In global_data, how to call a helper function  [Solved]
mm148881
Domoticz version: 4.11499
Post by mm148881 »
I am new to dzvents, sorry if this is trivial, but I cannot find a way of calling a helper function B from another function A both defined in global_data.lua. Just to be concrete, here is the code I am trying to run.
return{
        helpers={
        mysplit=function(inputstr, sep)
            if sep == nil then
                sep = "%s"
            local t={}
            for str in string.gmatch(inputstr, "([^"..sep.."]+)") do
                table.insert(t, str)
            return t
        end,
        timeEqual=function(myTime)
            local Time = require('Time')
            local now= Time() -- current time
            local hour=now.hour
            local minute=now.min
            local Time0=mysplit(myTime,':')
            if(hour == tonumber(Time0[1]) and minute == tonumber(Time0[2]))then
                return true
                return false
       data = {
          temperatures = { history = true, maxItems = 10 },
          temp = { initial={},history = true, maxItems = 10 },
          T_0= {initial=24.0 }
In this specific case mysplit is not seen by timeEqual.
Thanks beforehand!
elmortero
Domoticz version: 3.9639
Re: In global_data, how to call a helper function
Post by elmortero »
domoticz.helpers.mysplit(inputstr, sep)
Re: In global_data, how to call a helper function  [Solved]
mm148881 wrote: Wednesday 13 November 2019 12:00 Hi,
A helper function calling another helper function also need to use domoticz.helpers.<helper function name> and therefore also need to have domoticz in the header.
Also data defined with history = true cannot have an initial value.
So it would become something like.
return
   data =
      temp = { history = true, maxItems = 10 },
      T_0 = { initial = 24.0 },
   helpers =
        mysplit = function(inputstr, sep)
            if sep == nil then
                sep = "%s"
            local t= {}
            return t
        end,
        timeEqual = function(myTime,dz)
            local now = Time() -- current time
            local hour = now.hour
            local minute = now.min
            local Time0 = dz.helpers.mysplit(myTime,':')
            if (hour == tonumber(Time0[1]) and minute == tonumber(Time0[2])) then
                return true
                return false
I don't know what you try to compare here but dzVents has a native function for comparing times. (see below example)
         function (time object).compare(other time obkect) returns a table with the following keys
         hours
         ms
         secs
         mins
         minutes
         milliseconds
         seconds
         compare (1 or -1) --past of future
         days
return
    on = { timer = { 'every minute' }},
    execute = function(dz)
        local myDevice = dz.devices(132)
        dz.utils.dumpTable(dz.time.compare(myDevice.lastUpdate))
mm148881
Post by mm148881 »
Thank you for the solution to the problem. I would have hoped that there was some object like self or this (which I tried) to reference to the global data.
Answering waaren's question, I am trying to compare only the hour and minutes of time, to trigger action on some device every day. Thus, I would give timeEqual a string like '18:30' for a given time of day to compare to the current time. I looked at the documentation, but as far as I understood comparison is between time objects, which include also days, months and years, which meant that I would have to create a time including those information on the current day and each day. I didn't find a way of using compare hours and minutes of time object, but I wouldn't be surprised that that is possible. I read the documentation quite rapidly, and also I don't really know lua as I have a C++, C and python background.
mm148881 wrote: Wednesday 13 November 2019 15:11 I am trying to compare only the hour and minutes of time, to trigger action on some device every day.
If I understand your intended functionality correctly these examples both do what you want.
solution 1
return
    on = { timer = { 'at 17:23' }},
        dz.log('it\'s now ' .. dz.time.rawTime)
solution 2
return
    on = { timer = { 'every minute' },
    devices = {' devicename' },
    	if dz.time.matchesRule('at 19:29') then
mm148881
Post by mm148881 »
Thanks for the great help! Solution 1 is for me the cleanest solution.
