when not sure where to post, post here and mods will move it to right forum .
Moderators: leecollings , remb0
laco
Posts: 86 Joined: Tuesday 30 October 2018 12:57
Domoticz version: 2021.1
Post
by laco » Tuesday 17 September 2019 8:37
laco on Thursday 26 March 2020 10:02, edited 2 times in total.
emme
Posts: 909 Joined: Monday 27 June 2016 11:02
Domoticz version: latest
Post
by emme » Tuesday 17 September 2019 9:32
uh... how dows it works? is that a sort of P1 ?
if so, you have to change the waterflow to a counter
"We always done this way"
laco
Post
by laco » Tuesday 17 September 2019 10:37
I don't know where to change it.
The hardware selection is directly in domoticz.
Everything is set correctly.
It should show right Wh.
Picture from ECO-DEVICE:
Picture from Domoticz Devices:
Picture from Domoticz Hardware
laco on Thursday 26 March 2020 10:02, edited 1 time in total.
Destyny
Posts: 3 Joined: Tuesday 24 March 2020 13:55
Post
by Destyny » Tuesday 24 March 2020 13:58
I have the same problem.
l/min instead of kW/h
laco
Post
by laco » Sunday 29 March 2020 16:42
Where is the file located in domoticz ECO-DEVICES hardware so I can do it manually?
Or where in domoticz I can modify the existing equipment and change the liter to Wh?
I was looking for it but I can't find it.
dyter
Posts: 42 Joined: Thursday 08 February 2018 15:48
Domoticz version: 8841
Post
by dyter » Thursday 15 April 2021 21:45
I have same problem !
I think you must modify sql database for this
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
Posts: 7005 Joined: Monday 28 January 2019 18:48
Domoticz version: 2026.3
Post
by waltervl » Thursday 15 April 2021 22:22
The code of this device is in the main source code
https://github.com/domoticz/domoticz/bl ... evices.cpp
It seems untouched functionally since 2017, only later some general code changes/fixes. The latest line shows a SendWaterflowSensor command that seems to be in the source code since the beginning.
So you can change this for new users. Someone needs to change the source code. There could be more files related to this hardware, see also
https://www.domoticz.com/wiki/Developin ... are_plugin
laco
Post
by laco » Tuesday 07 September 2021 9:37
Nothing changed in this?
