Hello everyone!
I have installed the latest version of Domoticz on a raspberry pi4 running raspbian buster. I am having a problem scheduling changes in the temperature set of a z-wave Danfoss Popp radiator thermostat.
After setting up the hardware by including the thermostat, three devices show up: i) Thermostat Clock (type General, Thermostat), ii) Heating 1 (type Thermostat, SetPoint), iii) Temperature (type Temp, LaCrosse TX3). Item i) is weird as it gives me a time, which is 20-30 minutes less than the real time. Item iii) seems ok as it gives a reasonable room temerature. The problem is with item ii): If I impose the temperature manuall by clicking on the "edit" button, everything works, as the correct temperature is set on the thermostat. Otherwise if I try to schedule temperatures using the "Timers" button, the temperature on the thermostat does not change at all. For instance, I add an entry Type "On Time" at 18:20 Everyday, that does nothing to the thermostat. Am I doing anything wrong? Anything to be changed on the openzwave side? Where I can find an appropriate log file? The file /opt/domoticz/domoticz_crash.log contains nothing on my Danfoss thermostat.
Thanks beforehand for any help!
Max
Danfoss Radiator Thermostat scheduling temperatures does not work...
Re: Danfoss Radiator Thermostat scheduling temperatures does not work...
Sounds to me like a bug in Domoticz
- mm148881
- Domoticz version: 4.11499
Maybe it's a bug, I reinstalled the danfoss device (reset it and included it again) a few day afterward and now the Timers button seems to work.
