i've found this project
https://github.com/alcar21/WemosEM
and i can't understand if possible to integrate it into domoticz, because looking screenshots, i understand MQTT is supported but i can't see any idx field to fill, so i can't understand the way to use it in Domoticz.
Any expert could explain more?
Thanx in advance
Fabrizio
How to integrate this power measurement sensor in Domoticz?
mvzut
Re: How to integrate this power measurement sensor in Domoticz?
I don't know this project, you can probably get it to work but it doesn't seem to be developed with Domoticz in mind, so it will probably involve extra work to integrate it.
Alternatively, you can have a look at this project:
https://www.letscontrolit.com/wiki/index.php/ESPEasy
Also uses ESP8266 modules, and integration in Domoticz is flawless! I am using this for a few sensors, for instance a water meter.
- emme
- Domoticz version: latest
espeasy will format the telegram for domoticz already...
I think that's the best choice
"We always done this way"
- LouiS22
Why don't you simply buy a shelly EM? It contains everything you need and it also supports Domoticz out of the box via MQTT (and a python plugin).acaonweb wrote: Monday 16 September 2019 8:47 Hi,
Thanx in advance
Fabrizio
acaonweb
well, i have a bunch of wemos to use
acaonweb
yes, but i'd like to understand how measure poweremme wrote: Monday 16 September 2019 10:41 espeasy will format the telegram for domoticz already...
I think that's the best choice![]()
- emme
the best way to do that is using a line analyzer with modbus
I'm succesfully using a Eastron SDM120C and I'm pretty happy with it!
The meter is connected to a ESPEASY Mega (nodeMCU 4Mb) linked to my WiFi and then to domoticz.
