After years of using Domoticz on the Raspberry, I recently switched to a large piece of metal on which I now, among other things, running a virtualized machine for Domoticz.
I chose Debian 10 as operating system.
I followed the instructions on page: https://www.domoticz.com/wiki/Build_Dom ... rom_source
I ran the procedure twice (in case I made a mistake), but there is something missing, or I do something wrong. Anyhow, after compiling Domoticz I try to change directory to Domoticz, but this folder doesn't excist. Only "dev-domoticz" and the earlier compiled/installed "open-zwave-read-only".
Do I need to rename, or is something else going wrong?
thanks in advanced, Rene
Building from source [Debian 10]
- waaren
Re: Building from source [Debian 10]
The wiki for building domoticz does not contain the steps for copying the required files to the work directory.
files / directories (including subdirectories) you need are
drwxr-xr-x 1 pi pi 1446 Mar 6 2019 Config
-rwxr-xr-x 1 pi pi 14840844 May 9 2019 domoticz
-rw-r--r-- 1 pi pi 4427 Aug 29 2017 domoticz.sh
drwxr-xr-x 1 pi pi 60 Apr 2 2018 dzVents
-rw-r--r-- 1 pi pi 94045 May 9 2019 History.txt
-rw-r--r-- 1 pi pi 35147 Aug 29 2017 License.txt
drwxr-xr-x 1 pi pi 30 Aug 29 2017 plugins
drwxr-xr-x 1 pi pi 350 Mar 25 2019 scripts
-rw-r--r-- 1 pi pi 3414 Aug 29 2017 server_cert.pem
-rwxr-xr-x 1 pi pi 607 Jun 14 2018 updatebeta
-rwxr-xr-x 1 pi pi 624 Jun 14 2018 updaterelease
drwxr-xr-x 1 pi pi 270 Apr 27 2019 www
Thanks for the input. I have copied all the suggested files and folders.
Next I ran into a new problem. Something with libssl. Domoticz is looking for libssl.so.1.0.0 while Debian Buster comes with libssl1.1
On github I read that I need to change the makefile (CMakeList.txt) before make.
I will give it a try tomorrow.
