Problems with Pushover suddenly
Golleman
Post by Golleman »
My notifications scripts have been working fine until latest update (so I believe) to version 4.10717 (May 9th 2019). Testing pushover via settings gui works fine.
The following scripts failes with log entries
2020-01-11 23:17:39.283 Status: LUA: ~~~~~~ (script_device_trigger) -- EventUpdated by TEST_BUTTON state:On idx:166 at 23.17.39
2020-01-11 23:17:45.048 Notification sent (pushover) => Failed
2020-01-11 23:17:45.048 Error: Pushover:
2020-01-11 23:17:46.087 Notification sent (email) => Success
Script triggered by dummy switch:
if(devicechanged['TEST_BUTTON'])then
	commandArray[#commandArray + 1] = { SendNotification = 'subject#body#0###'}
However, if I remove the if clause, it works...
and I recieve the push notification. Note that the scripts above is only an error tracking effort. I have several scripts that uses the 'SendNotification' in a similar way and they fail. Usually in a if statement I set notifications like
if(globalvariables['Security']=='Armed Away')then
		commandArray['SendNotification']=Alarm ON' .. '#' .. 'Entire house#0'
		print('** alarm script: *Armed Away* -> ligth off')
and it fails now. Any ideas why and how to solve?
Raspberry Pi B+
rfxtrx433e
various Nexa dimmers/switches/outlets
KD101 smoke detctors
Anslut switches
RAR801 temp sensor
Golleman
Re: Problems with Pushover suddenly
Post by Golleman »
Created a new LUA script that contained a function that does the 'SendNotification' setter on the commandArray and that worked ONCE. Second and following executes failed. Something is not right with the request...
Temp solution was to create a bash script that curls the pushover api and call that from the function script. Not optimal, but will do for now.
Function script:
function SendNotification(commandArray, subject, body, priority, sound)
	if(priority == nil or priority == '')then
		priority = '0'
	if(sound == nil or sound == '')then
		sound = '0'
	print('##---> SendNotification script (email + pushover) with subject:' .. subject)
	commandArray[#commandArray + 1] = { SendNotification = subject .. '#' .. body .. '#' .. priority .. '#' .. sound .. '##email'}
	--os.execute ('/home/pi/domoticz/scripts/pushover.sh "Test" "Test message" "-1"')
	os.execute ('/home/pi/domoticz/scripts/pushover.sh "' .. subject .. '" "' .. body .. '" "' .. priority .. '" "' .. sound .. '"')
Raspberry Pi B+
rfxtrx433e
Anslut switches
RAR801 temp sensor
bewo
Domoticz version: 2021.1
Post by bewo »
Hi Golleman,
maybe there's a problem with the annotations or the hashtags, when they are empty...
I'll do a "normal" notification in this way - Which work's fine:
if devicechanged['TEST-Schalter'] == 'On' then
    commandArray['SendNotification'] = 'Titel#Hello, this is an test message!'
If you want to send an message with higher priority just add an #1 or #2 at the end, just before the closing ' .
The format with commandArray-Table which i use without problem's is:
   commandArray[#commandArray+1] = { ['SendNotification'] = 'Titel#Hello, this is an test message!' }
And if you wan't to use a function, for example to send the message only at one of your devices, this is an possibility (found the base for this here in the forum):
function Pushmessage(priority, title, message, device, sound)
   -- priority = -2,-1,0,1,2
   -- title = title of the message
   -- message = message you'll like to send
   -- device = The device which should receive the message. For example: All, Name1, Name2
   if device == 'All' or device == nil then device = ''
   elseif device == 'Name1' then device = 'Name-of-the-device1-at-the-Pushover-Account'
   elseif device == 'Name2' then device = 'Name-of-the-device2-at-the-Pushover-Account'
   -- sound = The sound you would like to hear; Find here: https://pushover.net/api#sounds
   if sound == nil then sound = '' end
   -- Pushover-Account:
   UserKey = '1234-find-in-Pushover'
   ApiToken = '1234-find-in-Pushover'
   -- Send the message:
   os.execute('curl --data "token='..ApiToken..'&user='..UserKey..'&title='..encodeURI(title)..'&message='..encodeURI(message)..'&priority='..tostring(priority)..'&sound='..sound..'&device='..device..'" https://api.pushover.net/1/messages.json')
   print('Send an push-message to: '..device)
In the pushover-function i use another function for encode the message as an uri, to prevent problems with special characters:
function encodeURI(str)
	if (str) then
		str = string.gsub (str, "\n", "\r\n")
		str = string.gsub (str, "([^%w ])",
			function (c) return string.format ("%%%02X", string.byte(c)) end)
		str = string.gsub (str, " ", "+")
	return str
With the function sending a message is done as follows:
	Pushmessage('0', 'Title', 'Hello, this is an test message!', 'All')
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
Golleman
Post by Golleman »
Hi bewo,
Thanks for the feedback. I've tried different constructs of the annotation, unfortunately with the same outcome.
However, my function using curl is similar to yours and that works for me too.
I'll continue some testing and will use your suggestion with the uri encoding as well (thanks), but as the
works once for a new script, then fails, I believe there is something else going on with my pi/domoticz setup. I will also try out the table construct and see if it behaves differently. Is there a way to get detailed logging for errors in the gui log?
Raspberry Pi B+
rfxtrx433e
Anslut switches
RAR801 temp sensor
