There is not change unit for barometer device at setting Topic is solved
poleg
- Domoticz version: 4.10717
I use Davis meteo station and get data from baro device. Domoticz shor baro at hPa. I check setting and dont see where i can change unit to mmHg.
- waaren
Re: There is not change unit for barometer device at setting
You can't. It is not even allowed by law in the Netherlands.poleg wrote: Tuesday 07 January 2020 15:08 I use Davis meteo station and get data from baro device. Domoticz shor baro at hPa. I check setting and dont see where i can change unit to mmHg.baro sensor from Davis.JPG
Google translated this for me in
The Netherlands: legal ban on the use of mmHg
Since the Calibration Act of 1978, the use of mmHg as a unit of pressure "in the practice of a profession or business when requesting, offering or supplying goods or services" has been prohibited in the Netherlands, except for the blood pressure and pressure of other body fluids. This prohibition is repeated in the Units Decree to the Calibration Act of 1981 and in the Metrology Act of 2006. Following an amendment of the Metrology Act, this prohibition was implicitly applicable to everyone from 1 January 2010. [3] With effect from 2016 this prohibition applies explicitly to 'everyone'. [4]
Using a script and a virtual custom sensor you can work around this quite easily
-- Conversion from hPa to mmHG
return
on =
devices =
31 -- change to "name" or idx of your barometer device
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
execute = function(dz, item)
_G.logMarker = _G.moduleLabel -- set logmarker to scrptname
hydrargyrum = dz.devices('Call me old fashioned') -- Change to name of your custom sensor (with x-as mmHG)
hydrargyrum.updateCustomSensor( dz.utils.round( item.barometer / 1.3322387415, 1 ))
}Debian buster, bullseye on RPI-4, Intel NUC.
MikeF
- Domoticz version: V2022.2
...or in UK use mb(ar): 1 hPa = 1 mb
poleg
i dont understand how i can add Dummy virtual sensor. At hardware type list i have Dummy (Does nothing, use for virtual switches only) only.
- Screenshot_106.png (85.29 KiB) Viewed 1457 times
poleg
if i add Dummy (Does nothing, use for virtual switches only) and add script at Setup-More Options-Events i see at Log:
2020-01-09 15:36:10.547 Status: dzVents: Info: Handling events for: "Temp Hum Baro", value: "18.2;44;1;985.8;3"
2020-01-09 15:36:10.547 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "Temp Hum Baro (Davis)", Index: 17
2020-01-09 15:36:10.547 Status: dzVents: Error (2.4.19): Method updateCustomSensor is not available for device "Temp Hum Baro" (deviceType=Temp + Humidity + Baro, deviceSubType=Weather Station). If you believe this is not correct, please report.
2020-01-09 15:36:10.547 Status: dzVents: Info: ------ Finished Script #1
my script:
my script:
- Spoiler: show
poleg
Answer how add Dummy virtual sensor at V4.10717:
1. Select Dummy (Does nothing, use for virtual switches only)
2. Click Create Virtual Sensor and select Sensor Type: Custom Sensor
poleg
my finish script:
I used correct value 6.3 for getting result as at my MeteoStation Davis...
return
on =
devices =
17 -- change to "name" or idx of your barometer device
logging =
hydrargyrum = dz.devices('Barometer') -- Change to name of your custom sensor (with x-as mmHG)
hydrargyrum.updateCustomSensor( dz.utils.round( item.barometer * 0.75006375541921 + 6.3, 1 ))
}- waaren
Good to see that you got it working !
- EdwinK
- Domoticz version: BETA
O wow.. We are good in banning some stuff, but not others.
