Hello, Nice to meet you all! I am new to this specific Domoticz forum.
After searching online for connecting a PIR sensor with relay and tamper switch to Domoticz by using ESP easy I found the following video; https://www.youtube.com/watch?v=6dz2qkyayLw. It seems to work, but no explanation at all and the text in the video is too blurry to work out what has been done, apart from that it is another language.
So in simple words there are just mechanical switches that have to interact with Domoticz. The tamper switch, and the NO/NC contacts of the relay in the PIR. This is one of the (4) PIR sensors I would like to use for this: https://www.google.com/url?sa=i&source= ... 4014665970
Is there someone on this forum who knows how to connect this physical to the Raspberry PI and used it with Domoticz/ESP Easy?
ESP (Domoticz) with PIR!!
harryweasley
kluczus
Re: ESP (Domoticz) with PIR!!
Maybe this will help you. Bosch PIR with wemos d1 mini and Domoticz
https://www.youtube.com/watch?v=x_2QL5G70xs
Wysłane z mojego LYA-L29 przy użyciu Tapatalka
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
kimot
- Domoticz version: v3.8153
Simply create two dummy switches in Domoticz and make note of its IDX.
Two switches connect to GPIOs on ESP8266 and in ESPeasy create switches and put corresponding IDX to them.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
