zigate reporting doesn't work in lastest beta's
abroeders
Post by abroeders »
I experience that topology reports and energy level reports don't get generated in the latest beta's of the last days. At least not from 4.6.026 and later.
The status in the bottom bar stays busy:
Start at 25/11/2019 10:08:47
Rx/s : 2.76 Tx/s : 0.9 MaxLoad on Zigate : 10
Busy
Plugin version: 4.6.030
Firmware version: 031a
Sometimes it is briefly green, but changes to Busy again by itself.
When starting the plugin, i can see in the logs that a topology and energy report is requested. Pushing the scan button gives:
2019-11-25 17:25:15.185 (Zigate) Cannot start Network Topology as one is in the pipe
2019-11-25 17:25:18.408 (Zigate) a Scan is already in progress
pipiche
Re: zigate reporting doesn't work in lastest beta's
Post by pipiche »
Please profile the full logs since the plugin start, to understand the context and what's happen.
Wiki is available here.
Zigbee for Domoticz FAQ
abroeders
Post by abroeders »
i just rebooted and collected the logs. Status is now shown as Ready in the dashboard.
2019-11-25 22:08:03.513 Status: Domoticz V4.11488 (c)2012-2019 GizMoCuz
2019-11-25 22:08:03.513 Status: Build Hash: d43435328, Date: 2019-11-15 12:59:32
2019-11-25 22:08:03.513 Status: Startup Path: /home/arno/domoticz/
2019-11-25 22:08:03.526 Sunrise: 08:16:00 SunSet: 16:41:00
2019-11-25 22:08:03.526 Day length: 08:25:00 Sun at south: 12:28:00
2019-11-25 22:08:03.526 Civil twilight start: 07:37:00 Civil twilight end: 17:19:00
2019-11-25 22:08:03.526 Nautical twilight start: 06:56:00 Nautical twilight end: 18:01:00
2019-11-25 22:08:03.526 Astronomical twilight start: 06:16:00 Astronomical twilight end: 18:40:00
2019-11-25 22:08:03.558 Status: PluginSystem: Started, Python version '3.6.8'.
2019-11-25 22:08:03.560 Active notification Subsystems: (0/13)
2019-11-25 22:08:03.560 Status: WebServer(HTTP) started on address: :: with port 80
2019-11-25 22:08:03.562 Status: WebServer(SSL) started on address: :: with port 443
2019-11-25 22:08:03.563 Starting shared server on: :::6144
2019-11-25 22:08:03.563 Status: RxQueue: queue worker started...
2019-11-25 22:08:03.563 Status: TCPServer: shared server started...
2019-11-25 22:08:05.563 Status: (Zigate) Started.
2019-11-25 22:08:05.564 Status: (Buienradar) Started.
2019-11-25 22:08:05.564 Status: XiaomiGateway (ID=5): Delaying worker startup...
2019-11-25 22:08:10.564 Status: XiaomiGateway (ID=5): Selected as main Gateway
2019-11-25 22:08:10.565 Status: XiaomiGateway (ID=5): Worker started...
2019-11-25 22:08:10.565 Status: XiaomiGateway (ID=5): Using 192.168.123.145 for local IP address.
2019-11-25 22:08:10.565 Status: EventSystem: reset all events...
2019-11-25 22:08:10.566 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Auto_Kitchencloset.lua
2019-11-25 22:08:10.566 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Auto_Technical_Room.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Shutter_Temperature_Hi.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Nightligh_Automatic_Hall.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Shutter_DayState.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Auto_Garage.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Automatic_Backyard.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Automatic_Frontdoor.lua
2019-11-25 22:08:10.567 Status: dzVents: Write file: /home/arno/domoticz/scripts/dzVents/generated_scripts/Light_Automatic_Driveway.lua
2019-11-25 22:08:10.567 Status: EventSystem: reset all device statuses...
2019-11-25 22:08:10.569 Status: XiaomiGateway: RGB Gateway Detected
2019-11-25 22:08:10.615 (Xiaomi Gateway) Color Switch (Nightlight Hall)
2019-11-25 22:08:10.649 Status: Python EventSystem: Initalizing event module.
2019-11-25 22:08:10.650 Status: EventSystem: Started
2019-11-25 22:08:10.650 Status: EventSystem: Queue thread started...
2019-11-25 22:08:11.024 (Xiaomi Gateway) Temp + Humidity (Xiaomi TempHum)
2019-11-25 22:08:11.025 (Xiaomi Gateway) Temp + Humidity (Xiaomi TempHum)
2019-11-25 22:08:11.032 Status: PluginSystem: Entering work loop.
2019-11-25 22:08:11.187 Status: (Zigate) Entering work loop.
2019-11-25 22:08:11.187 Status: (Zigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-11-25 22:08:11.467 Status: (Buienradar) Entering work loop.
2019-11-25 22:08:11.467 Status: (Buienradar) Initialized version 2.5.0, author 'ffes'
2019-11-25 22:08:11.470 Status: (Zigate) Zigate plugin beta-4.6.030 started
2019-11-25 22:08:11.470 Status: (Zigate) Debug: 0
2019-11-25 22:08:11.470 Status: (Zigate) Python Version - 3.6.8 (default, Oct 7 2019, 12:59:55)
[GCC 8.3.0]
2019-11-25 22:08:11.470 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-11-25 22:08:11.470 Status: (Zigate) DomoticzVersion: 4.11488
2019-11-25 22:08:11.470 Status: (Zigate) DomoticzHash: d43435328
2019-11-25 22:08:11.470 Status: (Zigate) DomoticzBuildTime: 2019-11-15 12:59:32
2019-11-25 22:08:11.470 Status: (Zigate) load PluginConf
2019-11-25 22:08:11.471 Status: (Zigate) enablegroupmanagement set to 1
2019-11-25 22:08:11.471 Status: (Zigate) enableReadAttributes set to 1
2019-11-25 22:08:11.471 Status: (Zigate) port set to 80
2019-11-25 22:08:11.471 Status: (Zigate) filename set to /home/arno/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2019-11-25 22:08:11.471 Status: (Zigate) pluginHome set to /home/arno/domoticz/plugins/Domoticz-Zigate/
2019-11-25 22:08:11.471 Status: (Zigate) homedirectory set to /home/arno/domoticz/plugins/Domoticz-Zigate/
2019-11-25 22:08:11.471 Status: (Zigate) pluginData set to /home/arno/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-25 22:08:11.471 Status: (Zigate) pluginConfig set to /home/arno/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-25 22:08:11.471 Status: (Zigate) pluginOTAFirmware set to /home/arno/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-25 22:08:11.471 Status: (Zigate) pluginReports set to /home/arno/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-25 22:08:11.471 Status: (Zigate) pluginWWW set to /home/arno/domoticz/plugins/Domoticz-Zigate/www/
2019-11-25 22:08:11.471 Status: (Zigate) numTopologyReports set to 25
2019-11-25 22:08:11.471 Status: (Zigate) numEnergyReports set to 25
2019-11-25 22:08:11.471 Status: (Zigate) Opening DomoticzDB in raw
2019-11-25 22:08:11.473 Status: (Zigate) Plugin Database: DeviceList-2.txt
2019-11-25 22:08:11.479 Status: (Zigate) DeviceConf loaded
2019-11-25 22:08:11.479 Status: (Zigate) load ListOfDevice
2019-11-25 22:08:11.515 Status: (Zigate) Entries loaded from /home/arno/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt : 24
2019-11-25 22:08:11.519 Status: (Zigate) Transport mode: Wifi
2019-11-25 22:08:11.519 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-11-25 22:08:11.519 Status: (Zigate) Connection open: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.123.140', Port: '9999', Baud: -1, Connected: False,
2019-11-25 22:08:12.206 Status: (Zigate) setTimeServer - Setting UTC Time to : 628034892
2019-11-25 22:08:12.206 Status: (Zigate) Request Disabling Accepting new Hardware
2019-11-25 22:08:12.206 Status: (Zigate) Trigger a Topology Scan
2019-11-25 22:08:12.206 Status: (Zigate) Trigger a Energy Level Scan
2019-11-25 22:08:12.257 Status: (Zigate) Major Version Num: 0003
2019-11-25 22:08:12.257 Status: (Zigate) Installer Version Number: 031a
2019-11-25 22:08:12.460 Status: (Zigate) Accepting new Hardware: Disable
2019-11-25 22:08:12.512 Status: (Zigate) Initialize Zigate Data Structure 0000 00158d0001ed40b0
2019-11-25 22:08:12.513 Status: (Zigate) Zigate addresses ieee: 00158d0001ed40b0 , short addr: 0000
2019-11-25 22:08:12.513 Status: (Zigate) Network state UP, PANID: 028b extPANID: 0x4a4a75c4bb5e342c Channel: 11
2019-11-25 22:08:12.567 Status: (Zigate) Number of devices recently active in Zigate = 13
2019-11-25 22:08:21.850 (Zigate) Switch Blue Led On
2019-11-25 22:08:21.850 Status: (Zigate) Zigate set to Certification : CE
2019-11-25 22:08:21.850 Status: (Zigate) Start Group Management
2019-11-25 22:08:21.851 Status: (Zigate) Start Web Server connection
2019-11-25 22:08:21.869 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-11-25 22:08:21.869 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-25 22:08:21.951 (Zigate) Group Management - Init phase
2019-11-25 22:08:21.951 Status: (Zigate) --------->No update of Groups needed
2019-11-25 22:08:22.053 Status: (Zigate) TxPower Attenuation : 0 dBm
2019-11-25 22:08:26.672 Status: (Zigate) Group: 43a6 - Zigate Group 43a6
2019-11-25 22:08:26.673 Status: (Zigate) - device: 35cc/01 90fd9ffffe1fc29d
2019-11-25 22:09:51.855 (Zigate) UpdateDevice - (Climate Outside) 0:8.0;88.6;3;1003.7;3
2019-11-25 22:09:51.859 (Zigate) UpdateDevice - ( Temp Outside) 0:8.0;88.6;3
2019-11-25 22:09:51.860 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d00025d90df-01) 8.0:8.0
2019-11-25 22:09:51.864 (Zigate) UpdateDevice - (Climate Outside) 0:8.0;88.5;3;1003.7;3
2019-11-25 22:09:51.865 (Zigate) UpdateDevice - ( Temp Outside) 0:8.0;88.5;3
2019-11-25 22:09:51.877 (Zigate) UpdateDevice - (Climate Livingroom) 0:20.8;51.6;1;1005.8;3
2019-11-25 22:09:51.878 (Zigate) UpdateDevice - (Temp Livingroom) 0:20.8;51.6;1
2019-11-25 22:09:51.880 (Zigate) UpdateDevice - (Climate Livingroom) 0:20.8;51.6;1;1005.0;3
2019-11-25 22:09:51.886 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002e98fb9-01) 0:1005.0;3
2019-11-25 22:09:51.888 (Zigate) UpdateDevice - (Climate Livingroom) 0:20.8;51.6;1;1005.5;3
2019-11-25 22:09:51.897 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002e98fb9-01) 0:1005.5;3
2019-11-25 22:09:51.899 (Zigate) UpdateDevice - (Climate Outside) 0:8.0;88.5;3;1003.0;3
2019-11-25 22:09:51.906 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025d90df-01) 0:1003.0;3
2019-11-25 22:09:51.906 (Zigate) UpdateDevice - (Climate Outside) 0:8.0;88.5;3;1003.3;3
2019-11-25 22:09:51.907 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025d90df-01) 0:1003.3;3
abroeders
Post by abroeders »
This wasn't in the previous logfile. It happens on regular basis; see the bold lines.
2019-11-25 22:10:11.676 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.6;59.6;1
2019-11-25 22:10:11.677 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d00025ee690-01) 18.6:18.6
2019-11-25 22:10:11.681 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.6;59.4;1;1004.1;3
2019-11-25 22:10:11.687 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.6;59.4;1
2019-11-25 22:10:11.694 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.6;59.4;1;1003.0;3
2019-11-25 22:10:11.708 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025ee690-01) 0:1003.0;3
2019-11-25 22:10:11.709 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.6;59.4;1;1003.7;3
2019-11-25 22:10:11.711 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025ee690-01) 0:1003.7;3
2019-11-25 22:10:32.063 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0100
2019-11-25 22:10:52.562 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:15.2;68.7;1;1004.1;3
2019-11-25 22:10:52.564 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f7c10e-01) 0:15.2;68.7;1
2019-11-25 22:10:52.566 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d0002f7c10e-01) 15.2:15.2
2019-11-25 22:10:52.569 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:15.2;68.6;1;1004.1;3
2019-11-25 22:10:52.571 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f7c10e-01) 0:15.2;68.6;1
2019-11-25 22:10:52.572 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:15.2;68.6;1;1003.0;3
2019-11-25 22:10:52.591 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f7c10e-01) 0:1003.0;3
2019-11-25 22:10:52.593 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:15.2;68.6;1;1003.9;3
2019-11-25 22:10:52.594 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f7c10e-01) 0:1003.9;3
2019-11-25 22:13:12.410 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-25 22:14:20.174 (Zigate) UpdateDevice - (Climate Technical Room) 0:32.5;25.7;2;1003.0;3
2019-11-25 22:14:20.182 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f873a1-01) 0:1003.0;3
2019-11-25 22:14:20.183 (Zigate) UpdateDevice - (Climate Technical Room) 0:32.5;25.7;2;1003.8;3
2019-11-25 22:14:20.184 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f873a1-01) 0:1003.8;3
2019-11-25 22:15:52.700 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0100
2019-11-25 22:17:23.107 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-25 22:19:53.759 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-25 22:20:23.849 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-25 22:20:53.761 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
it's always on two devices 1688 and eeb3
1688 - 0017880102a2baf5 - Philips Hue LWB010
eeb3 - 0017880102c425f6 - Philips Hue LWB010
Both bulbs are controllable from domoticz.
Edit: The status in the zigate dashboard is now on Busy again... From previous experience, this will stay for hours, eventually it will become green and Ready again. Reports are never generated.
Some more logs:
2019-11-25 22:21:48.647 (Zigate) readCluster - 0300 - 6684/01 unknown attribute: 4001 30 0001 02
2019-11-25 22:21:48.648 (Zigate) readCluster - 0300 - 6684/01 unknown attribute: 400a 19 0002 0010
2019-11-25 22:21:48.698 (Zigate) readCluster - 0300 - 6684/01 unknown attribute: 400d 21 0002 0172
2019-11-25 22:21:48.749 (Zigate) readCluster - 0300 - 6684/01 unknown attribute: 4010 21 0002 ffff
2019-11-25 22:21:48.749 (Zigate) readCluster - 0300 - 6684/01 unknown attribute: fffd 21 0002 0001
that is:
6684 - ccccccfffe33725b - TRADFRI bulb E27 WS opal 1000lm
pipiche
Post by pipiche »
Can you try to disable Polling, to see how it behaves ?
abroeders
Post by abroeders »
I just restarted the plugin with polling disabled.
The errors:
2019-11-26 17:25:16.413 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 17:31:56.545 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 17:34:16.727 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
reoccur.. I'll wait and see if the reports get generated and if any other errors occur.
Edit: the plugin switched to Busy again.. In the log nothing special.
abroeders
Post by abroeders »
Some errors occuring:
2019-11-26 18:39:10.831 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0100
2019-11-26 18:42:01.305 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
2019-11-26 18:47:14.714 (Zigate) UpdateDevice - (Climate Livingroom) 0:20.8;54.6;1;998.0;4
2019-11-26 18:47:14.717 (Zigate) UpdateDevice - (Temp Livingroom) 0:20.8;54.6;1
2019-11-26 18:47:14.717 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d0002e98fb9-01) 20.8:20.8
2019-11-26 18:47:14.718 (Zigate) UpdateDevice - (Climate Livingroom) 0:20.8;54.8;1;998.0;4
2019-11-26 18:47:14.719 (Zigate) UpdateDevice - (Temp Livingroom) 0:20.8;54.8;1
2019-11-26 18:49:59.546 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
2019-11-26 18:50:01.155 (Zigate) timedOutDevice unit Light Frontdoor nwkid: eeb3
2019-11-26 18:50:01.157 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Frontdoor (Light Frontdoor,eeb3,0017880102c425f6) not correctly transmited. ( e9, MAC - [e9] No acknowledgement received when expected )
2019-11-26 18:50:54.110 (Zigate) remove timeOutDevice unit Light Frontdoor
2019-11-26 18:52:35.546 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.7;3;996.7;4
2019-11-26 18:52:35.550 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f7c10e-01) 0:14.3;74.7;3
2019-11-26 18:52:35.552 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d0002f7c10e-01) 14.3:14.3
2019-11-26 18:52:35.556 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.5;3;996.7;4
2019-11-26 18:52:35.557 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f7c10e-01) 0:14.3;74.5;3
2019-11-26 18:52:35.567 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.5;3;996.0;4
2019-11-26 18:52:35.574 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f7c10e-01) 0:996.0;4
2019-11-26 18:52:35.576 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.5;3;996.3;4
2019-11-26 18:52:35.577 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f7c10e-01) 0:996.3;4
2019-11-26 18:53:09.693 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 18:53:39.528 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
2019-11-26 18:53:44.247 (Zigate) timedOutDevice unit Light Frontdoor nwkid: eeb3
2019-11-26 18:53:44.249 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Frontdoor (Light Frontdoor,eeb3,0017880102c425f6) not correctly transmited. ( e9, MAC - [e9] No acknowledgement received when expected )
2019-11-26 18:54:09.390 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0110
2019-11-26 18:54:09.850 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 18:54:33.261 (Zigate) UpdateDevice - (Climate Technical Room) 0:28.6;31.0;2;996.7;4
2019-11-26 18:54:33.264 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f873a1-01) 0:28.6;31.0;2
2019-11-26 18:54:33.265 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d0002f873a1-01) 28.6:28.6
2019-11-26 18:54:33.269 (Zigate) UpdateDevice - (Climate Technical Room) 0:28.6;31.4;2;996.7;4
2019-11-26 18:54:33.270 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f873a1-01) 0:28.6;31.4;2
2019-11-26 18:54:33.272 (Zigate) UpdateDevice - (Climate Technical Room) 0:28.6;31.4;2;996.0;4
2019-11-26 18:54:33.283 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f873a1-01) 0:996.0;4
2019-11-26 18:54:33.284 (Zigate) UpdateDevice - (Climate Technical Room) 0:28.6;31.4;2;996.3;4
2019-11-26 18:54:33.285 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f873a1-01) 0:996.3;4
2019-11-26 18:54:36.604 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.4;60.6;1;996.5;4
2019-11-26 18:54:36.607 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.4;60.6;1
2019-11-26 18:54:36.609 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d00025ee690-01) 18.4:18.4
After seeing the issues about Light Frontdoor I changed the dim-level from 1% to 100% and this went without any problem. See logs:
2019-11-26 18:55:39.404 (Zigate) _errorMgt - Give a chance of APS recovery for 4672/0017880102bc47d1 on command 0100
2019-11-26 18:55:59.868 (Zigate) remove timeOutDevice unit Light Frontdoor
2019-11-26 18:56:17.966 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.4;71.8;3;996.2;4
2019-11-26 18:56:17.970 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.4;71.8;3
2019-11-26 18:56:17.971 (Zigate) UpdateDevice - (Zigate - lumi.weather_Humi-00158d00025ee690-01) 71.8:3
2019-11-26 18:56:37.431 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.6;3;996.3;4
2019-11-26 18:56:37.433 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f7c10e-01) 0:14.3;74.6;3
2019-11-26 18:56:37.434 (Zigate) UpdateDevice - (Climate Master Bedroom) 0:14.3;74.6;3;996.4;4
2019-11-26 18:56:37.437 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f7c10e-01) 0:996.4;4
2019-11-26 18:56:47.796 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.5;71.8;3;996.2;4
2019-11-26 18:56:47.798 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.5;71.8;3
2019-11-26 18:56:47.799 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp-00158d00025ee690-01) 18.5:18.5
2019-11-26 18:56:47.799 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.5;73.3;3;996.2;4
2019-11-26 18:56:47.801 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.5;73.3;3
2019-11-26 18:56:47.802 (Zigate) UpdateDevice - (Zigate - lumi.weather_Humi-00158d00025ee690-01) 73.3:3
2019-11-26 18:57:00.066 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 18:58:59.187 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.5;77.9;3;996.2;4
2019-11-26 18:58:59.193 (Zigate) UpdateDevice - ( Temp Bathroom) 0:18.5;77.9;3
2019-11-26 18:58:59.193 (Zigate) UpdateDevice - (Zigate - lumi.weather_Humi-00158d00025ee690-01) 77.9:3
2019-11-26 18:58:59.194 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.5;77.9;3;996.0;4
2019-11-26 18:58:59.195 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025ee690-01) 0:996.0;4
2019-11-26 18:58:59.195 (Zigate) UpdateDevice - (Climate Bathroom) 0:18.5;77.9;3;996.2;4
2019-11-26 18:58:59.197 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00025ee690-01) 0:996.2;4
2019-11-26 19:00:55.472 (Zigate) UpdateDevice - (Light Frontdoor) 1:100
Same is happening to 'Light Garage outside':
2019-11-26 19:02:11.993 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0110
2019-11-26 19:02:12.296 (Zigate) timedOutDevice unit Light Garage outside nwkid: 1688
2019-11-26 19:02:12.300 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Garage Outside (Light Garage outside,1688,0017880102a2baf5) not correctly transmited. ( e9, MAC - [e9] No acknowledgement received when expected )
2019-11-26 19:02:32.158 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0100
2019-11-26 19:02:32.462 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0100
2019-11-26 19:04:08.882 (Zigate) UpdateDevice - (Light Garage outside) 1:100
2019-11-26 19:04:16.895 (Zigate) UpdateDevice - (Light Garage outside) 1:2
These lights are Philips Hue, maybe it's because they don't support reporting and polling is turned off?
Sidenote: I still don't have a topology or energy report. They used to be finished already.
abroeders
Post by abroeders »
I think maybe the next message is interresting:
2019-11-26 19:29:10.720 (Zigate) NwkScanResponse - Empty Queue, Receive infos from 0988
0988 is the following device and perfectly responding:
0988 - 000b57fffecb5b2c - TRADFRI bulb E27 WS opal 980lm
But still no topology or energy report :-(
pipiche
Post by pipiche »
From the numbers of APS messages it seems that you have some network interferences or something like that.
What Zigbee channel are you ? What Wifi Channel are you using ( on 2.4 Ghz)
abroeders
Post by abroeders »
Thank you for your assistance!
Wifi channel is set to 1, for zigbee I have the channel set to 0 (auto select). In the logs of domoticz I see channel 11 is used for zigate. Is zigbee only using 1 channel or is it using multiple channels side-by-side because I see in the old energy report chart the channels 11,15,19,20,25,26.
For me it is no issue to change Wifi channel or change/lock zigbee channels.
For now, should I transfer the WiFi to channel 13? Then I would use the other side of the spectrum. That would mean the least overlap with the channels described in the wiki https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md if i'm right.
Can interference have as effect that the reporting doesn't work anymore? I used to have energy reports of at least 5 routers with about 200 'energy units'.
I set WiFi to channel 13.. and restarted the plugin:
So, not even close to the channel 13. Let's see what it brings this night.
abroeders
Post by abroeders »
I still got the APS messages, so in addition to changing the WiFi to channel 13 I set the zigbee channel to 15 in the zigate-dashboard as this is a non-overlapping channel with Wifi.
After setting the channel to 15 and restarting I still saw:
Status: (Zigate) channel set to 15
So I checked in the Wifi UI of the Zigate esp-link (wifi version zigate) and tried to change the channel there in the Console menu. I couldn't change the channel in the textbox from 26 because of a disabled textbox, so I hit the Set Channel button to see if it would pop-up a set channel dialog. Instead it changed the channel in the ZiGate to 26. Now it seems although the channel is set to 15 in the zigate plug, the real channel that is in use is 26.
Effect: I lost connection to all my devices. Rebooting the zigate-wifi and domoticz doesn't change things back to the old channel, still channel 26. I don't know it will recover from this automatically, going to sleep now. See log:
2019-11-27 00:51:06.471 Status: (Zigate) Started.
2019-11-27 00:51:12.051 Status: (Zigate) Entering work loop.
2019-11-27 00:51:12.051 Status: (Zigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-11-27 00:51:12.413 Status: (Zigate) Zigate plugin beta-4.6.030 started
2019-11-27 00:51:12.413 Status: (Zigate) Debug: 0
2019-11-27 00:51:12.413 Status: (Zigate) Python Version - 3.6.8 (default, Oct 7 2019, 12:59:55)
2019-11-27 00:51:12.413 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-11-27 00:51:12.413 Status: (Zigate) DomoticzVersion: 4.11488
2019-11-27 00:51:12.413 Status: (Zigate) DomoticzHash: d43435328
2019-11-27 00:51:12.413 Status: (Zigate) DomoticzBuildTime: 2019-11-15 12:59:32
2019-11-27 00:51:12.413 Status: (Zigate) load PluginConf
2019-11-27 00:51:12.415 Status: (Zigate) enablegroupmanagement set to 1
2019-11-27 00:51:12.415 Status: (Zigate) port set to 80
2019-11-27 00:51:12.415 Status: (Zigate) channel set to 15
2019-11-27 00:51:12.415 Status: (Zigate) filename set to /home/arno/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2019-11-27 00:51:12.415 Status: (Zigate) pluginHome set to /home/arno/domoticz/plugins/Domoticz-Zigate/
2019-11-27 00:51:12.415 Status: (Zigate) homedirectory set to /home/arno/domoticz/plugins/Domoticz-Zigate/
2019-11-27 00:51:12.415 Status: (Zigate) pluginData set to /home/arno/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-27 00:51:12.415 Status: (Zigate) pluginConfig set to /home/arno/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-27 00:51:12.415 Status: (Zigate) pluginOTAFirmware set to /home/arno/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-27 00:51:12.415 Status: (Zigate) pluginReports set to /home/arno/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-27 00:51:12.415 Status: (Zigate) pluginWWW set to /home/arno/domoticz/plugins/Domoticz-Zigate/www/
2019-11-27 00:51:12.415 Status: (Zigate) numTopologyReports set to 25
2019-11-27 00:51:12.415 Status: (Zigate) numEnergyReports set to 25
2019-11-27 00:51:12.415 Status: (Zigate) Opening DomoticzDB in raw
2019-11-27 00:51:12.418 Status: (Zigate) Plugin Database: DeviceList-2.txt
2019-11-27 00:51:12.425 Status: (Zigate) DeviceConf loaded
2019-11-27 00:51:12.425 Status: (Zigate) load ListOfDevice
2019-11-27 00:51:12.483 Status: (Zigate) Entries loaded from /home/arno/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt : 24
2019-11-27 00:51:12.487 Status: (Zigate) Transport mode: Wifi
2019-11-27 00:51:12.487 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-11-27 00:51:12.487 Status: (Zigate) Connection open: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.123.140', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2019-11-27 00:51:13.274 Status: (Zigate) setTimeServer - Setting UTC Time to : 628131073
2019-11-27 00:51:13.275 Status: (Zigate) Request Disabling Accepting new Hardware
2019-11-27 00:51:13.275 Status: (Zigate) Trigger a Topology Scan
2019-11-27 00:51:13.275 Status: (Zigate) Trigger a Energy Level Scan
2019-11-27 00:51:13.377 Status: (Zigate) Major Version Num: 0003
2019-11-27 00:51:13.377 Status: (Zigate) Installer Version Number: 031a
2019-11-27 00:51:13.881 Status: (Zigate) Accepting new Hardware: Disable
2019-11-27 00:51:13.984 Status: (Zigate) Initialize Zigate Data Structure 0000 00158d0001ed40b0
2019-11-27 00:51:13.985 Status: (Zigate) Zigate addresses ieee: 00158d0001ed40b0 , short addr: 0000
2019-11-27 00:51:13.985 Status: (Zigate) Network state UP, PANID: 028b extPANID: 0x4a4a75c4bb5e342c Channel: 26
2019-11-27 00:51:14.189 Status: (Zigate) Number of devices recently active in Zigate = 5
2019-11-27 00:51:22.744 (Zigate) Switch Blue Led On
2019-11-27 00:51:22.853 (Zigate) Group Management - Init phase
2019-11-27 00:51:22.745 Status: (Zigate) Zigate set to Certification : CE
2019-11-27 00:51:22.745 Status: (Zigate) Start Group Management
2019-11-27 00:51:22.745 Status: (Zigate) Start Web Server connection
2019-11-27 00:51:22.768 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-11-27 00:51:22.768 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-27 00:51:22.853 Status: (Zigate) --------->No update of Groups needed
2019-11-27 00:51:23.614 (Zigate) _errorMgt - Give a chance of APS recovery for 0988/000b57fffecb5b2c on command 0100
2019-11-27 00:51:23.716 (Zigate) timedOutDevice unit Light Kitchencloset nwkid: 0988
2019-11-27 00:51:23.411 Status: (Zigate) TxPower Attenuation : 0 dBm
2019-11-27 00:51:23.724 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Kitchencloset (Light Kitchencloset,0988,000b57fffecb5b2c) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:23.927 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Kitchencloset (Light Kitchencloset,0988,000b57fffecb5b2c) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:27.597 Status: (Zigate) Group: 43a6 - Zigate Group 43a6
2019-11-27 00:51:27.597 Status: (Zigate) - device: 35cc/01 90fd9ffffe1fc29d
2019-11-27 00:51:33.606 (Zigate) _errorMgt - Give a chance of APS recovery for 0acc/000d6ffffee40143 on command 0100
2019-11-27 00:51:33.708 (Zigate) timedOutDevice unit Light Technical Room nwkid: 0acc
2019-11-27 00:51:33.818 (Zigate) _errorMgt - Give a chance of APS recovery for 6684/ccccccfffe33725b on command 0100
2019-11-27 00:51:33.715 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Technical Room (Light Technical Room,0acc,000d6ffffee40143) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:43.410 (Zigate) -- - Change PowerOn OnOff for device: 4672 from 1 -> 255
2019-11-27 00:51:43.616 (Zigate) _errorMgt - Give a chance of APS recovery for bd83/ccccccfffe56aeb1 on command 0100
2019-11-27 00:51:43.718 (Zigate) timedOutDevice unit Garage inside 1 nwkid: bd83
2019-11-27 00:51:43.726 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Garage inside 1 (Garage inside 1,bd83,ccccccfffe56aeb1) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:43.779 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Garage inside 1 (Garage inside 1,bd83,ccccccfffe56aeb1) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:44.133 (Zigate) _errorMgt - Give a chance of APS recovery for 4672/0017880102bc47d1 on command 0110
2019-11-27 00:51:53.514 (Zigate) -- - Change PowerOn OnOff for device: 4672 from 1 -> 255
2019-11-27 00:51:53.515 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 00:51:53.568 (Zigate) timedOutDevice unit Light Backdoor nwkid: 4672
2019-11-27 00:51:53.602 Error: (Zigate) APS Failure , Command: 0x0110:Write Attribute request for Light Backdoor (Light Backdoor,4672,0017880102bc47d1) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:58.592 (Zigate) _errorMgt - Give a chance of APS recovery for 1688/0017880102a2baf5 on command 0100
2019-11-27 00:51:58.694 (Zigate) timedOutDevice unit Light Garage outside nwkid: 1688
2019-11-27 00:51:58.697 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Garage Outside (Light Garage outside,1688,0017880102a2baf5) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:58.799 Error: (Zigate) APS Failure , Command: 0x0110:Write Attribute request for Light Garage Outside (Light Garage outside,1688,0017880102a2baf5) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:51:58.900 Error: (Zigate) APS Failure , Command: 0x0110:Write Attribute request for Light Garage Outside (Light Garage outside,1688,0017880102a2baf5) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:52:08.375 (Zigate) -- - Change PowerOn OnOff for device: eeb3 from 1 -> 255
2019-11-27 00:52:08.630 (Zigate) _errorMgt - Give a chance of APS recovery for eeb3/0017880102c425f6 on command 0110
2019-11-27 00:52:08.732 (Zigate) timedOutDevice unit Light Frontdoor nwkid: eeb3
2019-11-27 00:52:08.738 Error: (Zigate) APS Failure , Command: 0x0110:Write Attribute request for Light Frontdoor (Light Frontdoor,eeb3,0017880102c425f6) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:52:13.656 (Zigate) _errorMgt - Give a chance of APS recovery for 5a13/000b57fffeeb8756 on command 0100
2019-11-27 00:52:13.707 (Zigate) timedOutDevice unit Light Driveway nwkid: 5a13
2019-11-27 00:52:13.710 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Driveway (Light Driveway,5a13,000b57fffeeb8756) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:52:23.790 (Zigate) _errorMgt - Give a chance of APS recovery for 8c43/ccccccfffe504f07 on command 0100
2019-11-27 00:52:23.792 (Zigate) timedOutDevice unit Light Alex nwkid: 8c43
2019-11-27 00:52:23.795 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Alex (Light Alex,8c43,ccccccfffe504f07) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 00:52:23.898 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Light Alex (Light Alex,8c43,ccccccfffe504f07) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
abroeders
Post by abroeders »
after the latest loggings:
2019-11-27 01:05:09.447 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Colorlight Livingroom (Colorlight Livingroom,35cc,90fd9ffffe1fc29d) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 01:05:09.499 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Colorlight Livingroom (Colorlight Livingroom,35cc,90fd9ffffe1fc29d) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 01:06:34.647 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Garage inside 2 (Garage inside 2,6684,ccccccfffe33725b) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 01:06:34.699 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Garage inside 2 (Garage inside 2,6684,ccccccfffe33725b) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-11-27 01:06:34.801 Error: (Zigate) APS Failure , Command: 0x0100:Read Attribute request for Garage inside 2 (Garage inside 2,6684,ccccccfffe33725b) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
the zigate plugin seems to do nothing anymore. Ans as expected, all devices are unreachable.
Can you advise what to do/try? Or best to start all over?
pipiche
Post by pipiche »
Please do the following:
(1) Leave your Wifi on Wifi 2.4 Channel 11 or 13
(2) On Zigate
- Set the Channel back to 11 with Parameters settings
- do a Software Reset from the Web Admin GUI ( Admin sub-menu)
(3) After that some of the devices would reconnect, for those who are not able to re-join, put the Zigate/Plugin in Pairring mode and reset those devices
abroeders
Post by abroeders »
Great!
My network is online again, thank you for helping me out. Reports started working again, still strange to me that interference can hold up report generation.
Is there a way to migrate zigbee to another channel? I would like to try channel 15 because it has no overlapping WiFi channels. Maybe i can get rid of the occasionally APS messages.
Other question, for the first time ever i see:
2019-11-27 20:12:16.399 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:21.416 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:26.440 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:31.411 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:36.429 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:41.449 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:46.430 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:51.447 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
2019-11-27 20:12:56.416 (Zigate) -- - Change PowerOn OnOff for device: 1688 from 1 -> 255
For this device, my logfile is filling with this message. What does it mean? It is a LWB010 Philips Hue Bulb. The bulb is fully responsive.
pipiche
Post by pipiche »
Here are more information for the Wifi/Zigbee co-exesitence
You are on Beta, this message is linked to stuff that we are currently looking to implement on Beta.
abroeders
Post by abroeders »
Ok, thanks..
One last question. I understand the Coordiator automatically selects the most silent network channel.
Is there a way to force a change to a new channel. I would like to move my network channel to channel 15. I can think of only configuring channels 11,15... But how to initiate the change to this other channel. Make noise on channel 11 :lol: but how to do that.
Configurating only 15 and reprovision all the devices is my least preferred option.
pipiche
Post by pipiche »
If you want to move to a Channel;, then you have to specify the Channel you want to work on via the Settings and then you have do a Zigate Software reset (viad the plugin Admin menu).
After that the Zigate will be on Channel 15. and you will have to repair most of the devices, as only few of them (Heiman for instance) are able to switch automaticaly to the new channel.
