How to control thermostats in scenes!!
TiferMendos
Post by TiferMendos »
When I edit new scene I can add all nodes (switches, dimmers, door sensors), but no thermostats. How can I make a scene, which will control thermostats' setpoints?
For example "Away" scene, which would set all the thermostats' setpoints to one, low value?
At the moment I can only set plans for the thermostats.usps trackingshowbox
kimot
Domoticz version: v3.8153
Re: How to control thermostats in scenes!!
Post by kimot »
You can use DZVents script with scene trigger.
Or, if you are not familiar with DzVents scripting you can use Blockly with a little workaround.
Create your scene and use some dummy switch witch will be set ON in this scene.
Then in Blockly, when this switch is activated, set your setpoints to required value.
In other scenes set this switch OFF
I tested it - it works
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
