I'm trying to control a blinder
2019-09-02 14:00:02 Sun West 2/20
2019-09-02 17:52:55 Molnighet 18.00 0/18.00
2019-09-02 06:13:01 DayNight On 1/0Moderator: leecollings
2019-09-02 06:13:01 DayNight On 1/0As the logs was showing a numeric value I tried that, this is the current one.knielen wrote: Wednesday 11 September 2019 15:32 Looks like you used a switch called 'Sun', a switch can not have a value. Wat kind of device is 'Sun'?
I have a timers on the Sun dummy switch as you can see. It changes the status based on the timeknielen wrote: Monday 21 October 2019 14:48 Not sure if this works.
But in this case you want to know if the sun in on the same side as your screen. Maybe you can try to make this time based? In your case after midday?
