Run script at Switch on called by webhook Topic is solved
All kinds of 'OS' scripts
Onrust
Domoticz version: 4.10717
Post by Onrust »
I have the following set-up:
- Domoticz running on a Pi
- Security camera software (Shinobi) on a dedicated server
- On motion detection, Shinobi calls a url to set a virtual switch in Domoticz to ON:
http://192.168.178.60:8080/json.htm?type=command&param=udevice&idx=785&nvalue=1
This functions correctly, the switch is correctly being set to ON at motion.
- In Domoticz, the switch is set to run a script when the status changes to ON. The script looks like this:
#!/bin/bash
SnapFile="/var/tmp/camsnapshot.jpg"
# Get snapshot via Domoticz server
wget -O $SnapFile "http://192.168.178.60:8080/camsnapshot.jpg?idx=1"
curl -s -X POST "https://api.telegram.org/botxxxxxxx/sendPhoto" -F chat_id=-xxxxx -F photo="@$SnapFile"
# Remove Image
/bin/rm $SnapFile
The issue is that the script doesn't run when the switch is activated from the webhook, even though the switch itself is correctly activated and set to ON. When I activate the switch manually in the Domoticz dashboard, it works fine and the script sends me a picture as expected.
The permissions of the script are set to 777.
What am I doing wrong here?
Re: Run script at Switch on called by webhook
Onrust wrote: Saturday 26 October 2019 9:40 - On motion detection, Shinobi calls a url to set a virtual switch in Domoticz to ON:
It is not wrong but the udevice command is not designed to trigger a script or url in the ( on = / off = ) sections.
If you set Shinobi to send
http://192.168.192.178.60:8080/json.htm?type=command&param=switchlight&idx=785&switchcmd=On
it will probably work
Onrust
Post by Onrust »
Awesome, you rock! That worked indeed. Many thanks! :)
