Looking for a wall device or remote for room temperature set
Could somebody please recommend me some device that i can put on the wall(or use as remote) to set temperature and send it to domoticz?
wifi or rfxcom(433mhz)? it will be also good if it will send current room temperature too.
later this data will be used to switch on/off air conditions and set different modes depending on conditions.
it should work local, without any api,clouds and without internet
it should be not expensive
thank you.
kirelam
- Domoticz version: 4.9700
Re: Looking for a wall device or remote for room temperature set
You could use a Xiaomi gateway, together with the wall humid en temp sensor.
https://nl.aliexpress.com/item/33015694 ... b201603_52
https://nl.aliexpress.com/item/32920731 ... b201603_52
You could also buy them in packages!
thanks, but i mean device to SET temperature, like thermostat
i will try to use this devices:
https://www.aliexpress.com/item/4000046 ... b201603_55
ropske
- Domoticz version: V3_8394
its used for floor heating i see? can you also use it then for no floor heating?
i will use it just like a remote to set a temperature, next this data will be send to domoticz to control aircoin unit in this room
