Can't set temprature via bash script
All kinds of 'OS' scripts
xxLeoxx93
Post by xxLeoxx93 »
I'm trying to set the temprature of one dummy hardware temperature sensor.
Here's what I've so far:
echo $MEASURED
curl 'http://127.0.0.1:8080/json.htm?username=XXX&password=XXX&type=command&param=udevice&idx=175&nvalue=0&svalue=$MEASURED'
Result looks like this:
        "status" : "OK",
        "title" : "Update Device"
So as you can see my variable is filled corretly but the temperature is still 0 in domoticz (I've checked the IDX multiple times, it's correct and sensor type is Temp).
Any hints?
Re: Can't set temprature via bash script
xxLeoxx93 wrote: Tuesday 10 December 2019 13:39 I'm trying to set the temprature of one dummy hardware temperature sensor.
Any hints?
On my system no user/password is needed coming from my local network (as I defined it as such in [setup][settings][system] (Local Networks (no username/password):) but for other situations, the syntaxis is ( as described on this wiki page ) :
curl 'http://<username>:<password@>127.0.0.1:8080/json.htm?type=command&param=udevice&idx=175&nvalue=0&svalue=$MEASURED'
