Python Plugin framework - HTTPS session
pipiche
Post by pipiche »
If I'm not mistaken, the HTTPS doesn't create an https schema
        if (Parameters["Mode1"] == "443"): self.sProtocol = "HTTPS"
        self.httpConn = Domoticz.Connection(Name=self.sProtocol+" Test", Transport="TCP/IP", Protocol=self.sProtocol, Address=Parameters["Address"], Port=Parameters["Mode1"])
        self.httpConn.Connect()
For instance when doing it, I can only connect via http:// schema while using https:// crash the plugin
Barberousse
Re: Python Plugin framework - HTTPS session
Post by Barberousse »
One of my plugin (https://github.com/guillaumezin/DomoticzLinky) manages to connect with https, it even manipulates cookies, what do you mean by "via https schema"? What address do you give? What is your exact error message? What are your OS, Python and SSL library versions?
Dnpwwo
Post by Dnpwwo »
You are going to need to supply a crash dump and a Python dump if possible by running from the command line and piping the output to a log.
pipiche
Post by pipiche »
I’m currently away. Will come back later end of the month
pipiche
Post by pipiche »
Barberousse wrote: Saturday 07 September 2019 21:12 One of my plugin (https://github.com/guillaumezin/DomoticzLinky) manages to connect with https, it even manipulates cookies, what do you mean by "via https schema"? What address do you give? What is your exact error message? What are your OS, Python and SSL library versions?
Ok, I'll investigate further, but mainly if I do https://my-domoticzip:9443 it failed, and some domoticz thread crashed, while if I do http://my-domoticzip:9443 it works
On the Server side (Domoticz) it is RPI running Fedora 30 distribution and a full re-compiled version of Domoticz beta.
On the Client side MacOS with Safari, Chrome or Firefox client
Will investigate next week and come back.
But if I look into your LinkyPlugin , if I'm not mistaken the plugin is not acting as a Web Server, but more as a Web Client towars the Enedis Webserver . In my case, the plugin implement a Web Server in order to handle Web request , and my feeling is in the Python Framework the HTTPS protocol is not implemented as such and so performed only as HTTP.
pipiche
Post by pipiche »
Dnpwwo wrote: Sunday 08 September 2019 8:07 You are going to need to supply a crash dump and a Python dump if possible by running from the command line and piping the output to a log.
Do you confirm that you have implemented the SSL part into the Python Framework when creating a WebServer ?
pipiche
Post by pipiche »
pipiche wrote: Wednesday 25 September 2019 14:56
@Dnpwwo, do you confirm that HTTPS is implemented in the python plugin Framework ? and we can use (server mode) ?
pipiche
Post by pipiche »
Please do take the HTTP Listener plugin and instead of listening on Protocol HTTP, just put HTTPS , you will see that the Python Framework simply crash
