.4 in my debian 10 x64. apparently i need 3.14.0 to compile latest.
Can't you move to a later cmake ?
wget https://github.com/Kitware/CMake/releases/download/v3.16.2/cmake-3.16.2.tar.gz
tar -xzvf cmake-3.16.2.tar.gz
cd cmake-3.16.2
./bootstrap
./configure
make
sudo make install
