change block/device title when value changes Topic is solved
pvklink
Domoticz version: latest b
Post by pvklink »
I made a script that changes the block title when the state of the device changes
Problem is that the title does not change.
When the switch 1474 is On the title must be test1 and test2 when off...
function getChange_1474(idx,value,device){
if(parseFloat(device['state'])='On'){
blocks['1474']['title'] = 'test1';
else {
blocks['1474']['title'] = 'test2';
Jablotron connection, Ikea
HansieNL
Re: change block/device title when value changes
Post by HansieNL »
Can you try:
function getStatus_1474(idx,value,device){
	if (device.Data == "On") {
			blocks[1474]['title'] = "test1"
	 else {
		blocks[1474]['title'] = "test2"
Blah blah blah
pvklink
Post by pvklink »
thanks!
will try that!
pvklink
Post by pvklink »
yes works!
thanks Hansie
