RduPre wrote: Saturday 09 November 2019 11:34
I don't know what's relevant, so here is the whole file
I don't know either what is relevant but the differences between starting from the CLI and starting with /etc/init.d/domoticz.sh
user: domoticz.sh uses PI; CLI uses sudo
www: domoticz.sh uses port 8081; CLI uses 8080 (default)
slwww: domoticz.sh uses port 0 (disabled) ; CLI uses 443(default)
log : domoticz.sh use internal logging only ; CLI use logging to terminal
loglevel: domoticz.sh use none; CLI use normal,eventSystem
Maybe you can see what happens in more detail if you change
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
in /etc/init.d/domotizc.sh
to
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error,debug"
DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,eventsystem"
and then
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
sudo tail -100f /var/log/domoticz.log
dzVents wiki
