lost wrote: Thursday 04 June 2020 17:26
You're correct: I used a connector for an optional radio module (maybe providing more range than the embedded one), if I remember correctly. Don't remember exactly which one, but this was the only 24V that was permanent even when the door was operating, checking with a multi-meter.
I must have a photo of this, will try to find it if needed.
Take care that after a few months, I had to add a pullup resistor (wired to the permanent 24V hereupper) on the Qubino input sensing door state to keep reliable open/close information...
Thanks for your reply. I installed my Qubino Flush 1D relay on my garage door control board during the weekend and I think I have it all working now. Below is a description of my installation (might be useful for others as well), let me know if there is something I should have done differently.
I would like to know what type of pullup resistor you installed and how you installed it (I don't have an electrotechnical background myself).
My installation steps of the Qubino Flush 1D relay on Hormann Promatic 3 garage door controller
Firstly some pictures of my current installation. I think I will replace the blue and brown wires with other colors later on.
Internal 24V power supply:
I used the power from the External radio receiver on the garage door control board. Below you can see the External radio receiver description from the Hormann manual, including a description of each connector:
Based in this, I connected the External radio receiver to the Qubino module as follows:
- Connector 5 BN/+24V -> Qubino N
- Connector 20 GN/0V -> Qubino L
Command signal
I already have an external impuls button mounted on the wall for opening and closing the garage door. The impuls button is connected to the garage door control board like this:
I connected the external impuls button connectors on the garage door control board to the Qubino module in parallel to my existing external impuls button as follows:
- Relay + connector -> Qubino Q input
- Relay - connector -> Qubino Q output
Door closed signal
Firstly I changed the DIL switch on the garage door control board to be able to receive the closed signal as described in the manual. I set switch B to ON:
I then used the Option relay PR 1 to connect the door closed signal to the Qubino module. In the Hormann manual Option relay PR 1 description:
Based in this, I connected Option relay PR 1 to the Qubino module as follows:
- Connector 0V --> Qubino I2
- Connector 24V --> Qubino N
Domoticz
After including the Qubino module in Domoticz I made some changes.
Configured the hardware parameters as follows:
Hardware parameter 11. had to be configured like this to make sure the relay is automatically turned off. Before I made this change my wall mounted external impuls button was not working anymore, this setting fixed that problem
The Qubino module added 4 devices in Domoticz, including the switch button and sensor:
I added this switch button to my Domoticz switches and set the Switch Type to Push On Button:
I added the sensor to my Domoticz switches and set the Switch Type to Door Contact:
