This looks amazing. Great stuff!!
- heggink
- Domoticz version: 12451
Re: machinon theme
Ho ho ho, merry ehrm domoticz
P1 meter & solar panel
- EdddieN
- Domoticz version: 4.9700
Re: machinon theme
Nice nice nice! so we are (hopefully) not on the naughty list then
11101101 - www.machinon.com
quirk
Re: machinon theme
I just added the feature in the beta branch to display wind direction instead of origin (using your reworked icons).lzwfkv wrote: Sunday 08 September 2019 10:10 I personally prefer the arrows to indicate the Wind source (where it comes from) when "arrows" icons are used for Wind.
For whom has my same preferences, it is simple to implement: just replace the "Wind*" icons in Machinon's images folder with the attached ones (same as the original ones with inverted arrow heads though, you can do them yourself if you dont like my changes):
Re: machinon theme
Ok, great. More than happy to contribute, though slightly...keep up the good work.quirk wrote:I just added the feature in the beta branch to display wind direction instead of origin (using your reworked icons).lzwfkv wrote: Sunday 08 September 2019 10:10 I personally prefer the arrows to indicate the Wind source (where it comes from) when "arrows" icons are used for Wind.
Inviato dal mio Redmi Note 3 utilizzando Tapatalk
- Freakandel
Re: machinon theme
I have moved from a RasPi to an Intel NUC due to continues trouble with stability and SD-card errors. I have managed to get the configuration working on the NUC, but the Machinon theme has a strange error: it does not display the Configuration tab (*settings) after activating the theme. Only mangling in the DB I can manage it back to a standard theme. Removing the entire Machinon folder under styles and reinstall from scratch is not helping. Where can it go wrong?
wokkelp
Re: machinon theme
I'm not sure if this has been mentioned before...
I'm running MacOS Catalina 10.15.2 with Safari 13.0.4 and I don't have a settings menu option.
I do have it when I go to domoticz in my Chrome browser (V 79.0.3945.88) on my Macbook Pro.
Is there a quick solution?
Edit* I also don't have a custom page option and I can't get rid of the "Domoticz" button which is not there in Chrome.
quirk
Re: machinon theme
Do you have any errors/warning in the browser console?
paulie72
Re: machinon theme
I have an master and slave domoticz.
in which the slave is running on an RPI and there the Machinon theme is working.
unfortunately it is not working on my Domoticz which is running in an iocage jail within Freenas.
During installation the directory www/styles was not yet there so i made them and installed in there.
I have tried the next items:
- Restarting my domoticz and also the jail
- Emptying cache in my chrome browser
- using the incognito browser of chrome
Where does it go wrong It looks so nice on my slave domoticz
If i check www/js on my system it is not there and on my slave domoticz it is there filed with files.
quirk
Re: machinon theme
Does it work with another theme?paulie72 wrote: Tuesday 14 January 2020 12:47 [...]
Re: machinon theme
I don't know if is machinon theme related, but i just add a second camera to my domoticz.
only the old one appear on the dashboard.
the new one appear as a camera switch but i can't see the image on the dashboard.
Did i miss something in the config ?
paulie72
Re: machinon theme
Yes it does.quirk wrote:Does it work with another theme?paulie72 wrote: Tuesday 14 January 2020 12:47 [...]
Sent from my VOG-L29 using Tapatalk
quirk
Re: machinon theme
Any error in the browser console (press F12 to display it and reload the page)?
artuuu
Re: machinon theme
Hello
I am looking for an open and closed window icon for the Mahinon theme in blue like the rest of the icons.
- felix63
- Domoticz version: 2020.1
Re: machinon theme
Installed update 1.14 today. Cleared cache but when selecting Machinon Settings Menu the whole Settings menu disappears. Anyone else seeing the same thing?
58djarviss
Re: machinon theme
Yep, got the same problem too ! Doesn’t seems to be related to the browser, same issue on Safari and Firefoxfelix63 wrote: Sunday 19 January 2020 19:55 Installed update 1.14 today. Cleared cache but when selecting Machinon Settings Menu the whole Settings menu disappears. Anyone else seeing the same thing?
Any Help ?
quirk
Re: machinon theme
I found some errors in Firefox and released a new bug fix version (1.14.1).
Can you check it?
Can you check it?
credenty
Re: machinon theme
Good Morning,
I have a problem with the display of the blinds.
I have tried several versions of this theme, both beta and master, worse still happening.
This defect only occurs on an iPad Pro, on the PC it looks correctly.
It has a resolution 2048 x 1536 pixels (264 dpi)
Any help would be appreciated.
Regards,
Regards,
- F4BEA29D-4B9F-459C-894A-B6A499BC7595.jpeg (305.92 KiB) Viewed 3756 times
quirk
Re: machinon theme
I reported the issue on github: https://github.com/EdddieN/machinon-dom ... issues/321
I'll take a look at it.
cmartens75
Re: machinon theme
I have an issue with the latest version of the Machinon theme (1.15). The button to open the sub menus of Domoticz (switches, temperature, weather, etc.) is not visible anymore. So it is not possible anymore to open the sub menus. Tested on Chrome and Safari. Domoticz has been restarted after the upgrade, cache has been cleaned. Please let me know how can this be solved.
Re: machinon theme
Same problem with me.cmartens75 wrote: Wednesday 29 January 2020 10:12 Hi,
