do you have any error in domoticz log?
the strange thing is..... I do NOT have this issue with scenarios (that goes only ON ) or groups (that can be go OFF either)
2018-07-12 17:04:08.079 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":59,"switchcmd":"Off"}
2018-07-12 17:04:23.754 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":59,"switchcmd":"On"}
2018-07-12 17:04:28.752 MQTT: Topic: domoticz/in, Message: {"command":"setcolbrightnessvalue","idx":59,"hex":"FF0B85","brightness":90,"iswhite":false}
2018-07-12 17:04:28.752 Status: MQTT: setcolbrightnessvalue: ID: 3b, bri: 100, color: '{m: 3, RGB: ff0a84, CWWW: 0000, CT: 0}'
2018-07-12 17:04:42.385 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":59,"switchcmd":"On"}
2018-07-12 17:05:30.416 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":59,"switchcmd":"Off"}
2018-07-12 17:05:41.778 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":59,"switchcmd":"On"}
2018-07-12 17:05:53.740 MQTT: Topic: domoticz/in, Message: {"command":"setcolbrightnessvalue","idx":59,"hex":"FF0B85","brightness":90,"iswhite":false}
2018-07-12 17:05:53.740 Status: MQTT: setcolbrightnessvalue: ID: 3b, bri: 100, color: '{m: 3, RGB: ff0a84, CWWW: 0000, CT: 0}'
Did you find this wiki page on MQTT <-> domoticz ?
SyntaxError: Unexpected token O in JSON at position 1
domoMQTT.on('message', function (topic, message) {
try {
var jsonData = JSON.parse(message)
if (TRACE) { console.log('MQTT IN: ' + message.toString()) };
if (IDX.contains(jsonData.idx)) {
self.mqttData(jsonData);
} catch(e) {
console.log('MQTT IN: ' + e);
