Can IFTTT script also work with ID's  [Solved]
pvklink
Domoticz version: latest b
Post by pvklink »
I have a small question about the ifttt script.
It works wunderful within domoticz and IFTTT !
Last part is converting my node-red nora scripts to use ifttvar
I normally use this content to execute a device with ifttvar : [{"obj":"lantaarn","act":"On"}]
But this special node for google home uses id's.
Does this script also handles id's instead of names?
I tried:
[{"obj":"1002","act":"On"}]
[{"obj":1002,"act":"On"}] but they dont work...
am i doing something wrong, or does this script only work with devicename (dont get me wrong, i am VERY happy with this script, i used it 1000 times....
syntax of JSON in uservar:
{"obj":"IFvar","set":"TestString"},
{"obj":"IFswitch","act":"On","fS":10,"aS":10,"si":true},
{"obj":"IFSelector","lbl":"Level1"},
{"obj":"IFScene","act":"On"}]
or
{"obj":"message from ifttt","msg":["message to all"]},
max. number of chars = 200
every action request in the json should have obj/object and max. one of (act/action, lbl/label, msg/message, set or upd/update, ).
Other controls (aS/afterSec, fS/ forSec, rAS/repeatAfterSec, si/silent are optional.
if message/msg is the requested action the object field is used as subject and subtable [{}]
            mandatory       line.object    message subject
            mandatory       line.message[1] message body
            optional or nil line.message[2] message priority  (-2=LOW, -1=MODERATE, 0=NORMAL, 1=HIGH, 2=EMERGENCY)
            optional or nil line.message[3] message sound (string like 'pushover','bike','none')
            optional or nil line.message[4] extra
            optional or nil line.message[5] subsystem or table with subsystems
            examples
            [{"obj":"message from ifttt","msg":["message to all notification systems with default priority"]}]
            [{"obj":"message from ifttt","msg":["message to pushover with high priority",1,null,null,"pushover"]}]
            [{"obj":"message from ifttt","msg":["message to pushover and gcm with low priority",-2,null,null,["pushover","gcm"] ]}]
if OSCommand/os is the requested action, the object field is used program / scriptname. name must be full qualified e.g. "/home/pi/scripts/myScript.sh"
local iftttvar = "IFTTTvar"
return
    on =
        variables = { iftttvar },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'ifttt',
    execute = function(dz, item)
        local function makeLongKeys(str)
            local shortNames = {
                                    act="action",  -- optional: Can be On, Off or OS/OScommand:
                                                   -- On; valid for switches and groups and scenes and scenes; Off; valid for switches and groups
                                    aS="afterSec", -- optional:
                                    fS="forSec",   -- optional: Only valid for standard (On/Off) switches
                                    lbl="label",   -- optional: levelName or number for selector type switches
                                    msg="message", -- Optional: obj must be set to subject
                                    obj="object",  -- Mandatory and must be unique in domoticz: name for device, scene, group or uservariable.
                                    os="OSCommand", -- if os / OSCommand is the requested action, obj must be set to full qualified script /program.
                                    rAS="repeatAfterSec", -- optional: Only valid for standard (On/Off) switches
                                    set="set",  -- Optional: update uservariable
                                    si="silent",  -- Optional: use "si":true in JSON
                                    upd="update", -- Optional: Only valid for devices (set nValue, sValue)
            for short, long in pairs(shortNames) do
                str = str:gsub('%f[%a]' .. short .. '%f[%A]' ,long) -- this will only replace short with long if short is a whole word
            return str
        local function getBaseType(name)
            for i, tuple in ipairs(_G.domoticzData) do
                if tuple.name == name then
                    return tuple.baseType, tuple.id
        local function makeTarget(baseType, name)
            if baseType == 'device' then
                return dz.devices(name)
            elseif baseType == 'group' then
                return dz.groups(name)
            elseif baseType == 'scene' then
                return dz.scenes(name)
            elseif baseType == 'uservariable' then
                return dz.variables(name)
        local function doLabelVariant(line, target)
            if line.afterSec and line.silent then
                target.switchSelector(line.label).silent().afterSec(line.afterSec)
            elseif line.afterSec then
                target.switchSelector(line.label).afterSec(line.afterSec)
           elseif line.silent then
        local function doUpdateVariant(line, target)
                target.update(line.update).silent().afterSec(line.afterSec)
                target.update(line.update).afterSec(line.afterSec)
        local function doSetVariant(line, target)
                target.set(line.set).silent().afterSec(line.afterSec)
                target.set(line.set).afterSec(line.afterSec)
        local function doOnVariant(line, target)
            if line.afterSec and line.forSec and line.silent then
                target.switchOn().silent().afterSec(line.afterSec).forSec(line.forSec)
            elseif line.afterSec and line.repeatAfterSec and line.silent then
                target.switchOn().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
            elseif line.afterSec and line.silent then
                target.switchOn().afterSec(line.afterSec)
                target.switchOn()
        local function doOffVariant(line, target)
                target.switchOff().silent().afterSec(line.afterSec).forSec(line.forSec)
                target.switchOff().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
                target.switchOff().afterSec(line.afterSec)
                target.switchOff()
        local function doStopVariant(line, target)
                target.stop().silent().afterSec(line.afterSec)
                target.stop().afterSec(line.afterSec)
                target.stop()
        local function doNotificationVariant(line)
            dz.notify(line.object,line.message[1],line.message[2] or nil,line.message[3] or nil,line.message[4] or nil,line.message[5] or nil)
        local function doOSVariant(osCommand)
            os.execute('sudo ' .. osCommand .. ' &')
            dz.utils.dumpTable(result)
        local function doTasks(result)
            for _, line in ipairs(result) do
                if line.message then
                elseif line.action == 'OSCommand' then
                    doOSVariant(line.object)
                    local baseType, idx = getBaseType(line.object)
                    target = makeTarget(baseType, line.object)
                    if not(target) then
                       dz.log('no device, scene, group or var found',dz.LOG_ERROR)
                       return
                    if line.action and line.action == 'Off' then -- for switch type devices and groups
                    elseif line.action and line.action == 'On' then -- for switch type devices, scenes and groups
                    elseif line.action and line.action == 'OSCommand' then
                        doOSVariant(line, target)
                    elseif line.action and line.action == 'Stop' then -- for type blinds
                    elseif line.label then -- for selector type devices
                    elseif line.set then -- for uservariables
                    elseif line.update then -- for devices to set nValu, sValue
        -- main
        local result = dz.utils.fromJSON(makeLongKeys(item.value))
        doTasks(result)
Jablotron connection, Ikea
Re: Can IFTTT script also work with ID's  [Solved]
pvklink wrote: Thursday 17 October 2019 19:52 Does this script also handles id's instead of names?
In it's current form the script cannot deal with numeric objects because it does use the name to search in the getBaseType() function to identify the type of object (device, uservariable, scene, etc..) . A numeric value is not unique in _G.domoticzData.so this cannot be used.
To enable the script to deal with ID's, the JSON in the uservar should include the type of the object. It would then become something like:
[{"obj":1002,"type":"device","act":"On"}] If you are able to send such a JSON into the var, I am happy to code this into your current script.
If you send me the script via PM as you use it now, I will have a look.
pvklink
Post by pvklink »
OK, thanks Waaren.
Works perfect now!
{"obj":IFswitchID,"type":"device","act":"On"},   if IFswitchID = numeric , type = device, group, etc mandatory
or
            examples
return
    on =
    logging =
        marker = 'ifttt',
            return str
        local function getBaseType(line)
            if line.type then return line.type, line.object end
                if tuple.name == line.object then
        local function makeTarget(baseType, identifier)
                return dz.devices(identifier)
                return dz.groups(identifier)
                return dz.scenes(identifier)
                return dz.variables(identifier)
            elseif line.afterSec and line.forSec then
                target.switchOn().afterSec(line.afterSec).forSec(line.forSec)
            elseif line.forSec then
                target.switchOn().forSec(line.forSec)
                target.switchOn()
                target.switchOff().afterSec(line.afterSec).forSec(line.forSec)
                target.switchOff().forSec(line.forSec)
                target.switchOff()
                target.stop()
                    local baseType, idx = getBaseType(line)
                    if not(target) then
                       return
        -- main
        doTasks(result)
