Guide - How to check BTRFS volume integrity using Monit
All kinds of 'OS' scripts
ben53252642
Post by ben53252642 »
A Monit rule and script that does a read only BTRFS file system volume scrub (in this case the root volume / ) at a set time each day and generates a Monit alert if errors were detected.
Rule for /etc/monit/monitrc:
# BTRFS File System Integrity
check program btrfsintegritycheck with path "/etc/monit/scripts/btrfsintegritycheck.sh"
 with timeout 1800 seconds
 # Run at 4am each day
 every "0 4 * * *"
 if status != 0 then alert
Script that goes in:
#!/bin/bash
btrfs scrub start -Br / | grep -e 'no errors found' -e 'with 0 errors'
This is an extremely useful tool for detecting for example corruption of an SD card.
Last edited by ben53252642 on Thursday 07 November 2019 13:06, edited 1 time in total.
ben53252642
Re: Guide - How to check BTRFS volume integrity using Monit
Wow! Monit / Mmonit just picked up a server with a corrupt BTRFS volume!
I investigated and sure enough, it was corrupt with unfixable errors, now restoring from a backup. 8-)
Checking the server manually (output below):
ben53252642
I really, really like BTRFS! :)
Using the below command (will probably vary a bit for different systems), I was able to get a list of files that had become corrupt on the BTRFS file system, delete them (which fixed the file system corruption), then restore just those files that had become corrupted from a backup.
journalctl --output cat | grep 'BTRFS' | grep '(path:' | sed -n -e 's/^.*\(path:\)/\1/p' | cut -f2- -d: | tr -d ")"
Note that I ran this command before the one above: btrfs scrub start -Bd /dev/sda2
Upon deleting the list of corrupt files....
