Could anyone get data into domoticz?
new Xiaomi Mijia Temperature and Humidity Sensor, round with E-ink screen.
On the Internet, I found a description of how to connect the previous model. (Round with LCD screen)
I tried it - but it did not work (((. Error timeout.
The BLE response gives a completely different name - ClearGrass Temp & RH (Not MJ_HT_V1),
accordingly, the exchange protocol may be different.
I will be glad to any advice!
Xiaomi Temperature and Humidity (Round E-ink)
- Domoticz version: 3.8153
Re: Xiaomi Temperature and Humidity (Round E-ink)
I haven’t seen the round e-ink ones yet, but have a couple of the older ones (plus a couple of the square e-ink ones that don’t connect to anything!).
With the lcd ones, I found that the Bluetooth connections were very slow and timed out a lot. You just have to persevere. I use a raspberry with its inbuilt Bluetooth le capability, it may be better with an external one with a better radio.
Do you have a model name for the new ones?
Solved!
To solve the storage location data and the exchange protocol.
I'm programmed the script in python.
You can buy these sensors: "ClearGrass Temp & RH"
- Domoticz version: 2020.2
I'm looking for the script in python for this round E-ink, do you know where I can find this?
Thanks in advance.
Yann
Thanks in advance.
Yann
- Domoticz version: 2022.1
