OpenWebNet developing..?
jumposr
Re: OpenWebNet developing..?
Post by jumposr »
spugna85 wrote: Thursday 29 August 2019 23:49 Hi, in the last beta version I added the possibility to manually add devices for sending custom commands to the bticino gateway.
This should at least partially allow for the integration of missing systems like Sound diffusion.
I added a short description here:
https://www.domoticz.com/wiki/MyHome_Op ... _Interface
If anyone can do some tests I would like to have some feedback.
Thanks.
Hello spugna, i can test it, but the page in the link is blank.
spugna85
Post by spugna85 »
unfortunately for some reason that I do not know has been canceled. perhaps by mistake. currently I do not have access yet to be able to write on the wiki, so it remained empty.
spugna85 wrote: Friday 13 December 2019 0:55 unfortunately for some reason that I do not know has been canceled. perhaps by mistake. currently I do not have access yet to be able to write on the wiki, so it remained empty.
This is probably done by a mass removal of spam during the spam attack a couple of weeks ago. Please ask @gizmocuz via PM on this forum howto get new account on the Wiki. Thanks
spugna85
Post by spugna85 »
I've already done it. I wrote several times but have not yet received an answer.
chaitali31
Post by chaitali31 »
Excellent thread..!!!
anders
Domoticz version: 2020.1
Post by anders »
With the new update of Domoticz (stable version 2020.1), I experience problems with my Bticino devices (hardware MyHome OpenWebNet with LAN interface). I have blinds and sunshades that are now always in state "Closed" now, no matter if I open or close them.
The switches still respond to Open and Close commands, however, the status remains always as "Closed". This is a problem since I cannot keep track on the status. In the previous stable release, when you push open, the status changed. The normal status of blinds where "Stopped", but at least I could keep track of opened and closed with a user variable. This is no longer possible.
Anyone else experience this problem? What could be wrong? I have also tried a complete fresh install of domoticz without restoring backup and the behavior is the same.
spugna85
Post by spugna85 »
I'm still using the previous stable version.
As soon as I have time I try to update.
I'll let you know ..
anders
Post by anders »
great, thanks a lot!
spugna85
Post by spugna85 »
Hi anders,
I found the problem and I think I have solved it.
If it is approved, the fix will be in the next beta version.
I could not test the blind percentages, can someone do it?
anders
Post by anders »
That was quick! Thanks a lot for your work and help.
spugna85
Post by spugna85 »
The wiki page has been restored, however it is still incomplete.
I will try to complete the descriptions as soon as possible.
I hope this is useful:
umibozu
Post by umibozu »
Hi all, i think there's a problem with some commands.
The #area in the light channel (1) is not properly managed, in fact dz implementation provides an implementation of area command (first number of WHERE) from 1 to 9 and NOT from zero (0) to 9.
I have some devices in zero area but the command sent by domoticz ( after switch automatic detection) lacks of AREA part in where section.
Custom command also Doesn't work : 0 area is not selectable... Start from one
I have opened an issue:
https://github.com/domoticz/domoticz/issues/4252
Inviato dal mio Mi 9T utilizzando Tapatalk
spugna85
Post by spugna85 »
Hi umibozu,
thank you for your report.
I answered you on github.
spugna85
Post by spugna85 »
@umibozu I sent you a pm
spugna85
Post by spugna85 »
I'm trying to solve the problem of area 0 with this: https://github.com/domoticz/domoticz/pull/4279.
Can anyone test as soon as it gets approved?
jumposr
Post by jumposr »
Hello, i have Version: 2020.2 (build 12461)
Until last April the setpoint of all sensors were working correctly. Now they don't work anymore. Here are some log
2020-10-17 14:53:52.672 Status: User: domoticz initiated a SetPoint command
2020-10-17 14:53:52.692 Status: COpenWebNetTCP: Command #4#-32763*#1401903##
2020-10-17 14:53:53.692 Status: COpenWebNetTCP: sent=#4#-32763*#1401903## received=*#*0##
2020-10-17 14:58:14.922 Status: User: domoticz initiated a SetPoint command
2020-10-17 14:58:14.938 Status: COpenWebNetTCP: Command #4#-32762*#1402003##
2020-10-17 14:58:15.938 Status: COpenWebNetTCP: sent=#4#-32762*#1402003## received=*#*0##
-32763 is strange!
Anyone have same error?
thank you
spugna85
Post by spugna85 »
Hi jumposr,
i have a PI with Version: 2020.2 (build 12055)
I have now tried to set 22.5 °C and this is what I get:
2020-10-18 21:13:27.136 Status: COpenWebNetTCP: Command *#4*#1*#14*0225*3##
2020-10-18 21:13:28.137 Status: COpenWebNetTCP: sent=*#4*#1*#14*0225*3## received=*#*1##
As soon as I can I try with the latest beta, maybe in the next few days ..
spugna85
Post by spugna85 »
On windows with version: 2020.2 (build 12485)
I get the same problem:
2020-10-18 21:41:35.438 Status: User: domoticz initiated a SetPoint command
2020-10-18 21:41:35.447 Status: COpenWebNetTCP: Command *#4*#-32767*#14*0225*3##
2020-10-18 21:41:36.454 Status: COpenWebNetTCP: sent=*#4*#-32767*#14*0225*3## received=*#*0##
-32767 it should be 1
spugna85
Post by spugna85 »
@jumposr
The latest fix (area 0 management) introduced this bug.
I created a pull request that fixes this problem: https://github.com/domoticz/domoticz/pull/4404
Please try again when this is approved and let me know.
fmal
Help identifying unknown device
Post by fmal »
I have an unknown device not used but always ON in my devices list. It's ID 1000A named LIGHT 0010.
Here are all the light devices, please could you help me addressing how to discover what is that? If I delete unused devices it reappears after a while.
Thank you!!!!
