Currently available weather station?
- Domoticz version: 3.8153
Is anyone aware of a currently available weather station that is compatible with rflink preferably one that ships to Australia
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
- Domoticz version: mixed
Re: Currently available weather station?
First check the extensive list of supported devices for RFLinkGateway
Yeah I've done that. But looking online I can't seem to find where any of them are available. I did like the acurite 5 in 1 a couple of years ago but I'm struggling to find them available
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
The survey might be lagging rel. to the actual development/configuration.
Therefore, reversely, ask the Stuntteam of RFLink whether they have an interface for the weather station which is interesting to you:
see also section Development under this URL.
- Domoticz version: 4.10717
"Asking if a device that is not on the supported device list could be supported is useless."Toulon7559 wrote: ↑Monday 02 December 2019 15:34 The survey might be lagging rel. to the actual development/configuration.
http://www.rflink.nl/blog2/
My hopes are on this https://github.com/merbanan/rtl_433
- Domoticz version: 2020.2
is there anything like this for wifi that works with domoticz?
would love to have a weatherstation but do not want to buy an rflink just for that.
RTL-SDR costs only $21.95 USD if you want to try it. https://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/snellejellep wrote: ↑Monday 02 December 2019 19:00 is there anything like this for wifi that works with domoticz?
With RTL-433 It can decode many signals like car tyre pressure and temperatures.
I have RFLink, RTL-SDR, Z-Wave stick and Zigate. RFLink is not worst one even the latest firmware is over two years old. Zigate and Zigbee is by far the most rubbish one. Even the hardware tends to break and website is only in French. What's that about? If one wants to control only lights Philips Hue hub, 38 €, is less expensive than Zigate, 49 €.
The device in was looking at was on the supported list.mpx2 wrote: ↑Monday 02 December 2019 18:54
Quite literally for any of the weather stations or multi sensor 5 in 1
I cannot find any product that is available on Australia
I didn't really want to start a debate or anything or look at different technologies... Was just hoping that someone who uses the same technology as I was using had recently purchased or investigated purchasing one that could point me in the right direction
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
@mpx2
My reference to http://www.rflink.nl/blog2/ was more aimed at another, earlier section:
If RFLInk is not filling the gap by wireless interface, perhaps the configuration with TE923-interface is suitable for Domoticz-interfacing of a PWS:
using an USB-interface between the Domoticz-processor and a counterpart in the PWS (usually a console).
Another USB-interface for Domoticz&Meteo also available for Davis Vantage PWS.
Unfortunately the implication is, that you already should buy/have both the RFLink and the PWS, running the risk that the combination will never work if the Stuntteam does not produce a driver in a next release of the firmware.Regarding support questions:
- If you have a device that is not on the supported device list and is also not working, make debug logs and mail that to us.
