Zigate + Tradfri gu10 dual white added as RGBWW device
ronaldbro
Post by ronaldbro »
I added a few Tradfri GU10 warm white/cold white bulbs to my ZiGate but they are added as RGBWW device.
So Domoticz gives me the possibility to set RGB color or white temperature. Setting RGB of course does nothing.
Also the left and right button on the Tradfri remote don’t work. Probably because it tries to set a different color...
Is there a possibility to change the device to a turntable white device?
Regards Ronald
pipiche
Re: Zigate + Tradfri gu10 dual white added as RGBWW device
Post by pipiche »
Could you kindly provide the file Data/DeviceList-xx.txt where xx is the hardwareId of the plugin in domoticz?
As the remote it is expected behaviour . Check section 4.4 https://github.com/pipiche38/Domoticz-Z ... agement.md
And for Creating group you can do that via the Web admin page
ronaldbro
Post by ronaldbro »
Thanks for your help pipiche, I attached the DeviceList file.
I will check the remote page, thanks.
DeviceList-20.txt
(81.01 KiB) Downloaded 50 times
pipiche
Post by pipiche »
Is that TRADFRI bulb GU10 WS 400lm ? You have quiet a number ? All are indeed ColorControl RGB + WW.
You confirm they are only WW ?
ronaldbro
Post by ronaldbro »
Yep, that’s the bulb. Got 5 of them.
And yes, they are only WW. IKEA doesn’t have color GU10 bulbs, only single white and dual white. These are dual white.
pipiche
Post by pipiche »
Ok. I' gonna push an update on beta branch.
Unfortunately, you'll have to remove those and re-pair it in order that the right widget is used.
ronaldbro
Post by ronaldbro »
Ok, thanks. I’ll let you know how it turns out
pipiche
Post by pipiche »
Ok, let me know, and eventually I will retrofit it to the 'stable' branch
ronaldbro
Post by ronaldbro »
It works great, thanks. Now I only have the color temperature in the widget.
pipiche
[RESOLVED] Re: Zigate + Tradfri gu10 dual white added as RGBWW device
Post by pipiche »
Excellent. Thanks for your help and contribution.
ronaldbro
Post by ronaldbro »
I found another problem, although I’m not sure if it’s a problem in dzvents, domoticz or zigate...
When I send a setKelvin(xx) command from dzvents to change the color temp then the dim level also goes to 100%.
This worked fine yesterday with the lates stable of ZiGate and when the bulbs were set up as rgbww devices.
I’m using the latest beta at the moment.
pipiche
Post by pipiche »
If you switch back to stable do you still have the issue ? Or is that working correctly?
Do you have the same behaviour if doing it directly via Domoticz UI ?
If this happens on beta only could you enable debugWidget and debugCommand ( with web admin GUI).
ronaldbro
Post by ronaldbro »
When I switched back to stable it worked just fine.
Then switched to beta again and it's the same result. The level changes until it's 100%. I got some logging of my test. For this test I made a dzVents script triggered by a switch an the only thing it does is the command 'setKelvin(60)'. I did it a few times and the level changes 3 times and the third time is 100%. I started with 30%.
I tested multiple times and the dim level changes randomly, but every time it takes max 4 setKelvin commands until its on 100% and then it stays 100%.
Hope you can find something in the log.
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - {'0012': {'0055': 1}, '0000': {'0001': '9', 'ff01': {}}, '0006': {'0000': 1}, 'ClusterType': {'428': 'DButton_3'}}
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:21.581 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-28 21:45:21.582 (Zigate) UpdateDevice_v2 1:10:_{}:111_True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 21:45:21.582 (Zigate) UpdateDevice_v2 for : Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 RSSI = 5
2019-10-28 21:45:21.582 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 21:45:21.582 (Zigate) Update Values 1:10: 255:5 True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 21:45:21.796 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 21:45:21.797 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 21:45:21.797 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 21:45:21.797 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 21:45:21.798 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 21:45:21.798 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 21:45:21.798 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 21:45:21.798 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 21:45:21.798 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 21:45:21.822 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 21:45:24.257 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.258 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.261 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.262 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.314 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.315 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.316 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.370 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.371 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.373 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.376 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.481 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.485 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.490 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.493 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.597 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.598 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.601 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.603 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.604 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.708 (Zigate) Too early for a new update of LastSeen 987d
2019-10-28 21:45:24.709 (Zigate) Too early for a new update of LastSeen 987d
2019-10-28 21:45:24.709 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c273a - Device EP : 01 - Type : 0008 - Value : ba - Hue : - Attribute_ :
2019-10-28 21:45:24.709 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:24.710 (Zigate) MajDomoDevice - NWKID = 987d IEEE = 14b457fffe4c273a Unit = 424
2019-10-28 21:45:24.710 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '186'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373337523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'424': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:24.710 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:24.710 (Zigate) MajDomoDevice - NWKID: 987d SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 45
2019-10-28 21:45:24.711 (Zigate) UpdateDevice_v2 1:73:_{}:108_False (Woonkamer: Spot uitbouw 3)
2019-10-28 21:45:24.711 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 3 RSSI = 5
2019-10-28 21:45:24.711 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:73
2019-10-28 21:45:24.711 (Zigate) Update Values 1:73: 255:5 False (Woonkamer: Spot uitbouw 3)
2019-10-28 21:45:24.741 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.742 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:24.742 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c3e08 - Device EP : 01 - Type : 0008 - Value : ba - Hue : - Attribute_ :
2019-10-28 21:45:24.742 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:24.743 (Zigate) MajDomoDevice - NWKID = 9f16 IEEE = 14b457fffe4c3e08 Unit = 416
2019-10-28 21:45:24.743 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '186'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0006': '20190308', '000a': '4c454431373337523547553130', '0002': '98', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'416': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:24.743 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:24.743 (Zigate) MajDomoDevice - NWKID: 9f16 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 45
2019-10-28 21:45:24.743 (Zigate) UpdateDevice_v2 1:73:_{}:111_False (Woonkamer: Spot uitbouw 1)
2019-10-28 21:45:24.744 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 1 RSSI = 5
2019-10-28 21:45:24.744 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:73
2019-10-28 21:45:24.744 (Zigate) Update Values 1:73: 255:5 False (Woonkamer: Spot uitbouw 1)
2019-10-28 21:45:24.768 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 21:45:24.769 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - Device ID : 14b457fffe3dbe31 - Device EP : 01 - Type : 0008 - Value : ba - Hue : - Attribute_ :
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - NWKID = 3f96 IEEE = 14b457fffe3dbe31 Unit = 417
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '186'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373337523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'417': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:24.769 (Zigate) MajDomoDevice - NWKID: 3f96 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 45
2019-10-28 21:45:24.770 (Zigate) UpdateDevice_v2 1:73:_{}:93_False (Woonkamer: Spot uitbouw 2)
2019-10-28 21:45:24.770 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 2 RSSI = 4
2019-10-28 21:45:24.770 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:73
2019-10-28 21:45:24.770 (Zigate) Update Values 1:73: 255:4 False (Woonkamer: Spot uitbouw 2)
2019-10-28 21:45:24.787 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.788 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.790 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.793 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.795 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:24.847 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-28 21:45:24.847 (Zigate) MajDomoDevice - Device ID : 000d6ffffe8e9fb7 - Device EP : 01 - Type : 0008 - Value : ba - Hue : - Attribute_ :
2019-10-28 21:45:24.847 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:24.847 (Zigate) MajDomoDevice - NWKID = 4ecf IEEE = 000d6ffffe8e9fb7 Unit = 426
2019-10-28 21:45:24.848 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '186'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373339523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'426': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '329', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:24.848 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:24.848 (Zigate) MajDomoDevice - NWKID: 4ecf SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 45
2019-10-28 21:45:24.848 (Zigate) UpdateDevice_v2 1:73:_{}:84_False (Woonkamer: Spot uitbouw 5)
2019-10-28 21:45:24.848 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 5 RSSI = 4
2019-10-28 21:45:24.848 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:73
2019-10-28 21:45:24.848 (Zigate) Update Values 1:73: 255:4 False (Woonkamer: Spot uitbouw 5)
2019-10-28 21:45:24.032 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 21:45:24.033 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 21:45:24.033 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 21:45:24.034 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 21:45:24.034 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 21:45:24.034 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 21:45:24.034 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 21:45:24.034 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 21:45:24.034 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 21:45:24.070 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 21:45:26.673 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 21:45:26.674 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 21:45:26.674 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 21:45:26.674 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 21:45:26.675 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 21:45:26.675 (Zigate) MajDomoDevice - {'0012': {'0055': 1}, '0000': {'0001': '9', 'ff01': {}}, '0006': {'0000': 1}, 'ClusterType': {'428': 'DButton_3'}}
2019-10-28 21:45:26.675 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:26.675 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-28 21:45:26.675 (Zigate) UpdateDevice_v2 1:10:_{}:111_True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 21:45:26.675 (Zigate) UpdateDevice_v2 for : Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 RSSI = 5
2019-10-28 21:45:26.676 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 21:45:26.676 (Zigate) Update Values 1:10: 255:5 True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 21:45:26.901 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 21:45:26.903 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 21:45:26.903 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 21:45:26.928 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 21:45:27.515 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:100
2019-10-28 21:45:29.704 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:29.705 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:29.705 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c3e08 - Device EP : 01 - Type : 0008 - Value : fe - Hue : - Attribute_ :
2019-10-28 21:45:29.705 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:29.706 (Zigate) MajDomoDevice - NWKID = 9f16 IEEE = 14b457fffe4c3e08 Unit = 416
2019-10-28 21:45:29.706 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '254'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0006': '20190308', '000a': '4c454431373337523547553130', '0002': '98', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'416': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:29.706 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:29.707 (Zigate) MajDomoDevice - NWKID: 9f16 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 73
2019-10-28 21:45:29.707 (Zigate) UpdateDevice_v2 1:100:_{}:108_False (Woonkamer: Spot uitbouw 1)
2019-10-28 21:45:29.707 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 1 RSSI = 5
2019-10-28 21:45:29.707 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:100
2019-10-28 21:45:29.707 (Zigate) Update Values 1:100: 255:5 False (Woonkamer: Spot uitbouw 1)
2019-10-28 21:45:29.742 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-28 21:45:29.743 (Zigate) MajDomoDevice - Device ID : 000d6ffffe8e9fb7 - Device EP : 01 - Type : 0008 - Value : fe - Hue : - Attribute_ :
2019-10-28 21:45:29.743 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:29.743 (Zigate) MajDomoDevice - NWKID = 4ecf IEEE = 000d6ffffe8e9fb7 Unit = 426
2019-10-28 21:45:29.743 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '254'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373339523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'426': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '329', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:29.744 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:29.744 (Zigate) MajDomoDevice - NWKID: 4ecf SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 73
2019-10-28 21:45:29.744 (Zigate) UpdateDevice_v2 1:100:_{}:87_False (Woonkamer: Spot uitbouw 5)
2019-10-28 21:45:29.744 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 5 RSSI = 4
2019-10-28 21:45:29.744 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:100
2019-10-28 21:45:29.744 (Zigate) Update Values 1:100: 255:4 False (Woonkamer: Spot uitbouw 5)
2019-10-28 21:45:29.777 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 21:45:29.778 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 21:45:29.778 (Zigate) MajDomoDevice - Device ID : 14b457fffe3dbe31 - Device EP : 01 - Type : 0008 - Value : fe - Hue : - Attribute_ :
2019-10-28 21:45:29.778 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:29.779 (Zigate) MajDomoDevice - NWKID = 3f96 IEEE = 14b457fffe3dbe31 Unit = 417
2019-10-28 21:45:29.779 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '254'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373337523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'417': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:29.779 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:29.779 (Zigate) MajDomoDevice - NWKID: 3f96 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 73
2019-10-28 21:45:29.779 (Zigate) UpdateDevice_v2 1:100:_{}:93_False (Woonkamer: Spot uitbouw 2)
2019-10-28 21:45:29.780 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 2 RSSI = 4
2019-10-28 21:45:29.780 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:100
2019-10-28 21:45:29.780 (Zigate) Update Values 1:100: 255:4 False (Woonkamer: Spot uitbouw 2)
2019-10-28 21:45:29.813 (Zigate) Too early for a new update of LastSeen 987d
2019-10-28 21:45:29.814 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c273a - Device EP : 01 - Type : 0008 - Value : fe - Hue : - Attribute_ :
2019-10-28 21:45:29.814 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:29.814 (Zigate) MajDomoDevice - NWKID = 987d IEEE = 14b457fffe4c273a Unit = 424
2019-10-28 21:45:29.814 (Zigate) MajDomoDevice - {'0003': {}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, 'fc7c': {}, '0008': {'0000': '254'}, '0005': {}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '0019': {}, '0000': {'0003': '1', '000a': '4c454431373337523547553130', '0007': '1', '0006': '20190308', '0002': '98', '0005': 'TRADFRI bulb GU10 WS 400lm', '0000': '2', '0001': '32', '4000': '2.0.022', '0004': 'IKEA of Sweden'}, 'ClusterType': {'424': 'ColorControlWW'}, '0004': {}, '0300': {'0003': '30138', '0008': '2', '0007': '276', '0004': '26909', '4010': '65535'}}
2019-10-28 21:45:29.815 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:29.815 (Zigate) MajDomoDevice - NWKID: 987d SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 73
2019-10-28 21:45:29.815 (Zigate) UpdateDevice_v2 1:100:_{}:111_False (Woonkamer: Spot uitbouw 3)
2019-10-28 21:45:29.815 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 3 RSSI = 5
2019-10-28 21:45:29.815 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:100
2019-10-28 21:45:29.815 (Zigate) Update Values 1:100: 255:5 False (Woonkamer: Spot uitbouw 3)
2019-10-28 21:45:32.539 (Zigate) Ask Zigate Time
2019-10-28 21:45:32.580 (Zigate) mgtCommand called for Devices[80].Name: Keuken: Aanrechtverlichting SwitchType: 7 Command: Set Level Level: 1 Color:
2019-10-28 21:45:32.584 (Zigate) mgtCommand - NWKID = 0869
2019-10-28 21:45:32.585 (Zigate) mgtCommand : found Device : 403 in Ep 01 LvlControl
2019-10-28 21:45:32.585 (Zigate) mgtCommand - List of TypeName : ['LvlControl']
2019-10-28 21:45:32.585 (Zigate) mgtCommand - DeviceType : LvlControl
2019-10-28 21:45:32.585 (Zigate) mgtCommand : Found Ep 01 for Device 403 Cluster 0008
2019-10-28 21:45:32.585 (Zigate) EPout = 01
2019-10-28 21:45:32.585 (Zigate) mgtCommand : Set Level for Device: 0869 EPout: 01 Unit: 80 DeviceType: LvlControl Level: 1
2019-10-28 21:45:32.586 (Zigate) UpdateDevice_v2 1:1:_{}:72_False (Keuken: Aanrechtverlichting)
2019-10-28 21:45:32.586 (Zigate) UpdateDevice_v2 for : Keuken: Aanrechtverlichting RSSI = 3
2019-10-28 21:45:32.586 (Zigate) UpdateDevice - (Keuken: Aanrechtverlichting) 1:1
2019-10-28 21:45:32.587 (Zigate) Update Values 1:1: 255:3 False (Keuken: Aanrechtverlichting)
2019-10-28 21:45:32.683 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.684 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.687 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.688 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.690 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.691 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.796 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.797 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.800 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.801 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.805 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.806 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.809 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.914 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.918 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.920 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:32.921 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:33.024 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:33.026 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:33.029 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:33.032 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 21:45:33.136 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.137 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.139 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.142 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.245 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.248 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.253 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.256 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.360 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.361 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.367 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.368 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.372 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.373 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.480 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.481 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.484 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.485 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.490 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:33.495 (Zigate) Too early for a new update of LastSeen 9e2d
2019-10-28 21:45:35.703 (Zigate) Too early for a new update of LastSeen 0869
2019-10-28 21:45:35.704 (Zigate) Too early for a new update of LastSeen 0869
2019-10-28 21:45:35.705 (Zigate) MajDomoDevice - Device ID : 086bd7fffe1e23b4 - Device EP : 01 - Type : 0008 - Value : 03 - Hue : - Attribute_ :
2019-10-28 21:45:35.705 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:35.706 (Zigate) MajDomoDevice - NWKID = 0869 IEEE = 086bd7fffe1e23b4 Unit = 403
2019-10-28 21:45:35.706 (Zigate) MajDomoDevice - {'0003': {}, '0019': {}, '0020': {}, '0008': {'0000': '3'}, '0006': {'4003': '1', '4000': '01', '0000': '01', '4001': '0', '4002': '0'}, '1000': {}, '0005': {}, '0b05': {}, '0000': {'0003': '1', '0005': 'TRADFRI Driver 30W', '0007': '1', '0006': '20170529', '000a': '494350534843323433304555494c31', '0002': '87', '0000': '1', '0001': '17', '4000': '1.2.245', '0004': 'IKEA of Sweden'}, 'ClusterType': {'403': 'LvlControl'}, '0004': {}}
2019-10-28 21:45:35.706 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:35.706 (Zigate) MajDomoDevice - NWKID: 0869 SwitchType: 7, DeviceType: LvlControl, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 1
2019-10-28 21:45:35.707 (Zigate) --> LvlControl analogValue: -> 3
2019-10-28 21:45:35.707 (Zigate) ----> LvlControl sValue: -> 1
2019-10-28 21:45:35.707 (Zigate) --> LvlControl UpdateDevice: -> 1/1 SwitchType: 7
2019-10-28 21:45:35.707 (Zigate) UpdateDevice_v2 1:1:_{}:84_False (Keuken: Aanrechtverlichting)
2019-10-28 21:45:35.707 (Zigate) UpdateDevice_v2 for : Keuken: Aanrechtverlichting RSSI = 4
2019-10-28 21:45:37.688 (Zigate) OTA heartbeat - [721] Type: None out of 20 remaining Images, Device: None, out of ? remaining devices, upgradeInProgress: None
2019-10-28 21:45:46.715 (Zigate) Touch unit Woonkamer: Spot uitbouw 5 nwkid: 4ecf
2019-10-28 21:45:46.718 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-28 21:45:46.719 (Zigate) Too early for a new update of LastSeen 95cc
2019-10-28 21:45:46.720 (Zigate) Too early for a new update of LastSeen 95cc
2019-10-28 21:45:46.720 (Zigate) MajDomoDevice - Device ID : 000b57fffe907671 - Device EP : 01 - Type : 0008 - Value : 02 - Hue : - Attribute_ :
2019-10-28 21:45:46.720 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 21:45:46.720 (Zigate) MajDomoDevice - NWKID = 95cc IEEE = 000b57fffe907671 Unit = 253
2019-10-28 21:45:46.721 (Zigate) MajDomoDevice - {'0003': {}, '0008': {'0000': '2'}, '0b05': {}, '0006': {'0000': '01', '4003': '1', '4000': '01', '4001': '0', '4002': '0'}, '1000': {}, '0005': {}, 'Type': 'LvlControl', '0000': {'0003': '1', '0002': '87', '0001': '17', '0000': '1', '0004': 'IKEA of Sweden'}, 'ClusterType': {'253': 'LvlControl'}, '0004': {}}
2019-10-28 21:45:46.721 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 21:45:46.721 (Zigate) MajDomoDevice - NWKID: 95cc SwitchType: 7, DeviceType: LvlControl, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 1
2019-10-28 21:45:46.721 (Zigate) --> LvlControl analogValue: -> 2
2019-10-28 21:45:46.721 (Zigate) ----> LvlControl sValue: -> 1
2019-10-28 21:45:46.721 (Zigate) --> LvlControl UpdateDevice: -> 1/1 SwitchType: 7
2019-10-28 21:45:46.721 (Zigate) UpdateDevice_v2 1:1:_{}:108_False (Achtertuin: Zithoek Links)
2019-10-28 21:45:46.721 (Zigate) UpdateDevice_v2 for : Achtertuin: Zithoek Links RSSI = 5
ronaldbro
Post by ronaldbro »
I just did some more tests with the stable and the dim level also changes. But from 30% to 19% and it stays 19%.
See the logging below
2019-10-28 22:08:08.450 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 22:08:08.451 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 22:08:08.451 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 22:08:08.451 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:08.452 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:08.452 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 22:08:08.452 (Zigate) MajDomoDevice - {'0000': {'0001': '9', 'ff01': {}}, 'ClusterType': {'428': 'DButton_3'}, '0012': {'0055': 1}, '0006': {'0000': 1}}
2019-10-28 22:08:08.452 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:08.452 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 4 , old_sVal: 40
2019-10-28 22:08:08.453 (Zigate) UpdateDevice_v2 for : 22 Battery Level = {} Signal Level = 114
2019-10-28 22:08:08.453 (Zigate) UpdateDevice_v2 for : 22 RSSI = 5
2019-10-28 22:08:08.453 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 22:08:08.453 (Zigate) Update Values 1:'10:' (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 22:08:08.840 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 22:08:08.841 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-28 22:08:08.841 (Zigate) MajDomoDevice - Device ID : 14b457fffe3dbe31 - Device EP : 01 - Type : 0008 - Value : 31 - Hue : - Attribute_ :
2019-10-28 22:08:08.841 (Zigate) ClusterSearch - Cluster: 0008, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:08.841 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 22:08:08.841 (Zigate) MajDomoDevice - NWKID = 3f96 IEEE = 14b457fffe3dbe31 Unit = 417
2019-10-28 22:08:08.842 (Zigate) MajDomoDevice - {'0000': {'0000': '2', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0002': '98', '000a': '4c454431373337523547553130', '0004': 'IKEA of Sweden', '0001': '32', '4000': '2.0.022', '0003': '1', '0006': '20190308'}, '0300': {'0004': '26909', '4010': '65535', '0007': '276', '0003': '30138', '0008': '2'}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, '0019': {}, '0006': '01', 'ClusterType': {'417': 'ColorControlWW'}, '0005': {}, '0004': {}, 'fc7c': {}, '0003': {}, '0008': '31'}
2019-10-28 22:08:08.842 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:08.842 (Zigate) MajDomoDevice - NWKID: 3f96 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-28 22:08:08.842 (Zigate) UpdateDevice_v2 for : 5 Battery Level = {} Signal Level = 93
2019-10-28 22:08:08.842 (Zigate) UpdateDevice_v2 for : 5 RSSI = 4
2019-10-28 22:08:08.842 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:19
2019-10-28 22:08:08.842 (Zigate) Update Values 1:'19:' (Woonkamer: Spot uitbouw 2)
2019-10-28 22:08:08.864 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 22:08:08.865 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c3e08 - Device EP : 01 - Type : 0008 - Value : 31 - Hue : - Attribute_ :
2019-10-28 22:08:08.865 (Zigate) ClusterSearch - Cluster: 0008, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - NWKID = 9f16 IEEE = 14b457fffe4c3e08 Unit = 416
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - {'0000': {'0000': '2', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0002': '98', '000a': '4c454431373337523547553130', '0004': 'IKEA of Sweden', '0001': '32', '4000': '2.0.022', '0003': '1', '0006': '20190308'}, '0300': {'0004': '26909', '4010': '65535', '0007': '276', '0003': '30138', '0008': '2'}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, '0019': {}, '0006': '01', 'ClusterType': {'416': 'ColorControlWW'}, '0005': {}, '0004': {}, 'fc7c': {}, '0003': {}, '0008': '31'}
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:08.865 (Zigate) MajDomoDevice - NWKID: 9f16 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-28 22:08:08.866 (Zigate) UpdateDevice_v2 for : 4 Battery Level = {} Signal Level = 117
2019-10-28 22:08:08.866 (Zigate) UpdateDevice_v2 for : 4 RSSI = 6
2019-10-28 22:08:08.866 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:19
2019-10-28 22:08:08.866 (Zigate) Update Values 1:'19:' (Woonkamer: Spot uitbouw 1)
2019-10-28 22:08:08.935 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-28 22:08:08.936 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-28 22:08:08.936 (Zigate) MajDomoDevice - Device ID : 000d6ffffe8e9fb7 - Device EP : 01 - Type : 0008 - Value : 31 - Hue : - Attribute_ :
2019-10-28 22:08:08.936 (Zigate) ClusterSearch - Cluster: 0008, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:08.936 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 22:08:08.936 (Zigate) MajDomoDevice - NWKID = 4ecf IEEE = 000d6ffffe8e9fb7 Unit = 426
2019-10-28 22:08:08.936 (Zigate) MajDomoDevice - {'0000': {'0000': '2', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0002': '98', '000a': '4c454431373339523547553130', '0004': 'IKEA of Sweden', '0001': '32', '4000': '2.0.022', '0003': '1', '0006': '20190308'}, '0300': {'0004': '26909', '4010': '65535', '0007': '276', '0003': '30138', '0008': '2'}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, '0019': {}, '0006': '01', 'ClusterType': {'426': 'ColorControlWW'}, '0005': {}, '0004': {}, 'fc7c': {}, '0003': {}, '0008': '31'}
2019-10-28 22:08:08.937 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:08.937 (Zigate) MajDomoDevice - NWKID: 4ecf SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-28 22:08:08.937 (Zigate) UpdateDevice_v2 for : 82 Battery Level = {} Signal Level = 87
2019-10-28 22:08:08.937 (Zigate) UpdateDevice_v2 for : 82 RSSI = 4
2019-10-28 22:08:08.937 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:19
2019-10-28 22:08:08.937 (Zigate) Update Values 1:'19:' (Woonkamer: Spot uitbouw 5)
2019-10-28 22:08:08.955 (Zigate) Too early for a new update of LastSeen 987d
2019-10-28 22:08:08.955 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c273a - Device EP : 01 - Type : 0008 - Value : 31 - Hue : - Attribute_ :
2019-10-28 22:08:08.955 (Zigate) ClusterSearch - Cluster: 0008, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:08.955 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-28 22:08:08.955 (Zigate) MajDomoDevice - NWKID = 987d IEEE = 14b457fffe4c273a Unit = 424
2019-10-28 22:08:08.955 (Zigate) MajDomoDevice - {'0000': {'0000': '2', '0005': 'TRADFRI bulb GU10 WS 400lm', '0007': '1', '0002': '98', '000a': '4c454431373337523547553130', '0004': 'IKEA of Sweden', '0001': '32', '4000': '2.0.022', '0003': '1', '0006': '20190308'}, '0300': {'0004': '26909', '4010': '65535', '0007': '276', '0003': '30138', '0008': '2'}, 'Type': 'ColorControlWW', '0020': {}, '1000': {}, '0019': {}, '0006': '01', 'ClusterType': {'424': 'ColorControlWW'}, '0005': {}, '0004': {}, 'fc7c': {}, '0003': {}, '0008': '31'}
2019-10-28 22:08:08.956 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:08.956 (Zigate) MajDomoDevice - NWKID: 987d SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-28 22:08:08.956 (Zigate) UpdateDevice_v2 for : 6 Battery Level = {} Signal Level = 108
2019-10-28 22:08:08.956 (Zigate) UpdateDevice_v2 for : 6 RSSI = 5
2019-10-28 22:08:08.956 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:19
2019-10-28 22:08:08.956 (Zigate) Update Values 1:'19:' (Woonkamer: Spot uitbouw 3)
2019-10-28 22:08:08.650 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 22:08:08.651 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 22:08:08.652 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 22:08:08.668 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 22:08:12.862 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:19
2019-10-28 22:08:13.018 (Zigate) LQI:LQIresp - 4ecf already in Neighbours Table for 0000
2019-10-28 22:08:13.875 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 22:08:13.876 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 22:08:13.876 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:13.876 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:13.876 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 22:08:13.877 (Zigate) MajDomoDevice - {'0000': {'0001': '9', 'ff01': {}}, 'ClusterType': {'428': 'DButton_3'}, '0012': {'0055': 1}, '0006': {'0000': 1}}
2019-10-28 22:08:13.877 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:13.877 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-28 22:08:13.877 (Zigate) UpdateDevice_v2 for : 22 Battery Level = {} Signal Level = 114
2019-10-28 22:08:13.877 (Zigate) UpdateDevice_v2 for : 22 RSSI = 5
2019-10-28 22:08:13.877 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 22:08:13.878 (Zigate) Update Values 1:'10:' (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 22:08:14.866 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: 00
2019-10-28 22:08:14.090 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 22:08:14.091 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 22:08:14.092 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 22:08:14.092 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 22:08:14.127 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 22:08:17.777 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 22:08:17.778 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 22:08:17.778 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:17.778 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:17.778 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 22:08:17.779 (Zigate) MajDomoDevice - {'0000': {'0001': '9', 'ff01': {}}, 'ClusterType': {'428': 'DButton_3'}, '0012': {'0055': 1}, '0006': {'0000': 1}}
2019-10-28 22:08:17.779 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:17.779 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-28 22:08:17.779 (Zigate) UpdateDevice_v2 for : 22 Battery Level = {} Signal Level = 111
2019-10-28 22:08:17.779 (Zigate) UpdateDevice_v2 for : 22 RSSI = 5
2019-10-28 22:08:17.779 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 22:08:17.780 (Zigate) Update Values 1:'10:' (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 22:08:17.919 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:19
2019-10-28 22:08:18.222 (Zigate) Too early for a new update of LastSeen 8cca
2019-10-28 22:08:18.222 (Zigate) MajDomoDevice - Device ID : 00158d0002c63578 - Device EP : 01 - Type : 0400 - Value : 51 - Hue : - Attribute_ :
2019-10-28 22:08:18.222 (Zigate) ClusterSearch - Cluster: 0400, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - Type = Lux
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - NWKID = 8cca IEEE = 00158d0002c63578 Unit = 356
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - {'0000': {'ff01': '0121c70b03281b0421a83305210f00062413000000000a2100006410000b213300'}, 'ClusterType': {'357': 'Lux', '356': 'Motion'}, '0406': '01', '0400': '47', '0001': {'0000': 3015}, '0006': {'0000': '00'}}
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - NWKID: 8cca SwitchType: 8, DeviceType: Motion, ClusterType: Lux, old_nVal: 0 , old_sVal: Off
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - NWKID = 8cca IEEE = 00158d0002c63578 Unit = 357
2019-10-28 22:08:18.223 (Zigate) MajDomoDevice - NWKID: 8cca SwitchType: 0, DeviceType: Lux, ClusterType: Lux, old_nVal: 47 , old_sVal: 47
2019-10-28 22:08:18.224 (Zigate) UpdateDevice_v2 for : 71 Battery Level = 66 Signal Level = 132
2019-10-28 22:08:18.224 (Zigate) UpdateDevice_v2 for : 71 RSSI = 6
2019-10-28 22:08:18.224 (Zigate) UpdateDevice - (Keuken: Beweging - lux) 51:51
2019-10-28 22:08:18.224 (Zigate) Update Values 51:'51:' (Keuken: Beweging - lux)
2019-10-28 22:08:18.246 (Zigate) Too early for a new update of LastSeen 8cca
2019-10-28 22:08:18.247 (Zigate) Too early for a new update of LastSeen 8cca
2019-10-28 22:08:18.247 (Zigate) MajDomoDevice - Device ID : 00158d0002c63578 - Device EP : 01 - Type : 0406 - Value : 01 - Hue : - Attribute_ :
2019-10-28 22:08:18.247 (Zigate) ClusterSearch - Cluster: 0406, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:18.247 (Zigate) MajDomoDevice - Type = Motion
2019-10-28 22:08:18.247 (Zigate) MajDomoDevice - NWKID = 8cca IEEE = 00158d0002c63578 Unit = 356
2019-10-28 22:08:18.247 (Zigate) MajDomoDevice - {'0000': {'ff01': '0121c70b03281b0421a83305210f00062413000000000a2100006410000b213300'}, 'ClusterType': {'357': 'Lux', '356': 'Motion'}, '0406': '01', '0400': '51', '0001': {'0000': 3015}, '0006': {'0000': '00'}}
2019-10-28 22:08:18.248 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:18.248 (Zigate) MajDomoDevice - NWKID: 8cca SwitchType: 8, DeviceType: Motion, ClusterType: Motion, old_nVal: 0 , old_sVal: Off
2019-10-28 22:08:18.248 (Zigate) UpdateDevice_v2 for : 70 Battery Level = 66 Signal Level = 132
2019-10-28 22:08:18.248 (Zigate) UpdateDevice_v2 for : 70 RSSI = 6
2019-10-28 22:08:18.248 (Zigate) UpdateDevice - (Keuken: Beweging) 1:On
2019-10-28 22:08:18.248 (Zigate) Update Values 1:'On:' (Keuken: Beweging)
2019-10-28 22:08:18.284 (Zigate) MajDomoDevice - NWKID = 8cca IEEE = 00158d0002c63578 Unit = 357
2019-10-28 22:08:18.284 (Zigate) MajDomoDevice - {'0000': {'ff01': '0121c70b03281b0421a83305210f00062413000000000a2100006410000b213300'}, 'ClusterType': {'357': 'Lux', '356': 'Motion'}, '0406': '01', '0400': '51', '0001': {'0000': 3015}, '0006': {'0000': '00'}}
2019-10-28 22:08:18.284 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:18.284 (Zigate) MajDomoDevice - NWKID: 8cca SwitchType: 0, DeviceType: Lux, ClusterType: Motion, old_nVal: 51 , old_sVal: 51
2019-10-28 22:08:18.587 (Zigate) mgtCommand called for Devices[80].Name: Keuken: Aanrechtverlichting SwitchType: 7 Command: Set Level Level: 100 Color:
2019-10-28 22:08:18.587 (Zigate) mgtCommand - NWKID = 0869
2019-10-28 22:08:18.587 (Zigate) mgtCommand : found Device : 403 in Ep 01 LvlControl
2019-10-28 22:08:18.587 (Zigate) mgtCommand - List of TypeName : ['LvlControl']
2019-10-28 22:08:18.587 (Zigate) mgtCommand - DeviceType : LvlControl
2019-10-28 22:08:18.587 (Zigate) mgtCommand : Found Ep 01 for Device 403 Cluster 0008
2019-10-28 22:08:18.587 (Zigate) EPout = 01
2019-10-28 22:08:18.588 (Zigate) UpdateDevice_v2 for : 80 Battery Level = {} Signal Level = 84
2019-10-28 22:08:18.588 (Zigate) UpdateDevice_v2 for : 80 RSSI = 4
2019-10-28 22:08:18.029 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 22:08:18.030 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 22:08:18.030 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 22:08:18.031 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 22:08:18.031 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 22:08:18.031 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 22:08:18.031 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 22:08:18.031 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 22:08:18.031 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 22:08:18.063 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 22:08:23.189 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:19
2019-10-28 22:08:23.600 (Zigate) Too early for a new update of LastSeen 2832
2019-10-28 22:08:23.600 (Zigate) MajDomoDevice - Device ID : 00158d0002490400 - Device EP : 03 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-10-28 22:08:23.600 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 266
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 266
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 266
2019-10-28 22:08:23.601 (Zigate) MajDomoDevice - NWKID: 2832 SwitchType: 0, DeviceType: Switch, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
2019-10-28 22:08:23.601 (Zigate) UpdateDevice_v2 for : 66 Battery Level = 100 Signal Level = 90
2019-10-28 22:08:23.601 (Zigate) UpdateDevice_v2 for : 66 RSSI = 4
2019-10-28 22:08:23.602 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 267
2019-10-28 22:08:23.602 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:23.602 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:23.602 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 267
2019-10-28 22:08:23.602 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 267
2019-10-28 22:08:30.731 (Zigate) Too early for a new update of LastSeen 2832
2019-10-28 22:08:30.732 (Zigate) Too early for a new update of LastSeen 2832
2019-10-28 22:08:30.732 (Zigate) MajDomoDevice - Device ID : 00158d0002490400 - Device EP : 03 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-10-28 22:08:30.732 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:30.733 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:30.733 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 266
2019-10-28 22:08:30.733 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:30.733 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:30.733 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 266
2019-10-28 22:08:30.734 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 266
2019-10-28 22:08:30.734 (Zigate) MajDomoDevice - NWKID: 2832 SwitchType: 0, DeviceType: Switch, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
2019-10-28 22:08:30.734 (Zigate) UpdateDevice_v2 for : 66 Battery Level = 100 Signal Level = 90
2019-10-28 22:08:30.734 (Zigate) UpdateDevice_v2 for : 66 RSSI = 4
2019-10-28 22:08:30.734 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 267
2019-10-28 22:08:30.735 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:30.735 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:30.735 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 267
2019-10-28 22:08:30.735 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 267
2019-10-28 22:08:30.736 (Zigate) Too early for a new update of LastSeen 2832
2019-10-28 22:08:30.737 (Zigate) Too early for a new update of LastSeen 2832
2019-10-28 22:08:30.737 (Zigate) MajDomoDevice - Device ID : 00158d0002490400 - Device EP : 03 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-10-28 22:08:30.737 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:30.737 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:30.738 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 266
2019-10-28 22:08:30.738 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:30.738 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:30.738 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 266
2019-10-28 22:08:30.738 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 266
2019-10-28 22:08:30.739 (Zigate) MajDomoDevice - NWKID: 2832 SwitchType: 0, DeviceType: Switch, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
2019-10-28 22:08:30.739 (Zigate) UpdateDevice_v2 for : 66 Battery Level = 100 Signal Level = 90
2019-10-28 22:08:30.739 (Zigate) UpdateDevice_v2 for : 66 RSSI = 4
2019-10-28 22:08:30.739 (Zigate) MajDomoDevice - NWKID = 2832 IEEE = 00158d0002490400 Unit = 267
2019-10-28 22:08:30.739 (Zigate) MajDomoDevice - {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'}
2019-10-28 22:08:30.739 (Zigate) MajDomoDevice - We have 2 EPs with ClusterType
2019-10-28 22:08:30.740 (Zigate) MajDomoDevice - search ClusterType in : {'ClusterType': {'266': 'Switch'}, 'Type': 'Switch', '0005': {}, '0004': {}, '0010': {}, '0006': '00'} for : 267
2019-10-28 22:08:30.740 (Zigate) MajDomoDevice - search ClusterType in : {'266': 'Switch'} for : 267
2019-10-28 22:08:30.741 (Zigate) Touch unit Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 nwkid: a474
2019-10-28 22:08:30.743 (Zigate) Too early for a new update of LastSeen a474
2019-10-28 22:08:30.744 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-28 22:08:30.744 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-10-28 22:08:30.744 (Zigate) MajDomoDevice - Type = Switch
2019-10-28 22:08:30.744 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-28 22:08:30.745 (Zigate) MajDomoDevice - {'0000': {'0001': '9', 'ff01': {}}, 'ClusterType': {'428': 'DButton_3'}, '0012': {'0055': 1}, '0006': {'0000': 1}}
2019-10-28 22:08:30.745 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-28 22:08:30.745 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-28 22:08:30.745 (Zigate) UpdateDevice_v2 for : 22 Battery Level = {} Signal Level = 111
2019-10-28 22:08:30.745 (Zigate) UpdateDevice_v2 for : 22 RSSI = 5
2019-10-28 22:08:30.745 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-28 22:08:30.746 (Zigate) Update Values 1:'10:' (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-28 22:08:30.956 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-28 22:08:30.958 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-28 22:08:30.958 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-28 22:08:30.972 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-28 22:08:34.729 (Zigate) processListOfDevices - Device: f4e3 is in Status = 'Left' for 5328HB
pipiche
Post by pipiche »
Did you enable debugCommand , as I do not see any command.
If I understood your dzVent script should trigger some action.
The only think I see is the state return update .
When processing a Color action, the plugin expects 2 attributes, the Level value and the Color value.
https://www.domoticz.com/wiki/Domoticz_ ... emperature
In your case if the Brightness is not provided, I would be interested to see what dzVents/Domoticz do and send to the plugin.
So the best is:
enable debugCommand
enable debugWidget
Screenshot 2019-10-29 at 07.56.55.png (122.12 KiB) Viewed 1301 times
ronaldbro
Post by ronaldbro »
Yep, both are set (and logDeviceUpdate too)
This is my dzVents test script. Maybe the problem is in the setKelvin command. It only takes 1 parameter.
devices = {
idx_test_switch
-- custom logging level for this script
logging = {
level = domoticz.LOG_DEBUG,
marker = "Test"
execute = function(dz, Item, info)
local lamp = dz.devices(idx_woonkamer_spotsUitbouw)
if Item.level == 10 then -- left button click
lamp.setKelvin(60)
elseif Item.level == 20 then -- left button double click
dz.log(lamp.getColor())
elseif Item.level == 40 then -- right button click
lamp.dimTo(30)
And some logging:
2019-10-29 09:53:56.764 (Zigate) Too early for a new update of LastSeen a474
2019-10-29 09:53:56.765 (Zigate) Too early for a new update of LastSeen a474
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - Device ID : 00158d00031360ed - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - Type = Switch
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - NWKID = a474 IEEE = 00158d00031360ed Unit = 428
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - {'0012': {'0055': 1}, '0001': '3115;3115;3125;3125', 'ClusterType': {'428': 'DButton_3'}, '0006': {'0000': 1}, '0000': {'0001': '9', 'ff01': {}}}
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:53:56.765 (Zigate) MajDomoDevice - NWKID: a474 SwitchType: 18, DeviceType: DButton_3, ClusterType: Switch, old_nVal: 1 , old_sVal: 10
2019-10-29 09:53:56.766 (Zigate) UpdateDevice_v2 1:10:_91:117_True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-29 09:53:56.766 (Zigate) UpdateDevice_v2 for : Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 RSSI = 6
2019-10-29 09:53:56.766 (Zigate) UpdateDevice_v2 for : Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 BatteryLevel = 91
2019-10-29 09:53:56.766 (Zigate) UpdateDevice - (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01) 1:10
2019-10-29 09:53:56.766 (Zigate) Update Values 1:10: 91:6 True (Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01)
2019-10-29 09:53:56.998 Status: dzVents: Info: Test: ------ Start internal script: Knoptest zigate: Device: "Zigate - lumi.remote.b286acn01_DButton_3-00158d00031360ed-01 (Zigate)", Index: 428
2019-10-29 09:53:57.155 (Zigate) Touch unit Woonkamer: Spot uitbouw 2 nwkid: 3f96
2019-10-29 09:53:57.157 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:53:57.157 (Zigate) MajDomoDevice - Device ID : 14b457fffe3dbe31 - Device EP : 01 - Type : 0008 - Value : 73 - Hue : - Attribute_ :
2019-10-29 09:53:57.158 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-29 09:53:57.158 (Zigate) MajDomoDevice - NWKID = 3f96 IEEE = 14b457fffe3dbe31 Unit = 417
2019-10-29 09:53:57.158 (Zigate) MajDomoDevice - {'ClusterType': {'417': 'ColorControlWW'}, '0000': {'4000': '2.0.022', '0002': '98', '0004': 'IKEA of Sweden', '000a': '4c454431373337523547553130', '0001': '32', '0007': '1', '0000': '2', '0006': '20190308', '0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm'}, '0004': {}, '0005': {}, 'fc7c': {}, '1000': {}, '0300': {'0007': '454', '4010': '65535', '0004': '10133', '0003': '25262', '0008': '2'}, '0020': {}, '0019': {}, 'Type': 'ColorControlWW', '0006': {'4000': '01', '4002': '0', '4003': '1', '4001': '0', '0000': '01'}, '0003': {}, '0008': {'0000': '115'}}
2019-10-29 09:53:57.158 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:53:57.158 (Zigate) MajDomoDevice - NWKID: 3f96 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-29 09:53:57.158 (Zigate) UpdateDevice_v2 1:45:_{}:84_False (Woonkamer: Spot uitbouw 2)
2019-10-29 09:53:57.158 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 2 RSSI = 4
2019-10-29 09:53:57.158 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:45
2019-10-29 09:53:57.158 (Zigate) Update Values 1:45: 255:4 False (Woonkamer: Spot uitbouw 2)
2019-10-29 09:53:57.170 (Zigate) Touch unit Woonkamer: Spot uitbouw 3 nwkid: 987d
2019-10-29 09:53:57.172 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:53:57.172 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c273a - Device EP : 01 - Type : 0008 - Value : 73 - Hue : - Attribute_ :
2019-10-29 09:53:57.172 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-29 09:53:57.172 (Zigate) MajDomoDevice - NWKID = 987d IEEE = 14b457fffe4c273a Unit = 424
2019-10-29 09:53:57.172 (Zigate) MajDomoDevice - {'ClusterType': {'424': 'ColorControlWW'}, '0000': {'4000': '2.0.022', '0002': '98', '0004': 'IKEA of Sweden', '000a': '4c454431373337523547553130', '0001': '32', '0007': '1', '0000': '2', '0006': '20190308', '0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm'}, '0004': {}, '0005': {}, 'fc7c': {}, '1000': {}, '0300': {'0007': '276', '4010': '65535', '0004': '26909', '0003': '30138', '0008': '2'}, '0020': {}, '0019': {}, 'Type': 'ColorControlWW', '0006': {'0000': '01'}, '0003': {}, '0008': {'0000': '115'}}
2019-10-29 09:53:57.172 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:53:57.173 (Zigate) MajDomoDevice - NWKID: 987d SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-29 09:53:57.173 (Zigate) UpdateDevice_v2 1:45:_{}:117_False (Woonkamer: Spot uitbouw 3)
2019-10-29 09:53:57.173 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 3 RSSI = 6
2019-10-29 09:53:57.173 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:45
2019-10-29 09:53:57.173 (Zigate) Update Values 1:45: 255:6 False (Woonkamer: Spot uitbouw 3)
2019-10-29 09:53:57.184 (Zigate) Touch unit Woonkamer: Spot uitbouw 5 nwkid: 4ecf
2019-10-29 09:53:57.185 (Zigate) Too early for a new update of LastSeen 4ecf
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - Device ID : 000d6ffffe8e9fb7 - Device EP : 01 - Type : 0008 - Value : 73 - Hue : - Attribute_ :
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - NWKID = 4ecf IEEE = 000d6ffffe8e9fb7 Unit = 426
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - {'ClusterType': {'426': 'ColorControlWW'}, '0000': {'4000': '2.0.022', '0002': '98', '0004': 'IKEA of Sweden', '000a': '4c454431373339523547553130', '0001': '32', '0007': '1', '0000': '2', '0006': '20190308', '0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm'}, '0004': {}, '0005': {}, 'fc7c': {}, '1000': {}, '0300': {'0007': '276', '4010': '65535', '0004': '26909', '0003': '30138', '0008': '2'}, '0020': {}, '0019': {}, 'Type': 'ColorControlWW', '0006': {'0000': '01'}, '0003': {}, '0008': {'0000': '115'}}
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:53:57.186 (Zigate) MajDomoDevice - NWKID: 4ecf SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-29 09:53:57.186 (Zigate) UpdateDevice_v2 1:45:_{}:87_False (Woonkamer: Spot uitbouw 5)
2019-10-29 09:53:57.187 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 5 RSSI = 4
2019-10-29 09:53:57.187 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:45
2019-10-29 09:53:57.187 (Zigate) Update Values 1:45: 255:4 False (Woonkamer: Spot uitbouw 5)
2019-10-29 09:53:57.246 (Zigate) Touch unit Woonkamer: Spot uitbouw 1 nwkid: 9f16
2019-10-29 09:53:57.248 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-29 09:53:57.248 (Zigate) MajDomoDevice - Device ID : 14b457fffe4c3e08 - Device EP : 01 - Type : 0008 - Value : 73 - Hue : - Attribute_ :
2019-10-29 09:53:57.248 (Zigate) MajDomoDevice - Type = LvlControl
2019-10-29 09:53:57.248 (Zigate) MajDomoDevice - NWKID = 9f16 IEEE = 14b457fffe4c3e08 Unit = 416
2019-10-29 09:53:57.249 (Zigate) MajDomoDevice - {'ClusterType': {'416': 'ColorControlWW'}, '0000': {'4000': '2.0.022', '0002': '98', '0004': 'IKEA of Sweden', '000a': '4c454431373337523547553130', '0001': '32', '0007': '1', '0000': '2', '0006': '20190308', '0003': '1', '0005': 'TRADFRI bulb GU10 WS 400lm'}, '0004': {}, '0005': {}, 'fc7c': {}, '1000': {}, '0300': {'0007': '276', '4010': '65535', '0004': '26909', '0003': '30138', '0008': '2'}, '0020': {}, '0019': {}, 'Type': 'ColorControlWW', '0006': {'0000': '01'}, '0003': {}, '0008': {'0000': '115'}}
2019-10-29 09:53:57.249 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:53:57.249 (Zigate) MajDomoDevice - NWKID: 9f16 SwitchType: 7, DeviceType: ColorControlWW, ClusterType: LvlControl, old_nVal: 1 , old_sVal: 30
2019-10-29 09:53:57.249 (Zigate) UpdateDevice_v2 1:45:_{}:117_False (Woonkamer: Spot uitbouw 1)
2019-10-29 09:53:57.249 (Zigate) UpdateDevice_v2 for : Woonkamer: Spot uitbouw 1 RSSI = 6
2019-10-29 09:53:57.249 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:45
2019-10-29 09:53:57.249 (Zigate) Update Values 1:45: 255:6 False (Woonkamer: Spot uitbouw 1)
2019-10-29 09:53:57.361 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:53:57.363 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:53:57.415 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-29 09:53:57.416 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-29 09:53:57.000 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: RGB(W) device adapter
2019-10-29 09:53:57.000 Status: dzVents: Debug: Test: Processing device-adapter for Woonkamer: Spot uitbouw: Switch device adapter
2019-10-29 09:53:57.001 Status: dzVents: Debug: Test: OpenURL: url = http://127.0.0.1:8080/json.htm?param=se ... &kelvin=60
2019-10-29 09:53:57.001 Status: dzVents: Debug: Test: OpenURL: method = GET
2019-10-29 09:53:57.001 Status: dzVents: Debug: Test: OpenURL: post data = nil
2019-10-29 09:53:57.001 Status: dzVents: Debug: Test: OpenURL: headers = nil
2019-10-29 09:53:57.001 Status: dzVents: Debug: Test: OpenURL: callback = nil
2019-10-29 09:53:57.001 Status: dzVents: Info: Test: ------ Finished Knoptest zigate
2019-10-29 09:53:57.020 Status: setkelvinlevel: t: 60.000000, color: '{m: 2, RGB: 000000, CWWW: 6699, CT: 153}'
2019-10-29 09:53:58.373 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:53:58.374 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:53:58.380 (Zigate) Too early for a new update of LastSeen 9f16
2019-10-29 09:54:00.698 (Zigate) Too early for a new update of LastSeen 95cc
2019-10-29 09:54:00.699 (Zigate) Too early for a new update of LastSeen 95cc
2019-10-29 09:54:00.699 (Zigate) MajDomoDevice - Device ID : 000b57fffe907671 - Device EP : 01 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-10-29 09:54:00.699 (Zigate) MajDomoDevice - Type = Switch
2019-10-29 09:54:00.699 (Zigate) MajDomoDevice - NWKID = 95cc IEEE = 000b57fffe907671 Unit = 253
2019-10-29 09:54:00.699 (Zigate) MajDomoDevice - {'1000': {}, '0b05': {}, '0004': {}, '0006': {'0000': {}}, '0000': {'0001': '17', '0000': '1', '0004': 'IKEA of Sweden', '0003': '1', '0002': '87'}, 'Type': 'LvlControl', '0008': {'0000': '2'}, 'ClusterType': {'253': 'LvlControl'}, '0003': {}, '0005': {}}
2019-10-29 09:54:00.699 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:54:00.700 (Zigate) MajDomoDevice - NWKID: 95cc SwitchType: 7, DeviceType: LvlControl, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
2019-10-29 09:54:01.020 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:100
2019-10-29 09:54:01.165 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.166 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.167 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.168 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.280 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.282 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.283 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.285 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.287 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.288 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.391 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.392 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.393 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.495 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.496 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.497 (Zigate) Too early for a new update of LastSeen 3f96
2019-10-29 09:54:01.599 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.600 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.601 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.703 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.704 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.705 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.706 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.808 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.809 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.810 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.912 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.913 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:01.914 (Zigate) Too early for a new update of LastSeen 987d
2019-10-29 09:54:02.170 (Zigate) Too early for a new update of LastSeen 819e
2019-10-29 09:54:02.171 (Zigate) Too early for a new update of LastSeen 819e
2019-10-29 09:54:02.171 (Zigate) MajDomoDevice - Device ID : 000b57fffec51189 - Device EP : 01 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-10-29 09:54:02.171 (Zigate) MajDomoDevice - Type = Switch
2019-10-29 09:54:02.172 (Zigate) MajDomoDevice - NWKID = 819e IEEE = 000b57fffec51189 Unit = 252
2019-10-29 09:54:02.172 (Zigate) MajDomoDevice - {'1000': {}, '0b05': {}, '0004': {}, '0006': {'4000': '01', '4002': '0', '4003': '1', '4001': '0', '0000': '00'}, '0000': {'0001': '17', '0000': '1', '0004': 'IKEA of Sweden', '0003': '1', '0002': '87'}, 'Type': 'LvlControl', '0008': {'0000': '2'}, 'ClusterType': {'252': 'LvlControl'}, '0003': {}, '0005': {}}
2019-10-29 09:54:02.172 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-10-29 09:54:02.172 (Zigate) MajDomoDevice - NWKID: 819e SwitchType: 7, DeviceType: LvlControl, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
pipiche
Re: Zigate + Tradfri gu10 dual white added as RGBWW device
Post by pipiche »
I’ll investigate with the script.
ronaldbro
Post by ronaldbro »
@pipiche I did some more tests and I think the problem is in de dzVents setKelvin command. When I use the setColor command like lamp.setColor(0,0,0,30,0,0,2,255) --setColor(r, g, b, br, cw, ww, m, t)
then it works perfectly without any problems
pipiche
Post by pipiche »
see that post, I just made: https://www.domoticz.com/forum/viewtopi ... 59&t=29947
It looks like a Level is provided, but no clue where it is coming from.
Will continue invetsigating with the setColor(). But with setColor, you set the expected brightness '30'
ronaldbro
Post by ronaldbro »
Yep, thats correct.
So setColor(0,0,0,30,0,0,2,255) is the combined command for setKelvin(100) and dimTo(30)
