Aeotec Home Energy Meter Gen 5
McJohn
- Domoticz version: 2020.2
Re: Aeotec Home Energy Meter Gen 5
We use a "simple" HEM 1 with 1 fase.
But I think you are right.
See picture below from the manual.
- Screen Shot 2019-05-12 at 16.32.54.png (140.37 KiB) Viewed 3053 times
Nautilus
Thanks - saw the same on online documentation, but wanted to make sure that I've really understood it correctly. Too bad, makes the purchase much less intriguing for a non-electrician (it's 75€+ for even a 5 minute visit of an electrician). Does anyone know any similar devices with 3-phase measurement and a possibility to detect the direction (import/export)?
McJohn
There is a bug in Domotics for this Aeotec Home Energy Meter Gen 5:
When the power if off (no 230V anymore, also for the HEM!) it keeps displaying the last HEM update: ~230V, even if there is no power anymore...
We want to make a Blocky or LUA trigger when the power is available again (or gone) but that's impossible with this bad information.
JuanUil
- Domoticz version: 4.11083
Maybe a stupid question but where can I find the manufactuer_specific.xml file.
I can not find it on my pi
JuanUil
Done everything mentioned in this thread but I don't get it working.
Could somebody post the settings of all parameters for the HEM?
Thnx in advance
Jan
Thnx in advance
Jan
JuanUil
And an upload of the manufactuer-SPECIFIC.xml file would also help
JuanUil
So tried everything without result.
meter is not reporting every 5 seconds and also the readings look redicules.
in nighttime I have a negative usage.
Anay help?
Anay help?
JuanUil
nobody?
drogert
I got my home energy Gen 5 (one clamp) fitted and its reporting!
Only one thing is not working as espected. It can report the Voltage and Amps but without stetting the device to polling it just wont update the values
WITH polling it does update BUT. i get a timeout error in domotica
I dont mind this as its working, but it shouldnt be the right way i guess...
Anyone knows what i can do about this?
UPDATE
So by changing the group output settings to:
Group 1 reports to : 15
Group 2 reports to: 0
Group 3 reports to: 0
You can calculate what the HEM reports with this Excel sheet:
https://aeotec.freshdesk.com/helpdesk/a ... 6039852024
fixed the "polling" issue. It now reports all 4 values every 5 secs
2019-11-05 21:30:21.041 Status: OpenZWave: Received timeout notification from HomeID: 4118417576, NodeID: 2 (0x02)Anyone knows what i can do about this?
UPDATE
Last edited by drogert on Wednesday 06 November 2019 22:55, edited 2 times in total.
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
drogert
So ive been measuring it for one day now and found out: when checking the logs it says I did a total of 18KW in 24hrs. When i calculate this from the actual meter its around 13Kwh. When I look at the Device itself in the Node screen it has a total of 12Kwh. Which is closer to what its actually shown by the meter. Does anyone know why this is so different?
Update
When waking up this moring the Kwh log went from 18Kwh to -4Kwh...
Surely this must be a bug in domoticz?
Update
quasarius
How did you fix the polling? Or rather, fix so it reports every 5 seconds? Even with correct node settings I only get updates every 90 seconds in Domoticz.drogert wrote: Tuesday 05 November 2019 21:31
drogert
Well, using the excel sheet you can fill in what the HEM5 needs to report to group 1quasarius wrote: Wednesday 13 November 2019 23:06How did you fix the polling? Or rather, fix so it reports every 5 seconds? Even with correct node settings I only get updates every 90 seconds in Domoticz.drogert wrote: Tuesday 05 November 2019 21:31
in this case its 15
then below the these settings you can set the interval for group 1 at 5 secs
quasarius
I know, my issue is that the OZW control panel does show updates every 5 seconds, but whatever I do I can't get Domoticz to update the device values more often than every 90 seconds. Which means it doesn't trigger any events more often than every 90 seconds either.drogert wrote: Friday 22 November 2019 13:58Well, using the excel sheet you can fill in what the HEM5 needs to report to group 1quasarius wrote: Wednesday 13 November 2019 23:06How did you fix the polling? Or rather, fix so it reports every 5 seconds? Even with correct node settings I only get updates every 90 seconds in Domoticz.drogert wrote: Tuesday 05 November 2019 21:31
in this case its 15
dagger38
- Domoticz version: 3.8153
Darn.... can't even get the hem to include into domoticz???
How do you do that!
How do you do that!
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
