After reading out the powergeneration out of the device in:
Add:PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
This resolved the problem for me.PowerGeneration=PowerGeneration:sub(0,-2)
I'm using the PHP version from @sinze and this no longer works for me either.sandeman684 wrote: Friday 15 November 2019 8:46 It seems GoodWe has (again) changed something but, at least for me, the script is no longer working. Instead of the JSON data, I now get the HTML of the login page. Anybody any ideas on how to fix this?
Same problem since wednesday 13 november 2:45sandeman684 wrote: Friday 15 November 2019 8:46 It seems GoodWe has (again) changed something but, at least for me, the script is no longer working. Instead of the JSON data, I now get the HTML of the login page. Anybody any ideas on how to fix this?
-- Created by Raymond Wiertz
-- DateTime: 2020-02-13
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
-- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
local UserName = ""
local Password = ""
local token = ""
local refresh_time = 180 -- secondens
local sensorSolarPanels = "solar panels" -- name of your
-- get login token
local loginCommand = string.format("curl --silent --output /dev/null --cookie-jar - -c cookie.txt -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
-- get data from site
local getDataCommand = string.format("curl -b cookie.txt -d 'str={\"api\":\"v1/PowerStation/GetMonitorDetailByPowerstationId\",\"param\":{\"powerStationId\":\"%s\"}}&s=v1/PowerStation/GetMonitorDetailByPowerstationId' 'https://www.semsportal.com//GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId'",token)
i=1
function isempty(s)
return s == nil or s == ''
function getExecuteCommand(command)
local f = assert(io.popen(command, 'r'))
s = assert(f:read('*a'))
f:close()
return s
function stripchars(str, chrs)
local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
return s
function getValue(value, searchString)
local response = ""
searchString = string.format("%q", searchString)
dummy, startPos = string.find(value, searchString )
if not(startPos == nil) then
dummy, endPos = string.find(value, ",", startPos)
response = string.sub(value, startPos, endPos-1)
response = string.gsub(response, ":", "")
response = string.gsub(response, "\"", "")
response = string.gsub(response, " ", "")
return response
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
difference = os.difftime (t1, t2)
return difference
function UpdateDevice(device, data)
idx = otherdevices_idx[device]
if (idx == nil) then
print('** Unknown device'..device)
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
i = i+1
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > refresh_time) then
getExecuteCommand(loginCommand)
local data = getExecuteCommand(getDataCommand)
--print(data)
if (isempty(data) == false) then
output_power = getValue(data, "output_power")
last_refresh_time = getValue(data, "last_refresh_time")
eDay = getValue(data, "eDay")
print("last_refresh_time :" .. last_refresh_time)
print("output_power :" .. output_power)
print("eDay :" .. eDay)
current = tonumber(stripchars(output_power, "kwhKWH"))
dayTotal = tonumber(eDay)*1000
UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
Thanks a lot.CrazyFrog wrote: Thursday 20 February 2020 22:51 sandeman684, supergroover, Rensticar, bldewit, sjoemie1985
hereby a new script.
hopefully the script will continue to work in the near future.
Have fun with it.
sandeman684 wrote: Saturday 22 February 2020 16:49Thanks a lot.CrazyFrog wrote: Thursday 20 February 2020 22:51 sandeman684, supergroover, Rensticar, bldewit, sjoemie1985
Have fun with it.
I had to add i=1 to get it working, but now it works fine.
I got an error at the following line:CrazyFrog wrote: Monday 24 February 2020 9:27why did you have to put this variable, the code does not use this variable?sandeman684 wrote: Saturday 22 February 2020 16:49 I had to add i=1 to get it working, but now it works fine.
Could you indicate where you have placed this declaration so that other users can take it over when referenced.
Thank you in advance for the information.
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}Code: Select all
i=1sandeman684 wrote: Monday 24 February 2020 9:50I got an error at the following line:CrazyFrog wrote: Monday 24 February 2020 9:27why did you have to put this variable, the code does not use this variable?sandeman684 wrote: Saturday 22 February 2020 16:49 I had to add i=1 to get it working, but now it works fine.
Thank you in advance for the information.Adding i=1 here:Code: Select all
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}solved this.Code: Select all
commandArray = {} i=1
PHP Fatal error: Uncaught Error: Call to undefined function curl_init() in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php:66
Stack trace:
#0 /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php(40): retrieve_goodwe_data('test')
#1 {main}
thrown in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php on line 66
Stack trace:
#1 {main}
thrown in /home/pi/domoticz/scripts/pass2php/goodwe-inverter.php on line 66/code]
just the be sure:
entering my username and password, is the actual Semsportal login, correct?
thnx in advance!
