Temporary solution to using 433 Mhz wall switches for Z-wave wall plugs.
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Switching from my 433 MHz system to Z-wave I shall miss my wall-switches for a long while, I think.
Try one to associated but I have it sending back. Sort this out later.
To use Blockly to connect a 443Mhz switch with a Z-wave wall plug I try this.
The + is the Z-wave wall plug
This went wrong by using timers.
The Z-wave wall plug didn't did NOT switching but CHANGE the time in the icon.
The logic I could see so I came up with ....
No direct connection anymore.
The 433Mhz system had to be on air.
For here is that not a problem because of the garden devices.
May be next summer for change that to Z-wave.
Also for now I don't have to changed my Blockly events.
Because I want to switch my Z-wave wall plugs wen my PC is down but also later for hand remotes for the garden, I have to solve that association problem.
Bear with me, English is not my native language.
Ron
Domoticz version: 2.2284
Re: Temporary solution to using 433 Mhz wall switches for Z-wave wall plugs.
Post by Ron »
I think you should use a group scene.
With the 433Mhz switch you can switch a Z-Wave device on or off.
In this example i can switch the "Gang spotjes" on or off using the 433Mhz "Home Easy schakelaar":
