I reviewed several templates, installed some, finally did it my way based on the FLATMAG administration panel. With your own icons. If anyone would like to try it, I would be grateful for any information that could be improved. I don't have much equipment connected to Domoticz, so I was based on what I have available. Several things still need to be improved... I try to improve on a regular basis.
You can download from here:
Small tip: after running domoticz you need to clear the cache of the pictures (e.g. in saved cookies and website data) of the domain where domoticz is located. As a result, it should look like the picture.
Another FLAT theme
mixmint
Another FLAT theme
- screenshot.jpg (153.41 KiB) Viewed 1439 times
