Zigate - Do not upgrade to Firmware 3.1b Topic is solved
pipiche
Post by pipiche »
Do not upgrade to firmware 3.1b
This create issues for pairing devices and also for devices that you power off/on
If you done it alreday, do not downgrade
tjabas
Re: Zigate - Do not upgrade to Firmware 3.1b
Post by tjabas »
So you have the same problem, which version do you think is the most stable?
pipiche
Post by pipiche »
tjabas wrote: Tuesday 21 January 2020 17:55 So you have the same problem, which version do you think is the most stable?
It is not a question of stability. For some 3.1b will work perectly for some other they will have some strange behaviour while doing electrical power Off/On of devices
So for me my recommendation is do not upgrade to 3.1b. If you have already done, let see if you fall into the issues
Geitje
Post by Geitje »
Thanks for informing, I was about to upgrade!
Is it an idea to also inform about this problem on the Zigate firmware download page?
Zwave, Zigate, RFlink etc.
pipiche
Post by pipiche »
Firmware 3.1c has been released and solved the issue of 3.1b
tjabas
Post by tjabas »
Thanks for the information :)
tjabas
Post by tjabas »
Hmm, didnt see that new firmware, only 3.1b
pipiche
Post by pipiche »
tjabas wrote: Wednesday 22 January 2020 18:04 Hmm, didnt see that new firmware, only 3.1b
https://github.com/fairecasoimeme/ZiGat ... /tag/v3.1c
tjabas
Post by tjabas »
thanks, i looked in the wrong place :)
pfloryann
Domoticz version: 2026.3
Post by pfloryann »
after 3.1c update the status for offline devices does not change, he remain online in domoticz. The value "HaveTimeout" does not change. In domoticz log display:
2020-01-27 14:20:56.243 (Zigate) Receive an APS Nck from 3500, let's put the device in default/not reachable.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Post by pipiche »
pfloryann wrote: Monday 27 January 2020 13:22 Hi,
I don't understand the issue ; could you clarify ?
pfloryann
Post by pfloryann »
with old firmware version when a device became unavailable for some reason in domoticz it was displayed that the device is offline because it did not respond at poll. This occurs because the device "HaveTimeOut" parameter from domoticz changes its value from false to true and now remain always false even if the device is offline.
pipiche
Post by pipiche »
pfloryann wrote: Monday 27 January 2020 20:28 with old firmware version when a device became unavailable for some reason in domoticz it was displayed that the device is offline because it did not respond at poll. This occurs because the device "HaveTimeOut" parameter from domoticz changes its value from false to true and now remain always false even if the device is offline.
And that is still true and had nothing to do with the Firmware version
pfloryann
Post by pfloryann »
in this case can be from domoticz?
pipiche
Post by pipiche »
Please do provide logs with information from that I might help
pfloryann
Post by pfloryann »
For example i switch on my offline device(Bec Ikea Dormitor-is a bulb) from domoticz, the widget device is changing status to ON as if the command was sent with success. The same for switch off.
Zigate respond with message "(Zigate) Receive an APS Nck from 3500, let's put the device in default/not reachable" but domoticz do nothing for to put device in to offline.
2020-01-28 20:57:11.826 (Zigate) UpdateDevice - (Bec Ikea Dormitor) 1:On
2020-01-28 20:57:11.819 Status: User: florian initiated a switch command (98/Bec Ikea Dormitor/On)
2020-01-28 20:57:18.304 (Zigate) Receive an APS Nck from 3500, let's put the device in default/not reachable
2020-01-28 20:57:36.819 (Zigate) UpdateDevice - (Bec Ikea Dormitor) 0:Off
2020-01-28 20:57:36.770 Status: User: florian initiated a switch command (98/Bec Ikea Dormitor/Off)
2020-01-28 20:57:43.293 (Zigate) Receive an APS Nck from 3500, let's put the device in default/not reachable
pipiche
Post by pipiche »
Please update to the latest version of the Plugin
pfloryann
Post by pfloryann »
Yes after beta plugin update works, only on beta.
It was a problem between plugin and domoticz?
Thank you!
pipiche
Post by pipiche »
pfloryann wrote: Wednesday 29 January 2020 7:42 Yes after beta plugin update works, only on beta.
Thank you!
Problem was on plugin side
pfloryann
Post by pfloryann »
With last beta plugin and domoticz 411670 I think something is not working properly because some devices become offline after a few minutes after last use or last polling but not always and become online after a period but
these devices are always connected. I think it should go offline after a longer period of inactivity and only when not responding to polling.
Last edited by pfloryann on Sunday 02 February 2020 20:47, edited 1 time in total.
