Zigate and Aqara Relay power measurement? Topic is solved
pfloryann
- Domoticz version: 2026.2
I use Aqara wireless relay with Zigate and works fine but in Domoticz i have not seen power measurement from this relay(model LLKZMK11LM). I saw on some websites that this relay has the power measurement functionality . Is true or not and i want to know if this functionality will be added for Zigate and Domoticz. Thank you!
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: Zigate and Aqara Relay power measurement?
I don't known. I don't have such relay and cannot commennt on it.
If it is capable to provide power measurement then this is not a zigate related issue.
On beta branch of the plugin, could you please provide an export of Tools -> Devices raw (json) and attach it here
pfloryann
In my domoticz is simple switch on/off with 2 channels. But can you read on this site https://www.zigbee2mqtt.io/devices/LLKZMK11LM.html
I will attach devices raw this evening
as said, could you please provide me the export information of "f Tools -> Devices raw (json) and attach it here" ?
pfloryann
Yes, but i can't now because i'm away. When i get home i'll try to make this export.
no problem.
The issue is not about is it providing Consomption or not, the issue is to see how to get it.
Are you on the plugin beta branch ?
pfloryann
I'm not sure, i have to check. This option is only on beta branch?
The option to export yes, and at the same time I just pushed an update on beta, which might be enough to enable Power/Meter.
So if you want to test, make sure you are on the plugin beta branche
Then you need to remove the 2 switches (in domoticz) , and redo the pairing. From that you should get 3 widgets per line
- 1 switch
- 1 Power for Instant power
- 1 Meter for instant and / daily/weekly consomption
if it works
git pull
git checkout beta
git pull- 1 switch
if it works
pfloryann
Please check json
- export.rar
- (7.22 KiB) Downloaded 39 times
Ok.
So what I suggest is , if you want , do what I suggested above in order to test and dig into that.
Usally after the pairing you'll get 2 Power/Meters widgets one for each swicth. I however suspect that (as Xiaomi did for one of their switch), you'll get only the total on One.
pfloryann
Yes you're right, it's working now. In domoticz were created 2 switches and 2 power usage widgets, but only 1 power usage widget(ch1) is working and show live power for both switches.
This function is avaible only on the beta branch?
Thank you!
Thank you!
- Untitled-1.jpg (92.48 KiB) Viewed 1156 times
Correctn only available on beta branche, I'll update in order to have the Meter/POwer created only on the first channelpfloryann wrote: Friday 24 January 2020 13:28 Yes you're right, it's working now. In domoticz were created 2 switches and 2 power usage widgets, but only 1 power usage widget(ch1) is working and show live power for both switches.
Thank you!
