compiling
compiling
can someone assist, just been compiling latest domoticz for debian
i actually compiled 4.10717 from git hub, and turned out to be 4.9700 when you check the console
thanks
dave
thanks
dave
- waaren
Re: compiling
Can you share in a bit more detail which steps you took to get the sources from github and to checkout the version you want to compile ?alienkidmj12 wrote: ↑Thursday 23 January 2020 20:45 i actually compiled 4.10717 from git hub, and turned out to be 4.9700 when you check the console
Re: compiling
i downloaded from here
https://github.com/domoticz/domoticz/re ... ag/4.10717
when i compiled and ran the binary it reported different version
Re: compiling
also tried domoticz_v4.10658, that also appears to be v4.9700
im at a loss, no idea whats going on
Re: compiling
ah when i click on versions at the top it reports
Versioon 4.10717 (May 9th 2019)
even more confused now
new to this git business.
- waaren
Re: compiling
To get the domoticz sources start with
target=<targetDirectory> # enter relative or absolute path where you want to store your local copy
git clone https://github.com/domoticz/domoticz.git $target
Re: compiling
I appreciate you.waaren wrote: ↑Friday 24 January 2020 6:46To get the domoticz sources start withOnce you have that you can compile the version you want. Without other git commands it will compile latest beta. If you want another version do a git checkout of the version you need first. You can find versions / commits here here.Code: Select all
target=<targetDirectory> # enter relative or absolute path where you want to store your local copy git clone https://github.com/domoticz/domoticz.git $target
keep it up
Burger king survey
Re: compiling
i only have cmake 3.13.4 in my debian 10 x64. apparently i need 3.14.0 to compile latest.
anyone know which is the latest which supports cmake 3.13.4, also what do i type to grab it,
thanks
dave
thanks
dave
- waaren
Re: compiling
Can't you move to a later cmake ?alienkidmj12 wrote: ↑Friday 24 January 2020 23:56 i only have cmake 3.13.4 in my debian 10 x64. apparently i need 3.14.0 to compile latest.
wget https://github.com/Kitware/CMake/releases/download/v3.16.2/cmake-3.16.2.tar.gz
tar -xzvf cmake-3.16.2.tar.gz
cd cmake-3.16.2
./bootstrap
./configure
make
sudo make install
