Zigate: wrong widget for Gledopto GL-C-009
ronaldbro
- Domoticz version: 2020.2
@pipiche,
Today I added a Gledopto GL-C-009 but it creates a wrong widget in Domoticz.
De widget which is created is a Color Switch - WW, but this device doesn't support white temperature. It's only a dimmer.
Re: Zigate: wrong widget for Gledopto GL-C-009
Could you kindly attach Data/DeviceList-xx.txt (after having stoppedthe plugin, in order to get Database flushed)
and let me know what is the IEEE of this device
ronaldbro
Sure, here it is.
The IEEE is 00124b001d43d2b3
Thanks for your help.
If you are on the 'beta' branch, please do a git pull (to retreive the last changes). Then restart the plugin, remove the existing wrong Gledopto GL-C-009 widget/device and then redo the pairing. It should create only a Level Control /Dim widget
Let me know if it works.
ronaldbro
Perfect like always
Thanks Pipiche
Thanks Pipiche
[SOLVED] Re: Zigate: wrong widget for Gledopto GL-C-009
djreesing
- Domoticz version: stable
I just paired a Gledopto GL-C-009 with Zigate. However, I noticed the widget was again the wrong RGWWW dimmer instead of just a normal dimmer switch. When I looked at the configuration files on github I noticed in the GL-C-009.json file the type was changed back to ColorControlRGBWW in the last stable update. When I use the old json with type LvlControl it works perfectly fine.
Why was this changed back to something that doesn't work? Are there maybe multiple versions of this GL-C-009? The one that I have is just a simple dimmer.
There is a reason, it has been reported by @ronaldbro tha GL-C-009 should be a RGBW. So it might happen that we have on the market 2 differents devices identified with teh same Model Name.
Could you kindly drop here an export.json file from the Plugin Device List RAW (json) ?
Thanks in advance
Thanks in advance
djreesing
Thanks for the quick reply, please find attached the requested export.
- export.json.txt
- (88.52 KiB) Downloaded 40 times
Seem to be a mistake on my end between GL-C-007 and GL-C-009.
Please kindly update to plugin
4.11.015 if you are on stable branch
4.12.108 if you are on beta branch
Unfortunately to get back the right Widget ( LvlControl) you'll have to remove the created widget and redo the pairing
djreesing
Thanks, just checked and it's working fine now!
