Hello all,
I just enabled a dummy hardware switch with the type RGBW color switch.
It controls a ledstrip with a tasmatified magichome controler.
Sofar things worked great.
193 Dummy switch hardware 00082193 1 Study ledstrip Color Switch RGBW
But from the switch panel, I can't figure out how to enable the white channel.
I can pick a color, and set the intensity. But this only adjusts the RGB values. The W value stays at 00.
In the Tasmota console it looks like this:
13:57:41 MQT: stat/magichome-4540/RESULT = {"POWER":"ON","Dimmer":75,"Color":"6038BF00","HSBColor":"258,71,75","Channel":[38,22,75,0]}
13:57:42 MQT: stat/magichome-4540/RESULT = {"POWER":"ON","Dimmer":100,"Color":"814BFF00","HSBColor":"258,71,100","Channel":[51,29,100,0]}
Am I missing something obvious in the control panel? Or is it really only setting the RGB values?
Any advice is welcome!
Kind regards,
Bert
RGBW switch question Topic is solved
brjhaverkamp
brjhaverkamp
Re: RGBW switch question
Ai, my mistake. I can switch on the white. but what I can't do is switch on a mix of the two. (that's why I missed it.)
I would like to set max ilumination with all leds blazing:-)
So if white is selected, also the rgb leds are lit with all equal value.
