Floorplan suggestions
mirikbb
Post by mirikbb »
hello,
if possible and helprful for others too, I would be glad to see extended functionality of floorplan as follows:
- if multiple floorplans defined, in full screen mode automatically switch between them in user defined time e.g. each 5 seconds
- room area color change based on the sensor value. e.g. change between blue, yellow and red, based on the temperature sensor located in particular room. If the temperature is below 21° Celsius display room color as blue, if 21-24 as yellow, if above 24 degrees then display as red.
OR use only one color but in different shades (light blue, blue, dark blue)
Many thanx for consideration.
Users browsing this forum: gmarchionni and 1 guest
