Hello all,
I'm new to the forum, running Domoticz and Zigbee2MQTT for a few months now and it works pretty stable.
But now I have trouble adding 2 different zigbee devices to Domoticz.
If I look into the Zigbee2MQTT log the devices successfully pair with the zigbee network, but they aren't added to the device list in Domoticz.
The Domoticz "Accept new hardware devices" is enabled during pairing.
All previously added devices work fine through Domoticz
Devices that are not added to Domoticz
- DZ4743-00B
- TRADFRI remote control
Does somebody has suggestions to solve this?
Or can I add them manually to Domoticz?
Setup:
- Raspberry PI 3B+
- cc2531 USB
- RFlink
- Zigbee2MQTT installed
- Several Ikea, Hue, Xiaomi and products are successfully connected
Zigbee2MQTT fail to add new devices to Domoticz Topic is solved
klaasvaak
- Domoticz version: 2020.2
Zigbee2MQTT, LAUNCHXL-CC26X2R1
klaasvaak
Re: Zigbee2MQTT fail to add new devices to Domoticz
Solved it!
Update the plugin and restarted domoticz
https://github.com/stas-demydiuk/domoti ... qtt-plugin
Then the TRADFRI remote control was added to Domoticz
DZ4743-00B is not yet supported by the plugin
So I added it manually by adding the following code to "/home/pi/domoticz/plugins/zigbee2mqtt/adapters/__init__.py"
After restarted Domoticz is was also added to Domoticz
# Lingan
'DZ4743-00B': OnOffSwitchAdapter, # Lingan Zigbee OnOff Controller
